Go Back   E46Fanatics > Classifieds > For Sale, For Trade or Wanting to Buy > Lighting & Mobile Electronics (I.C.E.)
Xenon lighting, HID kits, fog lights, BMW head units, navigation, speakers, subwoofers, In Car Electronics (I.C.E.), carputers, DDEs, angle eyes, halos, LED tail lights, interior lighting, etc.
Old 10-05-2010, 05:48 PM   #21
RHLP3
My Ride: An office chair
Bump for awesome work. Perhaps you can sell the IP to the folks at BSW and speed up their stage 2 upgrade release?
If we leave by midnight...
RHLP3 is offline   Reply With Quote
Old 10-06-2010, 09:51 AM   #22
Jaytona
Account Under Review
My Ride: e46/e66/e30
The harness connector pin numbers are embossed on the plastic. There are two "halves" to the connector, looking at the female harness connector its pin lay out looks like this:
Grey of connector
Pin # 13 / Tweeter Rear Right door + * Yellow Pin # 21 / Tweeter Rear Right door - *Blue / yellow
Pin # 12 / Tweeter Front Right - Blue / Brown Pin #20 / no connection
Pin # 11 / Tweeter Front Right + Blue / black Pin #19 / no connection
Pin # 10 / Switched +12v remote turn on White Pin #18 / no connection
Pin # 9 / Head unit output Front Right + Blue / red Pin #17 / Head unit output Front Right - Brown / orange
Pin # 8 / Head unit output Rear Right + Blue / black Pin #16 / Head unit output Rear Right - Brown / orange
Pin # 7 / no connection Pin #15 / no connection
Pin # 6 / no connection Pin #14 / no connection
Pin # 5 / +12v factory amp +12v supply *Red / green
Pin # 4 / Woofer Front Left +Blue / white
Pin # 3 / Woofer Front Left -Blue / brown
Pin # 2 / Woofer Rear Left +Yellow
Pin # 1 / Woofer Rear Left -Brown
Black of connector
Pin # 34 / Tweeter Front Left - Yellow / brown Pin # 42 / Mid Front Right door + *Green
Pin # 33 / Tweeter Front Left + Yellow / red Pin #41 / Mid Front Right door - *Blue / green
Pin # 32 / Tweeter Rear left door - * Yellow / brown Pin #40 / Mid Front left door + *White
Pin # 31 / Tweeter Rear Left door + * Yellow / black Pin #39 / Mid Front left door - *Blue / white
Pin # 30 / Head output Front left - Brown / orange Pin #38 / Head output Front Left + Yellow / red
Pin # 29 / Head output Rear Left - Brown / orange Pin #37 / Head output Rear Left + Yellow / black
Pin # 28 / no connection Pin #36 / no connection
Pin # 27 / no connection Pin #35 / no connection
Pin # 26 / DC ground factory ampBrown
Pin # 25 / Woofer Rear Right +Blue
Pin # 24 / Woofer Rear Right -Brown
Pin # 23 / Woofer Front Right +Blue / Red
Pin # 22 / Woofer Front Right -Blue / Brown
Pins 1-5 and 22-26 are heavier connections that then other pins, these are the ones that feed the woofers and provide power to the factory amp. I did not use the power connections for the factory amp for the ADS amp - the ADS can draw 30A and the factory connector had wire much to small for that type of current draw. Instead I powered the ADS amp directly (with safety fuses etc) from the battery (easy since BMW puts the battery in the trunk).
Jaytona is offline   Reply With Quote
Old 10-06-2010, 09:53 AM   #23
Technic
My Ride: 2015 320i
Thanks...
You can make your own amplifier upgrade with this harness, while choosing your own amplifier(s).
Technic is offline   Reply With Quote
Old 10-06-2010, 09:54 AM   #24
Technic
My Ride: 2015 320i
Grey of connector
Black of connector
What's the purpose of this post here?
Old 10-06-2010, 10:00 AM   #25
Jaytona
when u use this harness do u still connect the stero speaker wires to the back of the radio harness to the cars radio harness ?
Old 10-06-2010, 10:01 AM   #26
Jaytona
and run the out put speaker wire comming from the amp to the imput by the amps input harness?
Old 10-06-2010, 12:09 PM   #27
Technic
My Ride: 2015 320i
All the wires from the back of the OEM radio/Nav tuner are available at the trunk OEM amp connector; you just posted the OEM amp connector wire assignments that clearly show all the wires (inputs and outputs).
In this harness, the OEM radio/Nav tuner outputs are terminated with RCA plugs. There's no need to remove the radio or do anything in that Quadralock connector in the back of the radio.
The OEM amp is replaced by this harness, so you can connect your own amplifiers while using the existing OEM wires without cutting, splicing or tapping them.
Again, why the post of the pin assignments in this thread?
Old 10-07-2010, 06:03 AM   #28
Technic
My Ride: 2015 320i
Bump...
Old 10-07-2010, 06:46 PM   #29
Technic
My Ride: 2015 320i
Bump...
Old 10-08-2010, 03:23 PM   #30
Technic
My Ride: 2015 320i
Bump...
Old 10-08-2010, 03:40 PM   #31
Bill W
My Ride: 330ci
Nice looking work.
Bill W is offline   Reply With Quote
Old 10-09-2010, 08:32 AM   #32
Technic
My Ride: 2015 320i
Thanks...
Old 10-10-2010, 08:51 PM   #33
Technic
My Ride: 2015 320i
Bump...
Old 10-11-2010, 09:57 AM   #34
Technic
My Ride: 2015 320i
Bump...
Old 10-12-2010, 04:53 AM   #35
Technic
My Ride: 2015 320i
Bump...
Old 10-12-2010, 10:40 PM   #36
Technic
My Ride: 2015 320i
Bump...
Old 10-13-2010, 12:16 PM   #37
Technic
My Ride: 2015 320i
Bump...
Old 10-14-2010, 07:37 AM   #38
Technic
My Ride: 2015 320i
Bump...
Old 10-15-2010, 07:27 AM   #39
Technic
My Ride: 2015 320i
Bump...
Old 10-15-2010, 05:59 PM   #40
Technic
My Ride: 2015 320i
Bump...
