Attention vert gurus! top lid not latching - Page 3 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Convertible
Old 05-27-2011, 09:28 PM   #41
fmzip
My Ride: '08 328xi / '01 530i
Originally Posted by boltonic View Post
I brought the pictures to the dealership just to see what they think and they said that it maybe just a tension issue. Apparently I can adjust it by taking off the driver cover and adjusting it there. Of course I don't have the correct socket which I believe is 9mm or 10mm. Anyone have information on adjusting the tension for the cables?
I just adjusted mine until there wasn't any slack....
fmzip is offline   Reply With Quote
Old 05-27-2011, 09:31 PM   #42
boltonic
My Ride: 2005 325cic
How did you adjust it?
boltonic is offline   Reply With Quote
Old 05-29-2011, 08:24 AM   #43
fmzip
Tighten the nut until there is isn't any slack in the cable...........
Old 05-30-2011, 10:01 PM   #44
fmzip
See the threaded rod.....the nut on the threaded rod..
http://forum.e46fanatics.com/attachm...7&d=1283981112
Old 08-14-2013, 08:34 PM   #45
dorisrgnt1
My Ride: 2001 BMW 330CI
Smile OMG! You guys ROCK!
Originally Posted by tooredhots View Post
Fixed! Your post made me really look at the link with pictures and compare in detail how the gears and cabling should look. I head back out one last time to see if I could do anything before taking it in to the dealership.
Turns out the crimped connector was catching on the arm that draws the cables into the motor unit under the seat cushion.
The picture shows the right cable how it should be, and the left is how they both were incorrectly routed.
I thought everything was ok, because they were both caught on the arm in the same way. I did not notice that they were curved to hinge on the arm.
...................... I saw your pic and realized both of mine were the same way as yours and didn't show the "tubes" at the end!!!...Both were stuck under the bracket!!!.....And I'm a girl!! Lol, it now locks!! Thank you, Thank you, Thank you!!
dorisrgnt1 is offline   Reply With Quote
Old 08-30-2013, 11:31 PM   #46
c stockwell
My Ride: 2002 330ci
Hello, I have an 02 330ci vert, with a problem, It seems that the driver side latch will not unlatch to allow my top to come down. Im to the point where im going to cut the plastic cover, and see what i can find out. sounds like a cable broke or somthing related to that latch, Has anybody else had this issue?
c stockwell is offline   Reply With Quote
Old 08-31-2013, 12:16 AM   #47
taylor192
My Ride: 2003.5 M3
Re: Attention vert gurus! top lid not latching
Latch at the windshield or for the storage lid? If at the windshield you will have to cut the plastic cover to find out either the latch is broken or the rod that connects the motor to the latch broke. If for the storage lid then just disconnect the cable from the motor under the rear seat.
Old 04-27-2015, 06:15 PM   #48
sgossler
My Ride: E46 330Ci
I had this problem... only it was the other way around. Very easy to fix! Thanks for the great save!!! it was squeaking and driving me nuts.
sgossler is offline   Reply With Quote
