Old 12-20-2010, 05:12 AM   #1
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Non-M 6 speed clutch alignment tool
Does anyone have an extra one laying around? I'll buy it.
Keep in mind that this only applies to facelift coupes and ZHP sedans that came with the 6 speed.
Be aware that these are apparently hard to find. So I'd keep yours if you only have one.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 04-23-2011, 08:44 PM   #2
genuity
My Ride: 2001 330iS
BMW part number for the tool is 83-30-0-494-280. It's about $33.
genuity is offline   Reply With Quote
Old 04-24-2011, 10:53 AM   #3
bigjae1976
bigjae1976's Avatar
Sweet, thanks!
Old 04-24-2011, 12:05 PM   #4
McSpeed
My Ride: 2005 ZHP TT Stg 1
OEM tool for $33? Sounds cool
Did you end up getting the Lisle tool? I found that it works to move the disc around but it's too loose to really use for alignment. I had to judge alignment by how the outside of the disc lined up with the pressure plate.
SOLD but fondly remembered...
Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife
ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch
Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs
Turbo Driveability Video
Horsepower vs. Torque
McSpeed is offline   Reply With Quote
Old 04-24-2011, 06:24 PM   #5
bigjae1976
bigjae1976's Avatar
Got the lisle tool but will definitely get the OEM tool.
Old 01-11-2013, 05:58 PM   #6
secono330ci
My Ride: 04' 330ci/15' A3 TDI
Bumping an old thread..
Will the oem BMW tool work with an aftermarket clutch?
Oh...and the "$300 here, $600 there" scenario will turn into "$3000 here, $6000 there". I've had an enourmous amount of labor put into my car. (Luckily the majority of it was done by myself) Also, I've spent over $5k on my tool set since I started my project. You've been warned...
secono330ci is offline   Reply With Quote
Old 01-11-2013, 08:53 PM   #7
secono330ci
Bump, really need to find a tool...
Old 01-12-2013, 06:02 PM   #8
redbull 325is
My Ride: 325xit/6
Send a message via AIM to redbull 325is
I just modified a 5 speed tool my buddy had laying around
Royal Elite Club of 6 Speed Tourings - founder
redbull 325is is offline   Reply With Quote
Old 01-13-2013, 07:53 PM   #9
secono330ci
So the splines aren't needed?
Old 01-13-2013, 08:33 PM   #10
TrippinBimmer
My Ride: Just Fast!
^ his way is kinda ghetto but it will do..
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
Stock
NAwhp/NAwtq SAE Corrected
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 01-14-2013, 01:45 PM   #11
redbull 325is
My Ride: 325xit/6
worked fine for me.. it kept the clutch disk right where it needed to be
