Sponsored by BimmerWorld
Old 09-21-2010, 10:56 AM   #1
coffee
Waiting for my V8 4door M3!
My Ride: is Pepsi blue
Send a message via AIM to coffee
Rotor and pad suggestions
Man I'm confused and frustrated! My car seems to enjoy warping rotors. Dealership replaced them twice and after my warranty ran out, I bought another set and now those are warped. Can anyone recommed a good quality set of rotors and break pads?
I don't run autox or race. I own a 2003 530i sport.
coffee is offline   Reply With Quote
Old 09-21-2010, 11:06 AM   #2
ChasCan
My Ride: 2001 330xi
It sounds as if you may have a binding caliper causing your rotor/s to warp. Check for free wheel rotation. The wheel that does not rotate freely will be the caliper that is bound up. HTH, Chas
ChasCan is offline   Reply With Quote
Old 09-21-2010, 02:48 PM   #3
ECSTuning
ECSTuning's Avatar
My Ride: BMW
We to make shopping and purchasing brakes for your vehicle simple and affordable with our 'RPS' kits.(Rotors Pads and Sensors)
Our RPS kit includes everything you'll need to do the job at home on a Saturday afternoon. The RPS kit is a perfect brake replacement kit for your E46!
Includes the following Parts:
* Front Brake Rotors
* Brake Pads
* Brake Wear Sensor
Best,
Joe
Old 09-21-2010, 02:58 PM   #4
coffee
thanks guys! Anyone else have any suggestions?
ECSTuningJoe - I never heard of those rotors before nor did I hear about the last rotors that I bought. I just don't want to buy another set that will simply warp again 6,7 or 8 months later
Old 09-21-2010, 03:06 PM   #5
BimmerBrakes
The Brake Newbie!
My Ride: 2005 ZHP BMW
Send a message via AIM to BimmerBrakes
There are tons of Brands.
Meyle, Zimmerman, Centric, Stoptech, Powerslot, and Brembo for Rotors
Performance Friction Z-Rated pads, Stoptech Street Performance pads, Hawks HPS and etc. for Pads.
-Anthony@BimmerBrakes
BimmerBrakes is offline   Reply With Quote
Old 09-22-2010, 11:48 AM   #6
ECSTuning
ECSTuning's Avatar
My Ride: BMW
The rotors in the kit listed above are manufactured from Brembo, who is known for their high quality braking components, as well are an OEM supplier!
Old 09-22-2010, 12:12 PM   #7
hummer
My Ride: 2001 330CI
If you are warping multiple set of OEM rotors, the rotors are not the issue! Something else is causing them to warp. Personally, I have never seen a warped rotor. Are the caliper pistons sticking, slides sticking? Do you put the car away with wet brakes? Do you ride the brakes?
Old 09-23-2010, 02:37 PM   #8
blarf
My Ride: 323i, 325iT, 540iT
That.
My list of suspects would include:
- driver (technique)
- sticking calipers (pistons, sliding pins)
- brake lines
- suspension bushings or steering components
- unevenly torqued wheels
Originally Posted by howie View Post
do you park near poodles?
blarf is offline   Reply With Quote
Old 09-26-2010, 10:29 PM   #9
Kubica
My Ride: 2003 325xi
I don't think performance friction makes pads for the 530, otherwise I would have put them on my dad's 2003 530i. I'm a huge fan.
I used Brembo rotors with Pagid oem type pads on the 530i.
And I have warped a few rotors in my day by driving through puddles with very hot brakes.
