Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > Southwest
Southwest
AZ NM NV OK TX UT
Old 09-17-2010, 03:40 PM   #1
rhinos57
My Ride: 2002 330ci
Cool Belt replacing
Guys,
after a routine inspection of the engine compartment on my 330 C. I I became aware that the serpentine belt and a/c are in need of replacement and since I don't know when the last time the tension or pulley or the idler pulley were replaced I'm intending to replace those at the same time. I was in hopes that someone has done a video of this process so that I don't remove anything that I don't necessarily have to remove in order to do the job so anybody out there has done this or has seen it if they would put me up I would greatly appreciate it.
I also have a news noise that I would like for you to give me your opinion on when I turn the key on without starting the car it makes a noise that sounds like someone saying, HUH. The first time it did it I had passengers in the car and I thought one of them said it the second time it happened my wife was in the car and I thought she said finally I was by myself and it did it again so I don't feel like I'm losing my mind any ideas would be greatly appreciated.
Ron
In Houston
rhinos57 is offline   Reply With Quote
Old 09-18-2010, 12:29 PM   #2
wildcat293
My Ride: 325xi
Just did this a few min ago, thought about taking pics but its a real easy DIY.
You need to figure out if you have mechanical or hydraulic pulleys first.
If you have mechanical you want Qty 2 of Dayco 89133 (Main tensioner and A/C Tensioner) and Qty 1 of Dayco 89089 (Main idler pulley). These Dayco parts are made in germany by INA and are the same ones on your car.
For hydraulic I think you need Qty 2 of Dayco 89046 and Qty 1 of Dayco 89089 but I am not 100% sure since I had mechanical.
Rock Auto has these parts for cheap, or you can go to advanced auto.
If you have an auto this DIY covers most of the stuff you need
http://forum.e46fanatics.com/showthr...diy+water+pump
These are the steps for mechanical tensioners:
Once you get the fan out you will need a T40 and a T60 torx bit
For the top (main tensioner) there is a 16mm bolt that you use to turn the tensioner to remove the belt. Use a 16mm or 5/8" socket and turn the tensioner. There is a slot in the tensioner that you can stick an allen key through to hold it loose.
Once its held loose pop off the dust cap and use the T40 to remove the shoulder bolt. Bolt is right hand thread (lefty loosey). Put on the new pulley and tighten the bolt until you start moving the tensioner instead of turning the bolt.
Next take off the idler pulley, this is a normal socket. Don't know what the torque on this one is so i went "fairly tight".
Finally there is the A/C tensioner which is a bit different. You use a T60 to turn the tensioner and relieve the tension, pin it with the same allen key. There is a 16mm bolt there but this isn't what you want to turn! Removing the pulley is the same as the other tensioner.
wildcat293 is offline   Reply With Quote
Old 09-18-2010, 12:47 PM   #3
BimmersGarage
My Ride: E46 330i
@Rhinos57
Just check out my DIY vids, it'll show you everything you ever wanted to know about your serpentine & A/C belts and pulleys. (Read the video Description for more details.)
Just take your time.
Good luck.
About your "Huh" noise... not quite sure what that is, can you video it for reference?
BimmersGarage is offline   Reply With Quote
Old 10-23-2010, 04:40 PM   #4
devGOD
devGOD
My Ride: AA S/C 2000 323i
Send a message via AIM to devGOD Send a message via Yahoo to devGOD
you can use a 16mm or 5/8 on the A/C pulley too. its much easier than loosening a screw
Xbox360: devGOD
devGOD is offline   Reply With Quote
