Sponsored by BAVSOUND
Old 09-20-2010, 02:55 PM   #1
sinlightened
My Ride: '01 325ci
OEM Headunit swap. Internal Antenna?
I am needing to swap the headunit in my 01 325ci. From what I've gathered, this unit has an internal powered antenna and ones post 2002 don't. If I were to get one of the later dated ones (possibly for aux or mp3 support) what would I need to bypass this antenna so FM will still be an option as well?
"I hate to advocate drugs, alcohol, violence, or insanity to anyone, but they've always worked for me."
Hunter S. Thompson
sinlightened is offline   Reply With Quote
Old 09-20-2010, 04:22 PM   #2
sinlightened
My Ride: '01 325ci
no one has any input?
Hunter S. Thompson
Old 09-20-2010, 05:23 PM   #3
Steve330ci
My Ride: 2006 325ci vert
To use a newer HU in an '01 E46, you need an antenna adapter because BMW changed the antenna connectors in 2002. You may also need a newer antenna amplifier, which is in the driver's C pillar on a coupe or sedan. You can get the antenna adapter at Best Buy's install bay - I recall it's a VW-10 and a EU-20 that you connect together. The antenna amplifiers are available on EBay.
Steve330ci
2006 325ci vert
Steve330ci is offline   Reply With Quote
Old 09-20-2010, 06:03 PM   #4
Darkoz
My Ride: E46 325Ci
As Steve330ci mentioned all you'll need is an antenna adaptor, a new antenna amplifier is not needed though.
Darkoz is offline   Reply With Quote
Old 09-20-2010, 07:31 PM   #5
sinlightened
My Ride: '01 325ci
sweet, thanks guys.
Hunter S. Thompson
Old 09-21-2010, 02:08 AM   #6
Arty
My Ride: 1999 328i
You need a FAKRA DIN adapter to convert the antenna connection to your NG radio. You need to follow this guide to fit an NG C pillar amp with the diversity antenna selection built in.
Arty is offline   Reply With Quote
