BMW 330Ci Turbo - 500rwhp and 640rwnm - Vids page 5 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 17 votes, 4.76 average. Display Modes
Old 09-21-2010, 02:56 PM   #1
JimmyOberg
My Ride: BMW 330Ci 2001
Hi, Some of you may have seen my thread about my NA engine build in the Motosport section here on e46fanatics.
Changed plans resulted in:
* SPA Exhaust manifold
* Precision SC6262 Billet Turbo
* Presision 44mm Wastegate
* 3" Steinless exhaust with 2 SIMONS silencers
* PPF 50mm BOV
* 450X300x75 Intercooler
* BMC Airfilter
* Link G4 EMS
* Audi ignition coils
* Siemens DEKA 895cc injectors
* Bosch 044 fuelpump mounted in the tank.
* Aeromotive AN6 regulator
* Modified fuelrail
* Clutchmaster 2-disc clutch with their flywheel. (From Adam's dragrace car)
I'm sure I forgot something but all these parts are bolted onto the stock engine.
The goal is to dyno ~450rwhp on Ethanol and stock engine.
PPF have theif 400rwhp "safe" kit for stock M50B25's, So I hope the M54B30 should last for a while with +50rwhp.
Hopefully it will be tuned and dynoed at PPF within 2 weeks. Pictures will come by the end of this week..
JimmyOberg is offline   Reply With Quote
Old 09-21-2010, 03:02 PM   #2
MachRc
E46Fanatic
MachRc's Avatar
My Ride: 2003 Technik S1 M3
Good Luck
SPA turbo.. wow havent heard that in ages..
is it this ebay piece?
http://cgi.ebay.com/ebaymotors/BMW-3...#ht_8960wt_802
"Can it be, we've run out of time? You're alive.. ohhh? In these streets we living to die. When it's your time, you will know..
..cause it ain't hard to tell. "
MachRc is offline   Reply With Quote
Old 09-21-2010, 03:11 PM   #3
JimmyOberg
Originally Posted by MachRc View Post
Good Luck
No no... Only the exhaust manifold. This is not a kit, it's all put together from scratch with products and brands that PPF carries... http://www.pure-pf.com
Old 09-21-2010, 07:48 PM   #4
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
Nice! So is the motor still built, or is a stock engine?
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is offline   Reply With Quote
Old 09-21-2010, 11:17 PM   #5
bluejeansonfire
ninja editor
My Ride: m5xual
Send a message via AIM to bluejeansonfire
Jimmy, welcome to the FI section... it'll be so much easier for me to keep up with what you're doing now, you're in the real subforum.
Can't wait to see it running.
I can't explain how jealous i am of your ethanol
01 330cit-92 s13c-99 328i/5-04 x5/6
bluejeansonfire is offline   Reply With Quote
Old 09-21-2010, 11:40 PM   #6
turboaddiction
My Ride: Turbo M3
Those new Link systems are supposed to be pretty good. I had an older Link Standalone on my e36 in the past. PPF always loved using Autronic but I believe that the new G4 Link is so good they are now going with that instead?
As long as you have the right standalone and the right tuner who knows how to properly wire the engine harness and tune it, then you can turbo anything. Good for you!
Oh, those injectors are a little big for that turbo. You should be going with the Precision pt71 billet dbb and then you could make 850whp!
| TRM | The Racers Market | Turbo M3 | 559whp@18psi | Dynojet Confirmed 6-1-2010 |
| The Truth Shall Set You Free! | It's Good To Have Her Back! |
turboaddiction is offline   Reply With Quote
Old 09-22-2010, 04:16 AM   #7
JimmyOberg
The motor is stock so far.. I have another engine that i'm building for more boost.
Thanks. So you dont have ethanol in the states yet? It's like cheap race gas at the gas stations over here in Sweden.
I'd say the injector size is perfect for 500rwhp. Ethanol requies injector sizes that are about 30% bigger than pump gas.
PPF has left Autronic and are now mostly using ViPec, Which is 99% the same EMS as Link.
