Old 09-23-2010, 11:52 AM   #1
Sir Smirnoff
My Ride: 2002 330i
Difference between s54 and m54
I know it's somewhat comparing apples to oranges, but how the hell did BMW get an extra 105HP out of an additional .2L of displacement????
The difference between an m52b28 and an m54b30 is 25 HP @ the crank.
How did BMW get the extra 80? I understand that there are different camshafts, ITB's and a more aggressive tune, but that cannot make 80HP! People here change out the camshaft and tune all the time. They usually get only 15HP out of that. So now there is 65HP that is unaccounted for, or at least around there. I can't think of anything that could give you that large a jump in horsepower except boost! Can anyone explain this to me since, as far as I can see, ITB's make a lot more power. But if ITB's made even 45HP, I bet a lot more people would be doing it....
Sir Smirnoff is offline   Reply With Quote
Old 09-23-2010, 01:08 PM   #2
McSpeed
My Ride: 2005 ZHP TT Stg 1
I think the ITBs are part of what allows the S54 to rev to 8000.
It's easy to make a lot of HP revving to 8000.
The M54 only revs to 6500.
The S54 is also a 3.2 liter iron block with very strong internals vs the M54's 3.0 liter Al-Sil block.
S54 compression ratio: 11.5:1
M54 Compression ratio: 10.2:1
Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife
ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch
Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs
Turbo Driveability Video
Horsepower vs. Torque - updated
McSpeed is offline   Reply With Quote
Old 09-23-2010, 01:16 PM   #3
invictus
My Ride: M3, 749R, SV650
m faeries
CCW. Dunlop. Ground Control. StopTech. Hawk. Vorschlag. Rogue Engineering. Recaro. TCDesign. RaceTech. VAC. Motul. Vorsteiner.
Find me on track: 10/19-21 Sonoma Speedway // 11/10-11 Thunderhill
The story so far...
Fund my track car:
PM me about my: stock diffuser, stock trunk
WTB 1x Dunlop Direzza Z1 Star Spec 265/35/18 (used is okay)
invictus is offline   Reply With Quote
Old 09-23-2010, 01:52 PM   #4
xixixi
Banned User
My Ride: 01 330x-xi
I'd also assume stiffer valve springs better head. IMO it's all from the top of the motor/CR the ITB's help too!
Old 09-23-2010, 01:57 PM   #5
xixixi
Banned User
My Ride: 01 330x-xi
repost..
Old 09-23-2010, 02:02 PM   #6
MP325
My Ride: 2004 325xi
Originally Posted by invictus View Post
m faeries
lol
MP325 is offline   Reply With Quote
Old 09-23-2010, 02:09 PM   #7
mrshelley
My Ride: 2004 330i
99% of everything is different from the front subframe up to the hood and from the radiator to the bell housing.
Old 09-25-2010, 10:03 PM   #8
lejeunebimmer
My Ride: 02' M3 SMG, 02' 330i
Ok,
I will give this as best a shot as I can.
-M54B30 has an Alu-sil block with the crank and bearings out of an S52 (I don't know if it's the B30 or B32 kind).
-S54B32 has a grey cast-iron block, with a much improved design of the crank and rotational assembly out of the S52.
-M54B30 has 10.2:1 compression
-S54B32 has 11.5:1 compression (here is a big part of the power!!!)
-M54B30 has hydraulic lifters (will most likely collapse in on its self @ ~7500rpm)
-S54B32 has solid rockers (partially enabling the 8k redline)
-S54B32 has more aggressive cams (more power)
-S54B32 has ITB (more power)
-S54B32 is more aggressivley tuned (more power)
-S54B32 has more freely flowing intakes and exhausts (more power)
Summary:
Take an M54B30 bore it to .30" over, throw in some forged connecting rods, and 12:1 compression pistons from Sunbelt, shave port&polish the head, install 1mm oversized valves, heavy duty valve springs, schrick cams, use the intake manifold from a WTCC (do they even have these that could fit?), bore out the throttlebody, throw on a quality set of stepped headers, to a free flowing 2.5" or 2.75" exhaust, maybe use an intake like the dinan CAI (either one), eliminate the A/C, underdrive the waterpump (race one now), underdrive the powersteering, underdrive the alternator, custom tuned or even designed Engine Management software, light weight (like 8.5lbs) flywheel, drysump oiling system, improved vibration dampner (crank pulley), so that you can actually safely rev to like 7500k (maybe remember you still have hyraulic lifters...).
You will have sunk 25k+ into it to make a racing engine that MIGHT make 350hp if you're lucky.... So you see, you could make the power applying the same measeures to the M54B30, but it would most likely have to be taken to extremes, and be overly pricey....
