Go Back   E46Fanatics > Tuning & Tech > Bavarian Soundwerks' Mobile Electronics Forum
Sponsored by Bavarian Soundwerks
Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 3.00 average.
Old 10-07-2010, 09:43 PM   #221
TRBOVNM
My Ride: 04 330 CI/04 Cobra
Send a message via AIM to TRBOVNM
thanks for the heads up. not too worried about it. installed enough double din units and work on cars daily. I have a buddy detailing the car monday, so if I need an extra hand, he will be there.
TRBOVNM is offline   Reply With Quote
Old 10-08-2010, 01:03 AM   #222
Honro
My Ride: M3 E46
Hi,
Ive read a number of posts online about the Dynavin Unit. Today I received mine, and attempted to install it.
However, ive come to a problem. On the side of my original unit (the Harman Kardon 7inch) it has two plugs that look like the below images;
Is there an alternate cable / adapter that I can buy or do I need the 5M Fakra harness? This is the harness that I received with my unit which obviously doesn't fit;
Please Help!
Thankyou all!
Honro is offline   Reply With Quote
Old 10-08-2010, 01:47 AM   #223
ZZen330
My Ride: 2002 330Ci
Honro -wow, it appears that those are the telephone type wiring and they go directly into the headunit. What headunit exactly to you have? Pics of the front? What manufacturer and model number of that headunit? I don't think North America ever got that unit.
ZZen330 is offline   Reply With Quote
Old 10-08-2010, 02:18 AM   #224
Quenotte
My Ride: E46
Originally Posted by jeffb325@DynavinSolutions View Post
I hear you....I will pass it on.
Thank you Jeff!
Quenotte is offline   Reply With Quote
Old 10-08-2010, 09:03 AM   #225
Str8down
My Ride: E46 M3
Honro,
Yes if you have factory NAV, you need the Fakra 5m harness. With the Fakra, you will not use your factory plugs in that pic, nor will you use that harness that came with the Dynavin.
Str8down is offline   Reply With Quote
Old 10-08-2010, 09:07 AM   #226
WRX2BIMA
My Ride: 04 M3, 02 330XI
so is the dynavin overall easier to install than say a alpine double din?
My Cars:
-2005 Range Rover
-2004 M3 Modded Heavy
WRX2BIMA is offline   Reply With Quote
Old 10-08-2010, 09:14 AM   #227
TRBOVNM
yes. the dynavin would be easier than any double din. the problem is the AC controls and ducting. for a double din unit you have to cut into the factory ducting and do some minor fabrication to fit the unit.
i think dynavin has a side view pic on their site and there is probably one on here somewhere as well. it is basically a single din like factory, but has the double din face. so it is almost just a drop in unit aside from your typical wiring for an aftermarket setup
Old 10-08-2010, 09:35 AM   #228
Honro
My Ride: M3 E46
Originally Posted by Str8down View Post
Honro,
Well as far as i know i dont have the factory NAV - if i do, there is no option to use it...
All i have is the factory double DIN head deck that came with the vehicle.
Jezz i hope that makes sense. Im assuming the Fakra runs from somewhere in the boot/trunk to the head deck, if so, where in the boot can i look for the amp?
Sorry for the newbie questions, just wanna be 100% sure.
Ty!!
Old 10-08-2010, 09:42 AM   #229
Str8down
My Ride: E46 M3
Oh, I have never seen that head unit, from the side, it looks like factory NAV. Anyway, probably the same issue though, since you don't have connectors to hook the Dynavin to stock wiring. The Amp is in the trunk on the drivers side. You have to remove that carpeting/panel. Once you do, see if the amp has a big square block connector that would accept "flat" pins. If so, then the Fakra 5M would probably be what you need.
Old 10-08-2010, 10:16 AM   #230
immigrant
My Ride: 2001 BMW 330CI
Send a message via MSN to immigrant
Hey guys. Can someone help me run igo 8.3 in 800_480? Or better yet run IGo Primo on that same resolution? I am good with computers, but i dont know where to find the appropriate files.
immigrant is offline   Reply With Quote
Old 10-08-2010, 10:48 AM   #231
TRBOVNM
immigrant,
search the other dynavin thread by jeff. darkoz had a lot of info in there
Old 10-08-2010, 11:03 AM   #232
will answer your questions
jeffb325@DynavinSolutions's Avatar
My Ride: BMW
Ty!!