Old 09-22-2010, 05:07 PM   #8
SweTurbo
Big Pimpin'
My Ride: 323i -98
Can't wait to see how this goes
Hur har du planerat med ECU- delen av bygget , kommer det vara blandat mellan bmw och eftermarknad , eller kommer du bygga nått helt eget ?
Tänkte för ecu'n sköter ju hastighet,antisladd osv....
This and women is why i'll never stop loving sweden
Old 09-22-2010, 05:31 PM   #9
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
We can get ethanol in the states. Some states just have it more readily available than others. It's not generally at the pump, but it's easy to come by.
Old 09-23-2010, 12:26 AM   #10
turboaddiction
My Ride: Turbo M3
Oh damn I missed that you are using ethanol. Nevermind. All good! I wonder why they stopped using Autronic. I heard ViPec is great.
Are they really all that hot? Damn I should have travelled to Sweden when I could have. I dated a chic who was born in Sweden and her mother had a heavy accent. If her mom had been divorced I'm sure I could have gotten both of them. Both were hot.
Old 09-24-2010, 02:31 AM   #11
JimmyOberg
Link sprutet är kopplat parallelt med orginal systemet... Allting kommer att fungera som vanligt då orginalsystemet styr VANOS, mätare, antisladd, färddator, etc. Det enda som stör mig är att Check Engine lampan lyser.
Maybe I should translate this becouse I belive more of you will wonder.
Pir4t asked me how things like the antispin, speedometer, dash, ect are going to work with Link/ViPec EMS.
Stock DME is still there, running all these things. Including the VANOS for the moment. Only thing that shows something is different is the Check Engine light...
Old 09-24-2010, 06:07 AM   #12
SweTurbo
Big Pimpin'
My Ride: 323i -98
Thank you , I hope we can get a race together sometime in the future to see just how many minutes(not bothering with seconds..) behind i'll be
As for the check engine light you could always have the LED disabled if it's the light that bothers you.
If it's the reason the LED is on that's bothering you i believe ESS know how to disable the light for vanos/timing/other reasons.
Old 09-24-2010, 04:35 PM   #13
JimmyOberg
Finally, It's alive.
Took the car to PPF today and we finished the exhaust and also the wireing that was remaining.
I had a gas leak in the fuelrail from welding one fitting for the.. hmm.. english.. back to tank line. When that was fixed and another small error was fixed it started just fine. Now I have some small things left to do, and hopefully Andreas have time to dyno and tune it by the end of next week.
Old 09-24-2010, 04:39 PM   #14
lllSupra
My Ride: E46 330i
If you used say an aem ems couldn't "any" shop tune it?
lllSupra is offline   Reply With Quote
Old 09-24-2010, 04:42 PM   #15
JimmyOberg
Andreas tunes almost all systems... But PPF are specialised on ViPec/Autronic... And they are 2km away from me so I see no reason for choosing something else..
BTW, I used Autronic SM4 on my E34 535 Turbo... But I have to say Link/ViPec seems alot easier installing.
Old 09-27-2010, 11:36 AM   #16
JimmyOberg
Dyno will be Friday 08.00!
I've done some cruising to see that clutch and everything is working. It sounds pretty cool with 3" SS exhaust and two small dampers. Also I've taken some pictures but forgot the camera at the shop. I get back with pictures and dyno results next weekend.
Old 09-27-2010, 11:42 AM   #17
bluejeansonfire
ninja editor
My Ride: m5xual
sweet!
Old 10-01-2010, 08:28 AM   #18
JimmyOberg
435 RWHP and 585 NM
This at only 0.95 bar!
Runs really good! Only thing now is traction...! My 225/40/18 doesnt make that much grip until 4th gear!
Old 10-01-2010, 08:34 AM   #19
JimmyOberg
BTW, I got full boost 0.95bar at 2700 rpm.. The response is great!
Old 10-01-2010, 08:57 AM   #20
mertd
Banned
My Ride: M3_M3_M5
nice project.
Will you measure 60-130 mph?
mertd is offline   Reply With Quote