330i - AA Tuned, Headers, UUC Stage I LW FW, e36 M3 Clutch, UUC SS Clutch line, BMW Performance Intake, Evo Sport Pulleys, BMW Performance Cross-Drilled Rotors, Hawk HPS, BW SS Brake Lines, BW Solid Guide Bushings, BMW Performance CF Strut Brace, H&R Sways, H&R Sport Springs, Bilstein Sport Shocks, Powerflex Bushings, LED Tails, Clear Sides/Turns, Black Grill, Mtech 2, CF Splitters
M3 - Not enough room to list
lejeunebimmer is offline   Reply With Quote
Old 09-27-2010, 10:58 PM   #9
Sir Smirnoff
My Ride: 2002 330i
thanks for that info. I was curious.... a big wtf went across my mind in class.... I'm glad you shot down all my hopes and dreams. allows me to focus on the important shit in life.
Old 10-20-2010, 08:47 AM   #10
Phantom Mark
My Ride: 2001 330i M-Sport TT
Always makes me stand and scratch my head when I see the M-Sport guys taking 300+ bhp out of the 2 litre N/A touring car engines lol, so your thoughts and theory were and are well justified, I guess the ol M engines really are as close to the race machines as you could expect for the road eh
Phantom Mark is offline   Reply With Quote
Old 10-20-2010, 12:51 PM   #11
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
It's in the cylinder head.
S54 Intake port = 275 CFM
M54 Intake port = 200 CFM
The rest of the stuff listed above is small potatoes. Want proof? I strapped an ITB intake onto a built M54 and lost 30rwtq and gained peak 5rwhp. Yuck!
Old 10-20-2010, 10:54 PM   #12
B6T
My Ride: 330Ci
Ding ding ding!!!
B6T is offline   Reply With Quote
Old 01-11-2013, 03:57 PM   #13
aleksankazakov
My Ride: 04 E46 330i sport
Are there are any parts fom S54-32 that can fit to M54-30?
aleksankazakov is offline   Reply With Quote
Old 01-11-2013, 04:00 PM   #14
aleksankazakov
Originally Posted by lejeunebimmer View Post
Ok,
Summary:
I dont think this will be cost effective way to put a power to M54-30. Turbo probably can make 350hp without rods, pistons, valves and all the other fancy stuff for under 5k to swap M54-30 for S54-32 will cost about the same, but what is the point when for the extra 5k you can upgrade the car to an M car
Old 01-11-2013, 04:09 PM   #15
aleksankazakov
Ok,
Summary:
Turbo is the most efficent way to make power, however the more compression you have the less success you will get. M54 can hold 6psi on the standart compression without detonation, but if you want to turbo or supercharge S54 you will need to lower the compression to avoid detonation . 11 cempression is not for turbo. Anything less than 9 will not be a problem. As for 10 on M54 I think 6psi will be the max without tearing the engine a part.
Old 01-11-2013, 04:15 PM   #16
aleksankazakov
Getting new pistons for better compression on M54 will be a good upgrade-maitnace at the miles we have on those vehicles. 150k miles on mine and it is nice to swap the pistons to ensure another 100k miles on the motor. Ofcorce you will replace all the seals and other stuff as you go, but it will be only cost efficent if you do it yourself. it means you need to work on your car for about a week every day after work to rebuild the engine. it is a big project to do , but yes it sure adds reliability and power if you put in some aftermarket racing pistons in.
Old 01-13-2013, 06:28 PM   #17
TerraPhantm
My Ride: 2005 M3 Coupe
The S54 cylinder head flows *much* better than the M54 head. The valvetrain is solid and the valves have stiffer springs. This allows it to rev to 8000 reliably. The M3 also has longer duration cams.
It's mostly the better flowing head and the high redline that allows it to make so much more power than the non-M motors.
TerraPhantm is online now   Reply With Quote
Old 01-14-2013, 08:42 AM   #18
jared_wiesner
My Ride: 1999 328i
Ya essentially three main things are taking place to make that power.
-It's stronger in many areas than the M54 allowing it to rev up to 8000 RPM safely. Given that horsepower is simply work completed as related to time, if you can keep making good torque at faster RPMs, you are making more power.
-It has the flow capability to flow enough air to make power at 8000 RPM. (higher flowing intake/heads/exhaust).
-It has a cam profile to match and make power up to 8000 RPM.
The key to making big horsepower n/a in these cars would be to rev them higher and support that with enough flow.
Check out my band - The Marked
1999 BMW 328i (Daily Driver) - m54b30 intake manifold, ebay headers, Rebirth Motorsports CAI, Rogue Engineering underive pulleys, Epic Motorsports Software, Custom 3 inch exhaust with Burns Merge, Schrick 264/248 Cams
1967 Buick Skylark - 430 Buick Big Block Swap.
jared_wiesner is offline   Reply With Quote
