Sponsored by BimmerWorld
Old 09-15-2010, 08:30 AM   #1
bAby norAA
My Ride: 01 BMW 330i
Left front suspension clunking
I've checked everything i can. There is no play in my wheel (left front) at 12 & 6 and from visual inspection my tie rod ends look fine, and VERY little play (decent amount of pressure to feel play) at 3 & 9. I know that my control arm bushing needs to be replaced, its not horrible but it is getting pretty worn out, i'm assuming this is my i have a little bit of play from side to side.
This popping or actually more of a "clunk" sound usually happens when taking off from a stand still and turning left. it will clunk quite a few times until the wheel is straightend out where i will get maybe 1 or 2 more clunks and it will stop, which leads me to believe its not my end link. it also happens from time to time when i hit a small bump while driving at highway speeds.
Can the control arm bushing cause this clunk? The only reason i've pushed that idea out of my head is because when i bought my car the right side bushing was torn completly to shreds, in much worse shape then this one and that never made any noises like this.
| VF Supercharged Stage 1.5| Southbend Stage 2 Clutch | ZHP Cams | Technik Headers |
bAby norAA is offline   Reply With Quote
Old 09-15-2010, 08:40 AM   #2
Rif Raf
My Ride: 2001 330i w/ Sport
I'm currently working on mine. Couple things I've noticed. The outer control arm ball joint on the left was bad. The right bushing look good, but there was some wiggle. Upper strut mounts are bad. Inner Tie Rod End on the right side was going out too. All possible clunks.
GL
Rif Raf is offline   Reply With Quote
Old 09-15-2010, 09:14 AM   #3
bAby norAA
GL
how do i go about testing the strut mounts?
Old 09-15-2010, 09:29 AM   #4
Rif Raf
I have dropped my struts out while doing the rest of the work. Once out, I was able to just grab and wiggle the mounts. I don't know that there is really a way to check them in the car.
Old 09-16-2010, 11:15 AM   #5
hummer
My Ride: 2001 330CI
Sway links!
Old 09-20-2010, 01:20 PM   #6
bAby norAA
Originally Posted by hummer View Post
Sway links!
sway links? as in end links? anything more you can give me on this would be great.
Old 09-20-2010, 03:34 PM   #7
mbadger
My Ride: E46 M3, E70 X5
In my case Clunking was because of worn out Control Arm Bushings. I replaced both and it has been great ever since. Check my vid, maybe this will help. It might be your issue, then again it might not be. Good luck in any event.
mbadger is offline   Reply With Quote
Old 09-20-2010, 03:40 PM   #8
invictus
My Ride: M3 (F80 & E46), S3R
Do you get this all the time, or just when the car is kinda warm?
I have a weird clunk I'm chasing that only happens if I drive a few miles when the car is cold, park for a few minutes and then drive again.
**** is driving me ****ing batty.
CCW. Dunlop. Ground Control. StopTech. Hawk. Vorschlag. Rogue Engineering. Recaro. TCDesign. RaceTech. VAC. Motul. Vorsteiner.
Find me on track: 10/19-21 Sonoma Speedway // 11/10-11 Thunderhill
The story so far...
Fund my track car:
PM me about my: stock diffuser, stock trunk, e46 m3 part out
invictus is offline   Reply With Quote
Old 09-20-2010, 04:31 PM   #9
bAby norAA
nah, mine seems to be all the time.
my control arm bushing DOES infact need to be replaced but i figured the noise wasnt coming from that only because when my other one ended up tearing out much worse than the side thats clunking, i dont remember any noises coming from it.
but i'm actually quite relieved to hear that this bushing was causing the noises in your car. looks like this will be my first plan of attack. thank you for the help.
if anyone has any good DIY's on here for the control arm bushing feel free to post away. i'm going to search now
Old 09-24-2010, 12:44 PM   #10
ECSTuning
ECSTuning's Avatar
My Ride: BMW
We developed a kit has been specifically to include the 1st stage of common wear items on your E46 BMW.
Not only does this E46 suspension rebuild kit replace those common wear items we upgrade your units with Meyle upgraded all metal ball joints & Meyle upgraded suspension bushings.
Change the way your E46 feels & even upgrade further than with parts from your BMW dealer. These control arms feature replaceable ball joints. This ECS E46 suspension rebuild kit includes the following:
* Meyle all metal ball joint control arms (left & right)
* Meyle upgraded control arm bushings
* Meyle related hardware
Best,
Joe
