Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 403 votes, 4.99 average.
Old 05-04-2011, 04:23 AM   #1701
bmw927
My Ride: N/A
Does the Dynavin unit plug into the car GPS receiver, or does it come with a receiver where you plug in and place it in the metal dash frame specified in the first page of this thread.
Thanks.
bmw927 is offline   Reply With Quote
Old 05-04-2011, 07:06 AM   #1702
aar0n_91
My Ride: 04 BMW325CI///MSport
what is the dynavin's pre out voltage???im tuning my aftermarket system and id like to know what voltage it is so i can set my gains accordingly
BMW 325 CI ///M-SPORT INDIVIDUAL
aar0n_91 is offline   Reply With Quote
Old 05-04-2011, 07:42 PM   #1703
alexbenz
My Ride: E30, Es300
Send a message via AIM to alexbenz
also does anyone know if somehow we can run google maps on the dynavin? that would be sweet...i was using it on my phone in my other car today and thought it would be cool if we can...
also can we hook up a ps2 to the dynavin as well?
W210-----SOLD, e39--Sold, e30---sold
E39----------Present
www.europrojektz.com
Current line up........lexus es300, 2010 Acura Tsx
Your not a baller until you got a engine in the Rear...
How did i fail Women Studies?
"I Love Biatches"
alexbenz is offline   Reply With Quote
Old 05-05-2011, 06:20 PM   #1704
masterj981
My Ride: toyota tacoma
jeff, i have the smaller green one so its for the newer e46's and no radio channels. The radio worked fined before hand with my old alpine that was it there
masterj981 is offline   Reply With Quote
Old 05-05-2011, 06:23 PM   #1705
jeffb325@NavigationSolutions
J&T Distributing
My Ride: BMW
although you are using the new style adapter......the tricky part is that the old radios had BOTH plugs on them, one big and one small....the new style radios only have the small plug. So the question is did you use the wrong antenna plug? Perhaps you could send me a pic of the back of your sock stereo so I could see which plugs it has....
Better to reach me by email by the way....to easy for questions here to get buried...
jeffb325@NavigationSolutions is offline   Reply With Quote
Old 05-05-2011, 08:53 PM   #1706
TitanSilverE46
My Ride: 2001 318i & 325i
Fitted Dynavin V5 unit today and have a couple of problems with the radio.
First I am running at Vol 4-5 with a lot of background noise. Threads from Jeff say I need LOCs. I noticed they were not in the box when I bought it but when my supplier (Jason at Euro Division in Melbourne, Australia) asked Dynavin they said I would not need them
Next problem:- when I search for stations I get a lot of 'hits' that are not stations as such and the 3 FM bands are full and we have only covered half the spectrum. Is there a way to manually load/save stations, or delete the crap ones?
TitanSilverE46 is offline   Reply With Quote
Old 05-05-2011, 09:06 PM   #1707
J&T Distributing
My Ride: BMW
There is a new firmware that has an option to reduce the headunit output to better match the OEM amps in cars so equipped. Contact Jason for this firmware and instructions on how to install and use it.
For the radio, just use the arrows to select the station and then press and hold next to the preset number to save it.
Old 05-05-2011, 11:17 PM   #1708
TitanSilverE46
OK, Jason emailed Dynavin and they sent a new zh_mcu.bin file of 98304 bytes.
From another thread I believe I need to install as follows:-
2. Connect a USB memory stick to your PC, delete everything from USB memory stick and make sure it's formatted in FAT or FAT32.
3. Put the zh_mcu.bin file in root of USB memory stick.
4. Turn off Dynavin and connect the USB memory stick to DVD-USB cable on your Dynavin.
5. Dynavin should turn on and update should start automatically, now just wait until the system turns off (should take about one minute).
The only instructions from Dynavin via Jason were:-
((After reload the mcu,
Long press "9" on IR remote in AUX mode
choose AMP to "YES"))
Does this make sense?
Haven't tried yet but will do shortly.
Cheers
Old 05-06-2011, 02:35 AM   #1710
TitanSilverE46
OK, relating to the saving of radio stations, yes that works fine. It is such a pity that the manual is not more helpful.
Regarding the update to reduce the headunit volume, not so helpful.
I followed the directions which were fine, but no effect on volume. I then thought I might try the Oct 2010 files to change the splash screen to BMW as well. So I did this update which 'took' (I do like the BMW screen) but still no change in Radio volume. Finally I uploaded the zh_mcu.bin that I got from Jason again. Still no change in radio volume.
I am wondering if I truly have the latest version
Jeff, could you check the size of the latest ... the one I have is 98,304 bytes.
I am suspecting I might have been sent an older version.
Now having spent most of the day with the door open, angel eyes on, testing this and testing that ... battery flat! So charger is connected for an hour or two! Probably lose all my radio station settings and GPS routes I have set up! Oh well, SWMBO is really happy as the Bluetooth is working well which was how I managed to convince her she needed the Dynavin for safely using her mobile phone 'handsfree'. Also my gift to her for this Sunday, Mother's Day here in Oz!!!
