Old 09-11-2010, 01:38 PM   #1
TxZHP04
My Ride: ESS TS2+ ZHP
Question driveshaft replacement
So I pulled my driveshaft today to replace a failing guibo that I believe has been causing some vibration under load. The rubber in the center support was starting to show signs of cracking so replaced that as well. As I was giving everything the once over before putting it back together, I noticed that the boot on the rear CV joint (mates to diff input flange) was torn in multiple places. The joint seems a little stiff to me but I'm not sure what's normal. I've heard that it's either not possible to replace this CV joint or that it's simply more economical to replace it due to the trouble of getting it properly balanced.
Am I correct in thinking that I need a new driveshaft or is it possible the boot can be replaced if the joint isn't damaged yet? Are there any quality options for remanufactured driveshafts? Somebody help me figure out what my options are.
Thx.
Old 09-11-2010, 01:47 PM   #2
B33MER
My Ride: 330i SMG M-Sport
http://www.acpt.com/driveshaft/index.html
CF driveshaft They've done an E46 M3 driveshaft ... Maybe they'll do a non-m?
330i SMG M-Sport Paket II Euro Spec
Mods:
CF Roundels all around, Black grillz, 7000k Angel eyes,6300k HID fog lights, Hamman Lip reps, ACS roof spoiler reps, Alutech front and rear struts, BMC CDA with DIY heatshield, Pro RS braided brake line, ///M Billet Oil Cap, OEM ///M mats, ///M aluminium pedals,
B33MER is offline   Reply With Quote
Old 09-11-2010, 01:58 PM   #3
TxZHP04
Thanks, not looking for anything exotic though... just a simple repair/replacement for the stock part.
Old 09-11-2010, 02:16 PM   #4
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
As long as you haven't lost much grease out of the joint, I'm sure you could just replace the boot. I tore a rear outer boot (brake line rubbed it and tore). Caught it before I lost too much, was able to just replace the boot/grease. Messy job
Old 09-11-2010, 03:14 PM   #5
TxZHP04
Can't replace just the boot, it's molded into the CV joint. Advice from Autoscope was to replace the driveshaft which is consistent with what I've read/heard before. Would love another option but I think it's down to finding someone that's capable of rebuilds or just buying a new one through BMW. Faulkner is listing them for ~$650 and Tischer for about $685. Rick told me to expect about $600 for a rebuilt. I just hate it when an otherwise simple repair reveals a bigger problem.
Old 09-11-2010, 04:55 PM   #6
McSpeed
My Ride: 2005 ZHP TT Stg 1
Weird - do the the tears look like they're from the boot getting pinched because the driveshaft was allowed to hang from the CV joint end?
SOLD but fondly remembered...
Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife
ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch
Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs
Turbo Driveability Video
Horsepower vs. Torque
McSpeed is offline   Reply With Quote
Old 09-11-2010, 05:24 PM   #7
TxZHP04
Hard to say what would have caused it.
I have updated info from another local tech who says replacing the CV joint should be doable and with no balance concerns. Now I just need to figure out how long the u-joints typically last. If they might go in 20-30k miles, I think I'd just assume go ahead and replace everything now.
Old 09-13-2010, 09:48 AM   #8
mrshelley
My Ride: 2004 330i
You can buy the rear CV joint (PN - 26117548392) and don't worry about the balance. This is what I'd do. I'd take off the rear CV joint and clean it up. Then I'd clean up the boot really well. Then I'd apply a nice coat of black RTV on the inside and outside of the boot. Repack the CV joint and put it back on.
That rear CV joint does not go through the amount of movement as a regular one does on an axle. It's not super critical that it needs to be 100% sealed. I bet the RTV on that boot will last you many years and save you the $188 that the CV joint retails for.
In conclusion, change out the flex disk, center support bearing, clean and reseal the rear CV joint. I bet that will be the last time you will be messing with the driveshaft.
Old 09-13-2010, 02:15 PM   #9
TxZHP04
That thought had crossed my mind....
So how does the CV joint attach to the shaft? Presumably there is some sort of fastener hiding under the boot?
Old 09-13-2010, 02:40 PM   #10
mrshelley
My Ride: 2004 330i
There's a snap ring on the end (not on the boot side). After that, you'll have to hammer the CV joint off with a brass drift. Here's a breakdown of the parts:
http://www.realoem.com/bmw/showparts...97&hg=26&fg=10
Old 09-13-2010, 03:06 PM   #11
TxZHP04
So I guess that means the end cover (#20) just pops off to expose the snap ring?
Old 09-14-2010, 09:23 AM   #12
mrshelley
My Ride: 2004 330i
Yep
Old 09-14-2010, 10:52 AM   #13
TxZHP04
Thanks! I'm much more willing to take something apart when I know how it's actually supposed to come apart.
Old 09-14-2010, 02:16 PM   #14
mrshelley
My Ride: 2004 330i
That CV joint is just like about what most German cars have had on axles since the 60's. I don't really understand why a 330 has a CV joint there as a 3.0l Z4 only has a U-Joint like in a 328, 325 or 323.
Old 10-14-2010, 03:01 PM   #15
TxZHP04
Anyone happen to know which specific clamp tool is required for the drive shaft CV boot clamp, BMW part 26117542264? I've got some rear subframe mount issues to attend to (once again), but after that's squared away, I'll be replacing the CV joint.
Old 10-14-2010, 03:56 PM   #16
xixixi
Banned User
My Ride: 01 330x-xi
I have a 330i Drive shaft from a manual? Also a shop near my house can make/balance a drive shaft for you. I had to have them make me one for my awd to rwd swap. I can send you the Drive shaft for 150 shipped.
Old 10-14-2010, 04:21 PM   #17
TxZHP04
Thanks for the offer but the replacement CV joint, clamp, and snap ring have already shipped.
Old 10-14-2010, 04:55 PM   #18
McSpeed
I'm gonna do this pretty soon as well - already got the parts. It looks like someone in here before me didn't know how to get the driveshaft off so they whaled the side of the flange section hard enough to bulge up the surface where torx screws go in. I hadn't noticed anything weird happening while driving but I figure I'll just replace the thing while the car's all apart anyway.
Old 10-17-2010, 10:52 AM   #19
McSpeed
I wasn't noticing progress with the hammer/drift method and I saw a dimple for a puller at the end of the shaft so I just pulled the CV with a 2/3 jaw puller from autozone. I used the extra puller arm mount for a very handy counter brace bar:
ID:	380025   Click image for larger version
Old 10-19-2010, 09:46 PM   #20
McSpeed
I just wrapped up the CV replacement. Something that looks like this would work for a clamp wrench:
http://www.amazon.com/gp/product/B00...F8&me=&seller=
Autozone had a similar one to loan. I tightened the clamp up with ~that^ and made the final pinch with a little set of craftsman cutter pliers (the one on top in the picture):
http://www.sears.com/shc/s/p_10153_1...u=00945671000P
Note that the clamp that Faulkner sent me was not the same as the one that was on the car originally.
Unrelated, but in case it helps: the end cap (#20) gets pressed evenly & tightly back on by the diff flange so no need to drive it in. You'll probably want a new end cap, too - I couldn't get mine off intact.
