Sponsored by The Tire Rack
Old 09-13-2010, 10:01 PM   #1
nhat179
My Ride: E46 323i Sedan 5 spd
Tire rubbing question
I did a search but didn't help at all. My rear set up was 19x9.5 +39 with 245/35/19 tires. My fender was shaved. I dropped on coilover but don't slam all the way down. In normal driving condition, I have no problem, but when I drive by some kinda wavy road, i notice the tire was rubbed in the back. Any suggestion? Thank you for your information.
This is how low my car dropped, i don't think my car is that low to be rubbed
nhat179 is offline   Reply With Quote
Old 09-14-2010, 04:10 AM   #2
Dean | KHOALTY, Inc
Dean | KHOALTY, Inc's Avatar
My Ride: BMWs
Would you be able to take a picture of where the rubbing occurs? If it's by the sidewalls, then you might need to pull/flare or adjust the camber. If it's rubbing on the top of your wheel well, then you'd need to stiffen your coils a bit.
But quite honestly if its just very minor (especially if you're into the whole stance phenom), "you ain't ballin, if you're not rubbin."
Dean | KHOALTY, Inc is offline   Reply With Quote
Old 09-14-2010, 11:12 AM   #3
beamah
My Ride: 99 328 sedan
maybe 30 series tires in the rear would help?
koo lil ride btw
beamah is offline   Reply With Quote
Old 09-14-2010, 11:32 AM   #4
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
Some more fender rolling and shaving may be required since the offset is aggressive for Sedan.
What tire manufacturer are you running? If you are open to swapping tires, Toyo T1R's or Falken FK452's offer great side wall characteristics and will yield you the most optimal clearance compared to other brands.
-Charles@VMRWheels
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 09-14-2010, 12:12 PM   #5
DangerousMind
My Ride: Sierra 1500 SLT
I have 19x9.5 +40 and shaved fenders on my coupe and it is a close fit. You have a sedan with virtually identical wheel offset and smaller fenderwells. You will need to dial in some camber or shave the fenders more or pull them.
DangerousMind is offline   Reply With Quote
Old 09-14-2010, 06:04 PM   #6
nhat179
Thanks for all reply guys. I will try to find out where the rub occured take some pix.
Old 09-14-2010, 08:21 PM   #7
nhat179
I found out that it was rubbed on top of my wheel well. You guys think that some negative camber will help? Thank you
Old 09-14-2010, 10:24 PM   #8
Eli1
My Ride: ZHP
Negative camber should help out.
Im running 19x10 et38 with 245/30/19 YOK S-Drives(pretty much same height as my stock 255/35/18) my fenders are barely rolled and I only rub on big dips or if I turn really hard. I'm going to roll them completly flat so I can lower it some more and maybe add a 5mm spacer.
Eli1 is offline   Reply With Quote
Old 09-16-2010, 12:50 AM   #9
cd330
ModZombie Moderator
cd330's Avatar
My Ride: SG E46, AW F30
i am running a 19x9.5 40 et in the rear on a 265/30/19 with cut fenders on UUC suspension and I rub in the same area and am lower than you. You can stiffen the suspension and adjust the camber, even run a 30 tire instead of 35 and it might solve the problem.
cd330 is offline   Reply With Quote
Old 09-16-2010, 12:54 AM   #10
smoke96
My Ride: 2004 325ci
take an ice shaver to your sidewall.
[QUOTE=Back2Basics;11538236]So you're gonna have your food delivered to you while you sit at your computer screen on the 112th floor responding to questions about dildo's and sex lube's while strangers fill your bank account to acquire the tools needed for their sick, guilty pleasures?
That's pretty ****ing legit man.
smoke96 is offline   Reply With Quote
Old 10-07-2010, 05:46 PM   #11
nhat179
How about I put a 19x8.5 with 235/35/19 will be good?
Old 10-07-2010, 05:50 PM   #12
Eli1
My Ride: ZHP
Depends what offset my zhp comes with 18x8.5 with 255/35/18 no problems but offset is what makes the difference. Right now I'm running a 19x10 +38 245/30/19 and the fenders are slightly rolled and it rubs still. On the front um running a 19x8.5 +40 with a 6mm spacer so +34 with a 215/35/19 and with the front slammed I still have too much room between the tire and fender probably going to pick up a 15mm spacer to replace the 6mm.
Old 10-07-2010, 08:15 PM   #13
nhat179
sorry guys, forgot to said that the wheel i'm talking about is 19x8.5 +40mm
Old 10-08-2010, 01:36 PM   #14
VMRWheels
VMRWheels's Avatar
19x8.5 +40 with a 235/35/19 is perfectly fine. No fender rolling will be required.
-Charles@VMRWheels
Old 10-10-2010, 06:35 PM   #15
nhat179
-Charles@VMRWheels
Thank you for all your help guys.
Old 10-22-2012, 05:44 PM   #16
aahmed2016
My Ride: 2003 330i ZSP/CP/PP
Originally Posted by cd330 View Post
i am running a 19x9.5 40 et in the rear on a 265/30/19 with cut fenders on uuc suspension and i rub in the same area and am lower than you. You can stiffen the suspension and adjust the camber, even run a 30 tire instead of 35 and it might solve the problem.
quad exhaust on a 330? How? Teach me the ways master!
Originally Posted by MercForHire View Post
Spends $2000 on car DVD + stereo -> Running 25000 mile oil changes and 87 gas with blown shocks
aahmed2016 is offline   Reply With Quote
