Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 403 votes, 4.99 average.
Old 05-07-2011, 08:27 PM   #1721
Deltaboy
My Ride: E46 330Ci Sport
V5 Droid
Hi all.
Have been in the shadows for some time, so I'd just like to say hi, I have a 330ci and am awaiting the arival of my v5 Dynavin, should have been delivered today but... mailman sucks. I have been sooooo excited but alas I saw one thread entitled Dynavin Android and its all gone south.
Has anyone else just purchased a v5 WinCe only to find its gonna outta date real quick because the v5 Android is out, short changed I think so!!!!
D
Deltaboy is offline   Reply With Quote
Old 05-07-2011, 09:40 PM   #1722
jeffb325@NavigationSolutions
J&T Distributing
My Ride: BMW
well....the android unit is a totally different thing....it needs to be tethered for much of it to function. It is only what you make out of it so you need to be somewhat technically savvy to make the most of it.
The windows unit is much more conventional, plug it in, set some basic settings, and use it.
So while the android unit is a really cool addition to Dynavin's offerings and is fantastic for some of us, if you want a conventional CD/DVD/Bluetooth/ipod/Navigation system, the windows unit is still probably a better choice.
jeffb325@NavigationSolutions is offline   Reply With Quote
Old 05-07-2011, 09:53 PM   #1723
Darkoz
My Ride: E46 325Ci
Originally Posted by 6spd_legend View Post
So I'm trying to upgrade to iGO8.3 and I keep getting the following message: "Failed to load ui_igo8/800_480/loading.bmp" "Application will now exit" I've very computer literate and this is driving me absolutely crazy. I've obviously replaced the appropriate .bmp files in both branding.zip and data.zip, I'm thinking something is not right in my sys.txt configuration. Could somebody who is running 8.3 show me what their sys.txt looks like? Any help would be GREATLY appreciated, thanks.
I tried deleting the contents of SAVE folder also, same thing happens.............
I think you'd be better off with iGO Primo, better functionality and easier to use.
Download link here, scroll down to post #424..........
http://forum.e46fanatics.com/showthr...797457&page=15
Darkoz is offline   Reply With Quote
Old 05-08-2011, 09:25 PM   #1724
TitanSilverE46
My Ride: 2001 318i & 325i
Interesting problem:-
My Dynavin was failing to respond to touchscreen commands ... switched off/on several times ... even got to the stage of pressing the reset pin in desperation (losing all my preset Radio channels of course ) and then I realised I had just fitted one of the anti-glare plastic strips that came with my unit. (BTW I had to cut 1mm from side and top so it would sit flat against the screen.)
So .... removed anti-glare screen and all touchscreen commands work again.
Anyone else noticed this?
TitanSilverE46 is offline   Reply With Quote
Old 05-09-2011, 12:08 AM   #1725
tesko.pk
My Ride: 2003 530i
Yee, had the same thing happen to me this weekend when I installed my V5A. I can live without the anti-glare plastic
tesko.pk is offline   Reply With Quote
Old 05-09-2011, 12:23 AM   #1726
Darkoz
My Ride: E46 325Ci
Has been known and discussed quite a few times......
Originally Posted by jeffb325@DynavinSolutions View Post
typically when there are problems, they are the same over and over, and ive seen this screen protector one dozens of times, Ive not yet seen a touch screen fail. If he takes off the screen protector it will work fine.
Old 05-09-2011, 01:46 PM   #1727
BrutaL
My Ride: E46
Clip from my sys.txt (I have a folder named iGO8 on the root of my SD card, all the stuff is in there):
[project]
name="tw_pna"
[folders]
app="StorageCard/iGO8"
[interface]
skin="ui_igo8"
laneinfo_signpost_enabeled=1
maxzoom2d=6900000
show_exit=1
show_tmc_eventlist=1
resolution_dir="800_480"
show_zoombar=1
shutdown_time=0
exit_on_restart=0
[rawdisplay]
screen_x=800
screen_y=480
Vga=1
highres=0
class="landscape"
driver="GX"
rawdisplay=GX
gx_force_using_dll=1
1. typo?
fyi: im running primo 2.1 now. consider switching to primo.
BrutaL is offline   Reply With Quote
Old 05-10-2011, 03:48 AM   #1728
TitanSilverE46
Yes, I followed the directions given me to use the IR remote, go into AUX and hold down "9" to go into the service? menu. At the bottom was "AMP" which I changed from "No" to "Yes".
Will do a drive around and see how it feels. At rest 4-5 is quite loud enough - maybe when driving a suitable higher level will be needed.
As "fadeaway" says, it could be from "Yes" to "No" so I will try both.
Cheers to all.
Tried both "Yes" and "No". On "Yes" a volume of 10 was equivalent to about 5 on "No" so there is definitely a drop in output as required.
