Bavarian Soundwerks' Mobile Electronics Forum
Have all your A/V and electronics questions answered here. Ipods, A/V, Radar Detectors Oh My! Sponsored by Bavarian Soundwerks |
#1 |
Harmon Kardon Subs or Amp?
The subs in my car started distorting for awhile and then stopped working not too long after i got my car. I open the sub box and the speakers seem physically fine. Do i just need to replace the amp? how can i be sure of this?
#2 |
help anyone?
#3 |
My Ride: 2002 Carbon Black M3
I would check and see if you are getting a signal into the subs first. If no signal then your amp is toast.
#4 |
i reconnected them a few months ago and there was nothing happening with the subs. so i guess its the amp then.
#5 |
If your other door speakers are working, I doubt it is the amp.
The OEM sub is really subpar. I would replace it with an aftermarket one + mono amp. |
#6 |
just wanted to clarify my fix for those who are searching around. The issue was a loose induction coil on the circuit board in the amp. I found a DIY and i re-soldered the coil and glued it down. Never had an issue since. The DIY is easy to find.
