Old 09-24-2010, 03:05 PM   #1
eas
Past Site Sponsor
My Ride: BMW
eas | KW Coilovers- Your #1 Source for V1, V2, V3's!
eas is proud to be an authorized KW dealer and supply your BMW's performance suspension needs!
Variant 1
Featuring sporty handling with factory pre-set damping, the KW V1 Coilover system is ideal for customers wishing to rely on the experience of KW's engineers to set the damper setting, yet determine their own degree of lowering. In extensive driving tests KW's engineers have set the dampers for the best balance between sporty driving, comfort and safety. The user is then free to decide the best height setting for their use and preference.
All KW coilovers pass stringent German TUV safety and quality testing standards. Each kit is sold TUV approved.
Features:
-Optimally pre-set
-Sporty harmonious damping technology
-"inox-line" Stainless steel technology
-Individually height-adjustable
-Lowering range approved by the German Technical Control Board (TÜV)
-Fully finished complete solutions -High-quality component parts for long durability -Comprehensive documentation for easy use
http://www.europeanautosource.com/ad...+kw+v1&x=0&y=0
Variant 2
The KW Variant 2 coilover system is intended for the experienced driver who does not only wish to determine the individual lowering of his vehicle, but also wishes to carry out setup adjustments. The adjustable rebound damper allows adjusting the pitch and roll behavior of the vehicle and therefore the driving pleasure can be adapted to the own requirements.
The rebound adjustment can be installed via an adjustment spindle at the piston rod end, as far as it is vehicle-specifically possible. The rebound damping primarily controls pitch and roll of the vehicle, especially in the low speed damping range which directly influences handling and comfort. Therefore vehicle can be adjusted to the needs of the driver, making the ride variable from comfortable to sporty and stiff, both with improved road handling.
Features:
-Damping technology with individually adjustable rebound
-"inox-line" stainless steel technology
-Individually height adjustable
-Adjustment parameters approved by the German Technical Control Board (TÜV)
-High-quality components for long durability
http://www.europeanautosource.com/ad...+kw+v2&x=0&y=0
Variant 3
The KW coilover suspension system enables the owner to substantially lower their vehicle while retaining enough travel to handle maximum load and dynamic loads during driving. Variant 3 permits an even higher degree of customization to the suspension. Adjustable (and independent reacting) rebound and compression damping allows a truly individual performance driving setup for those technically demanding drivers. Compression dampening adjustment is conducted in the low-speed range, while the high-speed set-up, so decisive for driving comfort, has been pre set by KW engineers.
Important characteristics such as safety, quality and performance are all taken into consideration with each KW coilover design. Each vehicle application is specifically designed and engineered for a proper range of motion, min/max weight loads and min/max lowering. All these requirements are met while retaining it's performance handling characteristics. Each KW coilover suspension is produced with unique stainless steel "inox-line" technology. The stainless steel construction internally and externally provides long term durability and corrosion resistance from the elements.
Features:
- Independently adjustable damping technology - rebound and compression damping
- "inox-line" stainless steel technology
- Individual height adjustment
- German TUV-tested adjustment parameters
- High-quality components for long life
- Comprehensive documentation for ease of use
- Infinitely adjustable rebound damping
- 14- level adjustable compression damping
- Unique, independently functioning damping power adjustment
http://www.europeanautosource.com/ad...+kw+v3&x=0&y=0
Applications (Check links above to see which variants are available for your Vehicle)
1999-2006 e46 3-Series Coupe, Convertible & Sedan
2001-2006 e46 M3 Coupe & Convertible
FREE SHIPPING in the United States.
PM me directly, e-mail, or give me a call if you have any questions, or would like a quote!
eas is offline   Reply With Quote
Old 11-01-2010, 06:06 PM   #2
eas
Past Site Sponsor
My Ride: BMW
Thanks for the order Jonathan, hope you enjoy your new KW V2s!
Old 11-17-2010, 05:36 PM   #3
eas
Past Site Sponsor
My Ride: BMW
We've got some KW coilovers in stock. Check the build quality of these:
Let me know if you'd like a quote
Old 11-24-2010, 06:44 PM   #4
eas
Past Site Sponsor
My Ride: BMW
We've got a few kits in stock ready to ship. Let me know if you're interested
Old 12-07-2010, 01:22 PM   #5
eas
Past Site Sponsor
My Ride: BMW
All PMs have been replied
Old 12-17-2010, 04:25 PM   #6
eas
Past Site Sponsor
My Ride: BMW
Thanks for the order John! Your V2s have been shipped!
Old 01-31-2011, 01:48 PM   #7
eas
Past Site Sponsor
My Ride: BMW
All PMs have been replied!
Old 02-10-2011, 06:37 PM   #8
eas
Past Site Sponsor
My Ride: BMW
Thanks for the order Justin!
Old 02-21-2011, 05:37 PM   #9
eas
Past Site Sponsor
My Ride: BMW
Old 02-21-2011, 05:38 PM   #10
SalM
My Ride: Shhh
Great kits! I love my Kw V1's
SalMPhotography
SalM is offline   Reply With Quote
Old 03-03-2011, 05:56 PM   #11
david @ eas
Past Site Sponsor
My Ride: E46 M3
A recent KW coilover install we did on an e46 M3. Yes, that is indeed a white Gallardo peeking in the background
david @ eas is offline   Reply With Quote
Old 03-15-2011, 05:56 PM   #12
david @ eas
Past Site Sponsor
My Ride: E46 M3
Still got a couple KW kits available, PM me for pricing
Old 04-07-2011, 04:09 PM   #13
david @ eas
Past Site Sponsor
My Ride: E46 M3
Get your car lowered in time for MFEST V!!!!
Old 04-19-2011, 06:48 PM   #14
david @ eas
Past Site Sponsor
My Ride: E46 M3
Some KW Goodies:
Old 04-29-2011, 06:32 PM   #15
david @ eas
Past Site Sponsor
My Ride: E46 M3
Thanks for the orders gentlemen, we appreciate your business!
Old 05-10-2011, 05:39 PM   #16
david @ eas
Past Site Sponsor
My Ride: E46 M3
Got a couple more kits in stock, ready to ship! PM me for best pricing
Old 05-20-2011, 01:10 PM   #17
eas
Past Site Sponsor
My Ride: BMW
Thanks for the inquiries, PMs replied!
Old 06-03-2011, 06:08 PM   #18
eas
Past Site Sponsor
My Ride: BMW
Here's an E46 M3 lowered on the V1s:
Old 06-16-2011, 06:45 PM   #19
eas
Past Site Sponsor
My Ride: BMW
Orders have been processed and shipped!
Old 06-29-2011, 06:23 PM   #20
david @ eas
Past Site Sponsor
My Ride: E46 M3