Next newbie question
The manual shows a "Phone Book OSD" which I don't seem to be able to find. Bluetooth has paired up correctly and we can make and receive calls using the keypad and steering wheel button to answer ... but can't find where to store the numbers/contact list?
Anyone, please?
Old 05-10-2011, 04:49 AM   #1729
Darkoz
My Ride: E46 325Ci
...........Next newbie question
Anyone, please?
Unfortunately no contact list on the screen with the Dynavin, a simple feature that has been ignored.
Old 05-10-2011, 05:35 AM   #1730
TitanSilverE46
Hmmmm! I wonder why the Dynavin User Manual on Page 15 has:-
Phone Book OSD:
(Picture of this screen)
This function can record the numbers you called, received call and missed call.
Interface Keys:
1. touch "CALLING" key lightly to check the calling numbers.
2. touch "RECEIVING" key lightly to check the received call.
3. touch "QUESTION" key lightly to check the missed all.
4. touch "RETURN" key lightly to return to the main menu.
5. touch "UP" key lightly to return the last catalogue.
Old 05-10-2011, 06:29 AM   #1731
Darkoz
My Ride: E46 325Ci
Phone Book OSD:
Interface Keys:
It'll only show the missed and called numbers only but it won't display the contact name and even then it's not that good as most times the unit will lock up if you try and scroll through the numbers list.
What I'm talking about is that it will not display your phone's contact list on the screen, so unless you know the number from memory you still have to use your phone to make a call.
Old 05-10-2011, 07:35 AM   #1732
Deltaboy
Difficult install and no backlight buttons
Hi all.
Just add some feedback re my recent install, had the day off all keyed up to crack on, removed old stereo, all fine, went to the boot and started to remove the old CD changer and radio unit then ran into a problem...
On the images of the DIY it shows a connector that is completely different to the one I had, image shows large boxy connector with flat pins, I have smaller connector with round pins.
In my Dynavin box I received three main cables the Fakra 5M cable with the flat pins, a small loom with flat pins for if you have the business unit and a small loom for business unit with round pins.
Contacted my supplier and they replied back to say I need to cut and shut the cables matching the colours for it to work, so much for plug and play!!! one trip to the Auto electrician I had one Fakra Loom out of two and it works but be aware in a small number of cases some E46's have round pin connectors...
Spliced the Red and Orange Fakra cables to get backlit buttons but is there anyway to make them dim with the dash lights..
All help appreciated.
Old 05-12-2011, 12:09 PM   #1733
Screamin
My Ride: 330ci
(I do like the BMW screen)
How do I upload(?) / get a BMW logo at start up?
Screamin is offline   Reply With Quote
Old 05-12-2011, 10:28 PM   #1734
currenssy
My Ride: 2001 BMW 330CI
I really hope someones still on here! I got OEM NAV so i have the fakra cable, but the female end to it in the trunk looks like the female end in this unit in the dash using rounder pegs to fit in. Is this something abnormal? My Fakra looks like the one in the DIY below for factory NAV but the female end looks different! I really need help on how to rectify this! Thanks.
Last edited by currenssy; 05-21-2011 at 03:24 PM. Reason: Sorry about quoting the original post. Thought i deleted that out and i havent been on here since so i didnt get to delete
currenssy is offline   Reply With Quote
Old 05-12-2011, 10:31 PM   #1735
J&T Distributing
My Ride: BMW
Some cars have the round pin connector in the trunk, in these cases you need to cut then end off the Fakra cable and splice on the round pin connector from the "other" harness that came with your unit. No big deal, look at them and figure it out in advance, it will make sense if you lay the cables side by side and understand what each wire does.
By the way....you probably shouldn't quote a post of that size.....
Old 05-12-2011, 10:36 PM   #1736
Darkoz
My Ride: E46 325Ci
Jeez man, no need to quote a million pics.
Old 05-12-2011, 10:50 PM   #1737
Jall
My Ride: 328Ci
Like Jeff said, its a splice job. You'll Also need to splice the Orange Dynavin wire into the red/grey wire found in the blue connector behind the headunit for illumination.
Sent from my HTC Desire using Bimmer App
Jall is offline   Reply With Quote
Old 05-13-2011, 12:17 PM   #1738
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
For those looking to upgrade to Primo, iGo8.3, and Wolf, shoot me a PM
Timeless Motor Group
Old 05-13-2011, 04:55 PM   #1739
opey
My Ride: 04 M3 coupe
WHYY would you quote that whole huge post???
IR/IR 6 speed
opey is offline   Reply With Quote
Old 05-13-2011, 08:50 PM   #1740
Darkoz
My Ride: E46 325Ci
Yes, currenssy would you mind deleting that huge quote please.
Rate This Thread