Old 05-06-2011, 08:02 AM   #1711
J&T Distributing
My Ride: BMW
Did you change the amp setting in the factory settings menu? Just installing the firmare wont do it, you have to change the amp setting as well.
Old 05-06-2011, 08:59 AM   #1712
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
Send out another two 4 gig SD cards today pre-loaded with iGo8.3, iGoPrimo, and Wolf. If you would like a pre formatted card that is plug and play and will update your navigation system, just shoot me a pm
Timeless Motor Group
Old 05-06-2011, 09:01 AM   #1713
DropTopKingM3
My Ride: All German
I got mine Just plugged my unit in for testing but I have an 01 nav setup so I had to put it in the trunk.. Oh boy this is gonna be a FUN day !!! I got a c43 connector in my trunk so Im gonna have to start splicing soon.
..George..
..Is now Alpine White/Cinnamon...
^Don't say my car is topless, say the t!tties is out^
DropTopKingM3 is offline   Reply With Quote
Old 05-06-2011, 01:17 PM   #1714
fadeaway
My Ride: 04 330Ci
Jeff, I hope you don't mind me answering this one.
When you're in that secret menu using long press 9, change the "AMP" from (I think) "Yes" to "No" or the other way around. That will bump up or down the volume from the head unit pre-amp. This is not the most intuitive setting, but this is how it works. You will most likely still get some hissing in the speakers at 0 volume, but at least the gain linearity is adjusted.
fadeaway is offline   Reply With Quote
Old 05-06-2011, 01:51 PM   #1715
J&T Distributing
My Ride: BMW
Old 05-06-2011, 05:12 PM   #1716
TitanSilverE46
Yes, I followed the directions given me to use the IR remote, go into AUX and hold down "9" to go into the service? menu. At the bottom was "AMP" which I changed from "No" to "Yes".
Will do a drive around and see how it feels. At rest 4-5 is quite loud enough - maybe when driving a suitable higher level will be needed.
As "fadeaway" says, it could be from "Yes" to "No" so I will try both.
Cheers to all.
Old 05-07-2011, 07:21 AM   #1717
ecchimo
My Ride: United Kingdom
Ordered a new batch of SD cards so feel free to PM me with requests. Have sent out maybe 75-80 of these at this point. All happy users
SD cards I send include Primo, 8.3, Wolf and all the needed preformatting (and ideal BMW settings such as load up screen) and is plug and play
Sounds great but is there anyone in the uk doing it? Or how much for one shipped to the uk?
ecchimo is offline   Reply With Quote
Old 05-07-2011, 01:53 PM   #1718
rbu_tuninq
My Ride: e46
Cheers to all.
i don't have this setting AMP...i have RDS on/off FM 150 AM 100 dvbt on/off and something else but no AMP.....i have de v5 version dynavin...help please
rbu_tuninq is offline   Reply With Quote
Old 05-07-2011, 04:02 PM   #1719
6spd_legend
My Ride: acura legend 6spd
So I'm trying to upgrade to iGO8.3 and I keep getting the following message: "Failed to load ui_igo8/800_480/loading.bmp" "Application will now exit" I've very computer literate and this is driving me absolutely crazy. I've obviously replaced the appropriate .bmp files in both branding.zip and data.zip, I'm thinking something is not right in my sys.txt configuration. Could somebody who is running 8.3 show me what their sys.txt looks like? Any help would be GREATLY appreciated, thanks.
I tried deleting the contents of SAVE folder also, same thing happens.
Clip from my sys.txt (I have a folder named iGO8 on the root of my SD card, all the stuff is in there):
[project]
name="tw_pna"
[folders]
app="StorageCard/iGO8"
[interface]
skin="ui_igo8"
laneinfo_signpost_enabeled=1
maxzoom2d=6900000
show_exit=1
show_tmc_eventlist=1
resolution_dir="800_480"
show_zoombar=1
shutdown_time=0
exit_on_restart=0
[rawdisplay]
screen_x=800
screen_y=480
Vga=1
highres=0
class="landscape"
driver="GX"
rawdisplay=GX
gx_force_using_dll=1
2001 LSB M3 Coupe
6spd_legend is offline   Reply With Quote
Old 05-07-2011, 04:23 PM   #1720
rbu_tuninq
My Ride: e46
if this help you....this is my original sd igo sys
[folders]
app="%SDCARD%/"
[interface]
skin="ui_igo8"
vga=0
[rawdisplay]
class="landscape"
screen_x=800
screen_y=480
highres=0
[map]
auto_nightmode=0
[msnd]
enabled=0
msnd.start=0
[sound]
ding=0
[debug]
skip_eula=1
enable_roadshadow=1
reserve_memory=1835008
cache=262144
[smartzoom]
minzoom=20
maxzoom=50
[utility]
utilitymov=",1,\%SDCARD%\IGO8,"
utilitydel=",2,\%SDCARD%\iGO8,"
[roundaboutcam]
enabled=0 ;(1)
centery=20 ;(50)
[scheme]
disable_themechanger=0
dawn_scheme="aurora"
twilight_scheme="crepuscolo"
checkscriptpath=""\STORAGECARD\checkTC.mscr""
[3d]
show_guidance_arrows=1
Rate This Thread
