Thread Tools Search this Thread Rating: Thread Rating: 68 votes, 5.00 average. Display Modes
Old 06-20-2011, 06:49 AM   #101
TitaniumCranium
/// Limitless
TitaniumCranium's Avatar
My Ride: 2002 BMW 330Ci
No moving parts, less to go wrong. I think the idea behind the 20lb SMF is solid. With that much weight I would think it would minimize gear rattle. The additional benefit, you should also have enough mass in the flywheel to keep it spinning as you start to give it gas without being as likely to kill the car, so more foregiving.
The general consensus is that the rattle is caused by power pulses in the motor that are transmitted to the transmission. In order to allow the transmission to spin freely there is a certain amount of gear lash allowed for. When these pulses occur the extremely lightweight flywheel allows the gears to momentarily rub against each other with the modulation of the pulse and you hear it as gear rattle.
With a lightweight flywheel, if the rattle doesn't bother you, and you live in FL it probably isn't that big a deal because you're almost always coming out of somewhere flat, except maybe a parking garage. If you live someplace where steep hills are more normal than flat stretches, life becomes very interesting for you on a daily basis.
/// MODS
Old 06-30-2011, 11:08 PM   #102
someguy_99
someguy_99's Avatar
My Ride: E46,335Xi,Lambo,...
Nice write up i read it all,
someguy_99 is offline   Reply With Quote
Old 06-30-2011, 11:53 PM   #103
kylekruchok
My Ride: 1992 Ford Explorer
I did too.
Holy epic. Sounds like someone had a bit of fun on this! How many trial and errors did you happen to go through as far as the electronics go? Or was figuring it all out in the first place pretty straight forward?
kylekruchok is offline   Reply With Quote
Old 07-01-2011, 01:49 AM   #104
TitaniumCranium
/// Limitless
Thanks for the kind words guys!!! Even in spite of kpeng's 5 days of kindness toward all Americans. He's holdin back and bein a little stingy with his kindness since the rest of the world will not benefit from this newfound spirit. But really... I digress... back on track!
There were others such as xmltok, Neil1138, and, ivegotissues666. I won't lie. I bruised their brains before I was satisfied with the answers I wanted. Thanks guys!
The result was that it all fell into place like like a swiss watch. All the electrical was in the right place and the car started the first time. It was truly uneventful. No electrical meltdowns no mechnical meltdows.
/// MODS
Old 07-01-2011, 12:26 PM   #105
TerraPhantm
My Ride: M3 & ZHP
TitaniumCranium, I remember you were having an issue where the DME was still looking for the EGS even though the DME software is supposed to be the same for autos and manuals... did you ever figure out what was going on there?
Old 07-01-2011, 12:28 PM   #106
jbeurotech
Regional Sponsor
My Ride: 2000 E46 with 254K
Should just need to change the Basic and programed numbers. That is what I do with all the conversions I program. The re-encode the whole car
Seth Thorson
Service Manager/BMW Tech
JB Eurotech Service "Your Reasonable Dealer Alternative"
General Questions can be sent to appointment@jbeurotech.com
1. Do not argue with an idiot. He will drag you down to his level and beat you with experience.
2. Light travels faster than sound. This is why some people appear bright until you hear them speak.
jbeurotech is offline   Reply With Quote
Old 07-01-2011, 12:49 PM   #107
TerraPhantm
My Ride: M3 & ZHP
That's what I figured, but at least according to the ETK (bmwfans.info at least, I didn't actually check my local copy), there isn't an auto-specific programmed number for the non-M E46s... Is the ETK mistaken?
Old 07-01-2011, 04:04 PM   #108
TitaniumCranium
/// Limitless
Yeah, I still don't have this working right.
Using DIS I can remove option 205 from the KOMBI and it indicates that the VO has changed but when I recode the rest of the modules I get an error indicating that the process has terminated because the VO has not changed.
I can disconnect the EGS module, and automatically recode. I get the same error message but the DSC and brake lights go out so it acts like it actually does recode the module but the cruse control doesn't work and the SES light is on.
If I start over using ncs expert I can get the transmission cog to go out and the cruise control works but if I unplug the EGS module I can't get the DSC/brake light to go out using DIS recoding.
So I'm driving around with my SES light on (bus fault - egs trying to communicate with dme), my EGS module plugged in, transmission cog out, and cruise control working.
/// MODS
Old 07-01-2011, 04:36 PM   #109
TerraPhantm
My Ride: M3 & ZHP
Theoretically changing the VO and recoding the modules should take care of everything except the DME.
Have you ever attempted to reflash the DME? The VO isn't used to determine the appropriate DME software, so changing the VO isn't enough for the DME. You have to manually input the number that points to the right software version. If you let DIS, SSS, or WinKFP automatically determine the proper DME version, it'll just flash the latest available automatic tune. If I had to make an educated guess, I would say the appropriate DME version is 7571613. If you attempt to reflash the DME, note down the version thats currently on there before flashing it
Old 07-20-2011, 07:21 PM   #110
KnightroExpress
My Ride: 2002 330ci
Amazing write-up! If (when) my Steptragic fails, this is the first place I'll go for my real gearbox conversion.
