Go Back   E46Fanatics > Tuning & Tech > Bavarian Soundwerks' Mobile Electronics Forum
Sponsored by Bavarian Soundwerks
Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 3.00 average.
Old 12-29-2010, 04:34 PM   #1141
jeffb325@DynavinSolutions
will answer your questions
jeffb325@DynavinSolutions's Avatar
My Ride: BMW
good to hear James, thanks
jeffb325@DynavinSolutions is online now   Reply With Quote
Old 12-30-2010, 11:24 AM   #1142
ketchup
My Ride: E46 M3
Received my replacement unit last night and installed it. Took care of my Bluetooth issue, thanks Jeff!
BT streaming works great from my palm pre but skips (every 40 seconds) for some reason when streaming from my iPad. However I am able to hook up the iPad directly to the dock cable and utilize it in iPod mode. When in iPod mode with the iPad, steering, touch, and remote functions do not work - you just simply use the iPad.
I'll keep you guys posted if I solve the skipping issue via BT iPad. Maybe if I update to IOS4. Not sure if the October firmware update (BMW logo screen) for the dynavin has anything new for the Bluetooth.
ketchup is offline   Reply With Quote
Old 12-30-2010, 11:43 AM   #1143
ketchup
My Ride: E46 M3
Originally Posted by zhp43867 View Post
Also, can you click on the on screen menu? So can you click on playlist directly, or do you have to use the arrows and the ok button?
I actually prefer using the touch screen for that. The long press on the steering function takes too long IMO and if you don't hold it down long enough you have to do it again. The only thing I use on the steering wheel is the R/T for return.
With the touchscreen, it's simply a quick touch. Touch playlist then touch the playlist you want then touch the song to play
Here's a video clip:
Old 12-30-2010, 12:38 PM   #1144
My Ride: BMW
yes, if you are just selecting a playlist what ketchup describes is very easy. Touch the screen for selections and use the RT button to go back. you only need to bring up the pop up menu (or use the remote) if you need to page forward...
Old 12-31-2010, 09:19 AM   #1145
thejames
My Ride: e46 330ci Coupe Auto
Just an addendum to the bits I mentioned above. Strongly recommend people give nDrive a go if they can get their hands on it. Looks fairly basic but it's really quick (much higher framerate than iGO), the instructions are clear, and best of all, there's full postcode input - something I've not found on any of the others.
A minimise option would be helpful though, on the off chance someone knows how to add it...
thejames is offline   Reply With Quote
Old 12-31-2010, 04:59 PM   #1146
newspec
My Ride: Mspec 325i 2001
I have tried ndrive version 10 on mine and although yes it is quicker frame rate wise i went back to primo with gurjon skin as for me anyway it has so many more features and looks and works better.
newspec is offline   Reply With Quote
Old 12-31-2010, 07:24 PM   #1147
omhl
My Ride: E46 M3 6MT
Send a message via AIM to omhl
in stock for pickup sunday?
I will be heading down to socal from the bay. Could I pick it up?
2002 BMW E46 ///M3 6MT
GruppeM Rep Muffler w/ 2 AR20 | 6K LED Angel Eyes w/Rheostats | DICE | OEM SSK | CF CSL Diffuser | 18x10" ET25 Enkei NT03+M | Drilled/Slotted Rotors| Yellow DPS Coilovers| SR48 Titanium Lugs | Air Scoop | Schroth 4 Point Harness | CSL Trunk |
omhl is offline   Reply With Quote
Old 12-31-2010, 09:22 PM   #1148
My Ride: BMW
Nope, all of my current inventory is spoken for but i have more coming this week.
Old 01-01-2011, 06:01 PM   #1149
piers
My Ride: 2004 M3
hey jeff, installed the v5 unit and everything went OK except... that the supplied line output converter does not work for front RH speaker... the speaker stopped outputing all sound. Removed the LOC and the speaker was fine again. Put the LOC back in line to double check and the RHF speaker again stopped working. I opened the LOC up and there was a loose solder joint on the solid grey wire where it connects to the board. are you able to provide a replacement under warranty?
thanks,
piers.
piers is offline   Reply With Quote
Old 01-01-2011, 06:23 PM   #1150
My Ride: BMW
yeah, thats no problem, just send me an email and the address where you would like it mailed so I can set it up.
