I have a 2000 323ci. About a month ago I was driving around. After a red light, I noticed my first gear seemed really weak. Once I got into second gear, the car went into limp mode and wouldn't go past 2000-2500 RPMs again with extreme power loss.
Also, the EML, DSC, and Service engine soon light came on.
I took it to a BMW Service dealership and got a diagnostic and they told me it needed a new mass air flow sensor. I bought a new one for $331 and have been driving around and it has been great, zero problems (also all the lights went out! )
Today, about 2 weeks later, the same problem occured. I was just driving and noticed my car went back into limp mode and all 3 lights came on.
There are two potentiometers in the throttle body (A&B), the second is for redundancy. They have a carbon wipe based system to sense the position of the throttle. Eventually the carbon strips wear through. There has never been a successful repair and a new TB must be fitted
In Inpa this gives something like a "Throttle position potentiometer sensor A/B implausible value".
Also they can get stuck with gunk.
211 idle actuator, Mecanical error
Error frequency: 1
Logistic counter: 40
Engine speed 1/min 00:00
Airmass 152.00 kg / h
actual value DK degree throttle poti 00:00
Idle duty cycle adjuster 6.64%
appear before (rel.) 0.10 h
Idle plate stuck closed
CARB-error
Error saved after debounce
Error is not currently available
sporadic errors
Error Code: D3 B2 01 28 00 26 00 11 59 5F
If you have bad wiring to the TB or the ECU [unplugged TB in this case] it gives any number of these faults
PWG-172 signal poti potentiometer 1 and 2 short circuit
Error frequency: 1
Driver-wish sensor potentiometer 12:00 PWG 1 degree DK
Driver-wish sensor potentiometer 12:00 PWG 2 degrees DK
Supply voltage 1 0.00 V voltage controller
Supply voltage voltage controller 2 5:00 V
appear before (rel.) 0.00 h
Grinder Short
CARB-error
sporadic errors
Error Code: AC B1 01 28 00 00 00 62 59 78
173 Signal throttle flap potentiometer poti 1 and 2 short circuit
Error frequency: 1
Throttle potentiometer sensor MDK 1 121.88 degrees DK
Throttle potentiometer sensor MDK 2 121.88 degrees DK
Grinder Short
CARB-error
sporadic errors
MDK 169 output stage control after diagnostic failure
Error frequency: 2
intake air temperature 39.00 degrees C
Battery Voltage 12.24 V
cooling water temperature 55.50 degrees C
MDK amp off after diagnosis error
sporadic errors
rrorcode: A9 A1 02 28 00 74 78 59 78 8A
10 signal PWG poti a potentiometer
rror frequency: 1
ogistic counter: 40
actual value padel poti PWG 1 0.00 degrees DK
actual value padel poti PWG 13:59 2 degrees DK
Short circuit to ground or line break
CARB-error
sporadic errors
rrorcode: B2 01 6E 28 00 1D 00 62 59 78
11 Signal PWG poti potentiometer 2
rror frequency: 1
ogistic counter: 40
actual value padel poti PWG 13:59 a degree DK
actual value padel poti PWG 2 0.00 degrees DK
CARB-error
sporadic errors
rrorcode: 6F B2 01 28 1D 00 00 62 59 78
112 Signal throttle flap potentiometer poti 1
Error frequency: 1
Throttle-valve Angle MDK 1 61.39 degrees DK
Throttle valve angle MDK 2 16:40 degrees DK
Short circuit on U-Batt. or line interruption
CARB-error
sporadic errors
Error Code: 70 B1 01 28 83 23 00 62 59 78
113 Signal throttle flap potentiometer poti 2
Error frequency: 1
Throttle valve angle MDK 1 16.40 degrees DK
Throttle valve angle MDK 2 61.39 degrees DK
CARB-error
sporadic errors
Error Code: 71 B1 01 28 23 83 00 62 59 78
I had this same thing start to happen to me, same codes and all. We think the ECU is bad, so I'm in the process of replacing it. If I beat you to a solution I will let you know.
any solution yet? I'm throwing a peak code 6e and a9, i hope it isnt the throttle body.
Related Threads
E46 Fanatics Forum
17.9M posts
592.5K members
Since 2001
A forum community dedicated to BMW E46, E90, and F30 owners and enthusiasts. Come join the discussion about M performance, turbo kits, engine swaps, builds, modifications, classifieds, troubleshooting, maintenance, and more!