KnightroExpress is offline   Reply With Quote
Old 08-13-2011, 11:25 AM   #111
azzy989
azzy989's Avatar
My Ride: 325i
Send a message via AIM to azzy989 Send a message via MSN to azzy989
Thought I'd bump this thread..
I was going to attempt this swap myself, but things came up and I didn't have the time to commit to it. I took it to a BMW indy shop instead and passed them the link to this DIY as a reference for the electronic side of the swap. I am told that the instructions were so good that the car fired up first try!
Some details about my car.. Car is a 2005 with the MS45.1 ECU and a GM A5S 390 R transmission. Swapped in a 6 speed 330 transmission along with a 330 driveshaft and 3.38 LSD. Thanks for being such a vital member in the community!
-Azlan *I want to be like CD330*
azzy989 is offline   Reply With Quote
Old 08-13-2011, 03:28 PM   #112
ESS330xi
My Ride: 330xi
First off, INCREDIBLE WRITE-UP!!!
My question: is it worth it to switch from a 5-spd to a 6-spd? My 5-spd cruises at around 3K RPM, and that's a bit much for me. I remember my Mustangs in college cruised at around 1800 RPM, and that was great. That was also a long time ago, and I would never own another Mustang again.
What type of costs (total) am I looking at for this swap? I just spoke with an independent shop & they said that there might be problem as to the computer not accepting the new 6-spd?
02 330xi
ESS330xi is offline   Reply With Quote
Old 08-13-2011, 05:37 PM   #113
toddeshpeter
My Ride: 1999 328i E46
I am currently ordering parts to go from auto to 5 speed. I wouldn't think of doing this swap if it wasn't for your great diy along with neil's and ivegotissues. Thank you so much! I have a 02/1999 328i that has a GM auto with reverse fail. I have just one question at this point. This is after reading all three diy several times.
1. I noticed on your diy and neil's you didn't change anything with the radiator like ivegotissues did. Ivegotissues said his would spew coolant if he didn't but you and neil didn't seem to have that problem. If I am correct all you did was remove the two lines from the radiator. Can you clarify this for me please?
Thanks, oh and one last question. If I run into trouble and need a little help during the swap what would be the best way to contact you? Email, PM, or on this thread? Thanks again!
toddeshpeter is offline   Reply With Quote
Old 08-13-2011, 07:31 PM   #114
OneOfaKindTrini
My Ride: 540i w/ 3 Pedals..
This swap is just so epic.
07 C280 4M Arctic White(AW) headlightTHEORY
Photobucket
OneOfaKindTrini is offline   Reply With Quote
Old 08-13-2011, 09:47 PM   #115
deafboy
My Ride: 2000 323Ci
If my tranny ever goes out again I am coming over and doing this...lol
-Cole aka bigtall*****
Originally Posted by Owtlaw333 View Post
You'll always be pretty in my eyes, Cole :luv:
Originally Posted by Chrissspyy View Post
i was like passed out while she's shoving the entire bar in my mouth. :rofl: :rofl:
deafboy is offline   Reply With Quote
Old 08-14-2011, 12:38 AM   #116
TerraPhantm
My Ride: M3 & ZHP
Assuming you're talking about 5MT to a 6MT, the computer doesn't care. The only electronic component in a manual transmission is the reverse switch. To go from a 5-speed to a 6-speed, you'd need a new driveshaft, clutch, and flywheel. You shouldn't have to touch the computer at all.
Old 08-14-2011, 02:38 PM   #117
toddeshpeter
ESS330xi, just to mention, you said back in college days your Mustang cruised at 1800 RPM. Assuming you are talking muscle car days, the engine is completely different than your BMW in that the old V-8's were built more for torque and less for horsepower and the BMW engine is built more for horsepower and less for torque. The mustang, being more torquey would run really well at low RPM with a load. At 1800 RPM in top gear and cruising at 60 mph is where that engine would shine. With an engine like the BMW it likes a little more RPM since it is built more for horsepower, so cruising at 60 mph at 3000 RPM is more where it likes to be.
All that aside, swapping to the 6 spd would be nice for gas mileage. If you are cruising at 60 or 70 mph it would be nice to drop it into 6th to save fuel on long trips.
Old 08-14-2011, 03:17 PM   #118
TitaniumCranium
/// Limitless
I didn't replace the radiator. It's not necessary but you could if you wanted to. You just remove the auto-trans cooling lines at the radiator, drain, and cap them off. Whatever you do, if you're keeping the auto radiator, don't remove the auto-trans cooler from the radiator or it will spew coolant all over the place (don't bother asking me how I know).
PM would be the best way, and I'll help in any way I can.
/// MODS
Old 08-14-2011, 10:04 PM   #119
toddeshpeter
Thank you very much for the help and future help!
Old 08-14-2011, 10:44 PM   #120
ESS330xi
My Ride: 330xi
Yikes. . .was hoping for far less costly solution. Crap.
ESS330xi. . .with an engine like the BMW it likes a little more RPM since it is built more for horsepower, so cruising at 60 mph at 3000 RPM is more where it likes to be.
True about the engines, but 60 mph @ 3K RPM isn't where I want to be!
You hit the nail on the head as to gas mileage, but also interior noise levels. It's almost as though the car wants to get shifted into 6th gear, and I'm guessing that's why BMW went to a 6-speed for this car soon after my model year. . .dammit.
02 330xi