If you want to save yourself some trouble and get your car back up and running sooner just steal the LOC from the rear speakers and use it on the front, then just use the fader to balance the front to rear sound. The LOCs are really only needed on the front. Then when you get the replacement LOC you can replace it at your leisure. (or not at all)
Old 01-01-2011, 06:37 PM   #1151
piers
My Ride: 2004 M3
awesome, thanks jeff.
Old 01-02-2011, 09:06 AM   #1152
ZACZ
My Ride: 2004 M3 E46
hi all
Just a quick question re. Dynavin......
Does the BLUETOOTH functionality link/work with the factory buttons that are in the car already?
ZACZ is offline   Reply With Quote
Old 01-02-2011, 08:25 PM   #1153
toddkageals
My Ride: 2002 M3 SMG/VERT
Guys,
I have A v5 and am running igo primo. I have an issue with the NAV volume. The NAV volume appears to be linked to the radio volume. Works fine if you have the radio up fairly loud. My issue is that I frequently have my wife and kids in the car and have the radio on at pretty low volume so that we can still talk to each other. At that level, the NAV can only barely be heard. I believe that I have the NAV. Volume settings at max but the radio volume control still turns the NAV down when the radio is turned down. Anyway to control the NAV. Volume independent from the radio volume?
Thanks for the help.
Todd
toddkageals is offline   Reply With Quote
Old 01-03-2011, 02:55 PM   #1154
2000_328CI
DK Jack Sparrow
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
Send a message via AIM to 2000_328CI Send a message via MSN to 2000_328CI
Anyone in need of the latest wolf, iGo8.3, and iGo Primo on a preformatted SD card, just shoot me a PM. Have almost sent out 4 dozen now and had nothing but great feedback
Everything you need to know on muffler deletes : http://forum.e46fanatics.com/showthread.php?t=745244
Back Up Camera for E46 : http://www.youtube.com/watch?feature...&v=ckrDiAClGgM
Muffler Delete on E46 : https://www.youtube.com/watch?v=ofYhRq0T3eI
Old 01-03-2011, 03:14 PM   #1155
Flybot
My Ride: E39 528
Originally Posted by toddkageals View Post
Guys,
Todd
Check the balance and fader controls on the radio side. They cut off rapidly and I find it best to have a neutral setting for both nav and BT volume.
Flybot is offline   Reply With Quote
Old 01-03-2011, 05:51 PM   #1156
thejames
Todd, check the primo thread. There's a small section you can add to your sys.txt that boosts the Nav volume.
Old 01-04-2011, 09:17 PM   #1157
My Ride: BMW
Originally Posted by ZACZ View Post
hi all
Yes
Old 01-04-2011, 11:51 PM   #1158
Darkoz
My Ride: E46 325Ci
Just a reminder for those looking to get or who have recently received their Dynavin, there is a Dynavin FAQ thread that Jeff has put together, chances are your question will be answered there.....
(^^And don't forget to also check out the other two links in Jeff's sig ^^)
http://forum.e46fanatics.com/showthread.php?t=803437
Darkoz is offline   Reply With Quote
Old 01-05-2011, 12:02 AM   #1159
ZACZ
Originally Posted by jeffb325@DynavinSolutions View Post
Yes
excellent - thanks Jeff!
Old 01-05-2011, 12:04 AM   #1160
DANe46
My Ride: 2004 BMW 325i E46
Has anyone figured out how to automatically power off the ipod when the Dynavin turns off? I am using the video cable with TVout and USB charging through AUX. I was just wondering if there is a workaround or even an app that will power the ipod off when not in use or it loses power from the USB
DANe46 is offline   Reply With Quote
Rate This Thread