Well.....thats not a newbie question as I dont think any of us have seen that head unit before! Looks the same as our Nav setup here in the US however, so following the above advice, take a look in the trunk and see what the plug looks like back there, you will likely need the fakra cable. Maybe take a pic and post it here for us.
by the way, I tried to return your email and it bounced back??
jeffb325@DynavinSolutions is online now   Reply With Quote
Old 10-08-2010, 12:39 PM   #233
WRX2BIMA
so i didnt find all the info i needed.. im gonna run quite a nice setup.. including JL Amp and JL Subs.. is there subwoofer control with this unit? i know there is a subwoofer output, but is their individual control over the sub level?
Honro - i dont appreciate you flicking us off (giving us the bird) in that picture haha.. kiding
My Cars:
-2005 Range Rover
Old 10-08-2010, 12:51 PM   #234
laureynsr
My Ride: 2005 330i ZHP
Hi Honro,
That looks just like the 16:9 7" BMW Navigation display. I just removed mine about a month ago. If it does not function either the CPU-DVD is dead or you have nonavigation DVD in the CPU (should be in trunk/boot). In any case, you will most likely need the 5m_Fakra cable. You can order it from here: http://www.cardvdkit.com/index.php?m...roducts_id=156.
You will also need a 15m antenna extension cable like this: http://www.amazon.com/Metra-44-EC204.../ref=pd_cp_e_3.
You have any questions, let me know.
Ray
2005 330i ZHP Imola Red Steptronic
Engine: K&N CAI, K&N Oil filter.
Interior: Carbon Fiber over aluminium pedals
Lights: Bi Xeonon, clear corners, clear sides
ICE: Dyanvin DVN-E46 v5, w/HK 12 speaker, Infinity Baselink and Proclip 5v iPhone mount.
"Imagination is more important than knowledge, for knowledge is limited while imagination embraces the entire world." Albert Einstein
laureynsr is offline   Reply With Quote
Old 10-08-2010, 12:54 PM   #235
My Ride: BMW
I have them in stock now..... and the antenna extensions are now included.
Hey Ray....your sig says Dynavin V4.....dont you have a V5
Old 10-08-2010, 12:58 PM   #236
My Ride: BMW
No the sub RCA out is a non fading non adjustable output. I have mine hooked to a sub control knob.
Old 10-08-2010, 01:22 PM   #237
BrutaL
My Ride: E46
it only takes 3 hands.....
Did mine with 1.5 hands.
BrutaL is offline   Reply With Quote
Old 10-08-2010, 04:15 PM   #238
immigrant
Hey Darkoz give me a hand man. I got primo all running with 800X460 Resolution however when i load the maps and try to start it it says outdated maps please contact dealer and then quits. I am using the maps from the Igo software that came with dynavin.
Old 10-08-2010, 04:16 PM   #239
Str8down
My Ride: E46 M3
Jeff,
Got mine installed today, only took about 2hrs including running the fakra, which was the hardest part. I am loving it but have 2 issues, 1 major, 1 minor.
The major one is, I bought this unit to stream slacker via Bluetooth, which works great, but if you switch to navi while using Bluetooth, it switches to radio. That is totally unacceptable.
The minor thing is the clock, it displays in G.I. Joe time. Is there any way to switch to 12 hour clock?
Old 10-08-2010, 04:27 PM   #240
My Ride: BMW
haha...GI Joe time.....nope sorry, I dont know why but for some reason the V5 is 24 hour only, ill ask dynavin if that is something that is set in stone....
I asked Dynavin about the bluetooth/Nav deal and basically I have bad news for you....its a hardware limitation, the bluetooth overrides all other functions (which makes sense, it is a phone system after all). But because of this you cant leave the bluetooth streaming function and have it continue to operate and thats exactly what going to Nav does...I realize that the other audio functions operate while in nav mode but they are running off a different piece of hardware and dont have the override function of the bluetooth. In the couple times where I have been in a situation where I need to use the nav and I want to continue to "stream" I just plug into the aux in or the ipod plug for a hard connection....not perfect but its a lot better that no streaming and no aux in on the factory system!
Just looked back at your order....no aux in plug....what kind of phone are you streaming from...
Rate This Thread
