Sponsored by BAVSOUND
Old 09-10-2010, 09:58 AM   #1
ferrarix99
ferrarix99's Avatar
My Ride: 87 325e - 05 M3 Vert
M3 Vert Speaker Upgrade [Polk+DLS]
Hey guys,
Im just beginning do do some research on speakers and heres what im thinking of going with:
midbass
Polk Audio MM6501
midrange
DLS 2.5UR
what do you think about the setup? how is the installation? what amp?
THANKS!!
click for pics of the old ride...
-Nick the Greek-
euro.techniks
Bimmerworld Epic Tune | OEM Euro Headers | CSL Brakes | B&B TriFlo | aFe SuperStock | PSS10 | Varrstoen TE37 | V1 | ZKW Lens Swap | Orion Golds
Want your car coded? PM me.
ferrarix99 is offline   Reply With Quote
Old 09-13-2010, 03:40 PM   #2
ferrarix99
ferrarix99's Avatar
No one goes custom? Everyone goes for the BSW?
-Nick the Greek-
euro.techniks
Old 09-13-2010, 04:23 PM   #3
Mulatto325
My Ride: 325ci convertible
I went totally custom. The only stock audio in my car is the speaker wires from the doors to the rear amp. BSW is great but way over price IMO. But there wiring diagrams helped quite a bit. Thank u BSW sorry i could not afford you equipment.
My tops down, its upset.
>>>Mulatto325<<< Build thread
http://forum.e46fanatics.com/showthr...087&highlight=
Mulatto325 is offline   Reply With Quote
Old 09-13-2010, 06:39 PM   #4
Mulatto325
My set up
Car Audio
Head Unit Dynavin nav unit V3
Front Diamond audio HEX s600a Components
Rear Infinity Reference Tweeters 1021t
Kicker DS5250 5.25 inch coaxes
TMA crossover
Amps Crunch GPV1000 125x4
Kicker kx600.1
Box Downward firing enclosure AV priority eBay
Sub JLw1v2.4
Wiring Power wire,dist block,Rca Cables
Old 09-14-2010, 05:32 AM   #5
radarcontact
My Ride: 2006 330CiC/ZHP
For the OP:
I would venture to say, most go custom, vs bsw.
If I were to buy new amps, I would look at the Alpine PDX series or other that accepts balanced differential inputs. This would allow you to bypass the OEM amp without needing to add an LOC before the amp.
Brand, power, etc. are all subjective and all depend on your needs, budget, and personal taste. There are threads on e46fanatics that have a partial list of these types of amps. Just double-check for yourself before buying!
radarcontact is offline   Reply With Quote
Old 09-14-2010, 05:35 AM   #6
DropTopKingM3
My Ride: All German
Originally Posted by Mulatto325 View Post
My set up
Car Audio
TMA crossover
Kicker kx600.1
Sub JLw1v2.4
All of that costs less than BSW? Nice car audio setup you got there!
..George..
..Is now Alpine White/Cinnamon...
^Don't say my car is topless, say the t!tties is out^
DropTopKingM3 is offline   Reply With Quote
Old 09-14-2010, 12:48 PM   #7
ferrarix99
ferrarix99's Avatar
Thanks guys, I'm still a newb in the audio dept but would like to make as sick of a setup as I can for the money
-Nick the Greek-
euro.techniks
Old 09-14-2010, 01:32 PM   #8
torrnt
My Ride: M3
If you want to keep all of your trunk space and have better sound, you can do something like I have. I know...I could've made it cleaner, but you can't even see the setup unless you bend down to look, because of where the vert top is stored. I'm running MB Quartz components up front with the XM-4S(I still have 2 channels open) and a Kicker with the XM-1S. BTW...no cutting or holes were made anywhere. Amps held up by heavy duty velcro for 3+ years.
torrnt is offline   Reply With Quote
Old 09-14-2010, 01:56 PM   #9
ferrarix99
ferrarix99's Avatar
Nice that's exactly what I'm looking to do
-Nick the Greek-
euro.techniks
Old 09-14-2010, 06:51 PM   #10
Mulatto325
Car Audio Price
Head Unit Dynavin nav unit V3 $400.00
Front Diamond audio HEX s600a Components $200.00
Rear Infinity Reference Tweeters 1021t $60.00
Kicker DS5250 5.25 inch coaxes $50.00
TMA crossover $35.00
Amps Crunch GPV1000 125x4 $100.00
Kicker kx600.1 $300.00
Box Downward firing enclosure AV priority eBay $157.00
Sub JLw1v2.4 $94.94
Wiring Power wire,dist block,Rca Cables $75.00
$1,471.94
Yes, I bought the Nav unit used from Jeff@Dynavinsolutions and the Components from a member here also. The kicker amp is almost 10 years old so i think i saved some money and it sounds great one of my best set ups as far as SQ is concerned. Its real loud and with the top down people just give my dirty looks. But it don't hit like the 4 12' i had in my grand Cherokee
I think the BSW ski pass subwoffer set up is like $700.
Old 09-14-2010, 07:06 PM   #11
Mulatto325
My set up
http://forum.e46fanatics.com/showthr...721&highlight=
The shop i went to originally mounted them too the back of front of the trunk compartment. It was a mess what the shop did to me anyway. DIY. If i wanted to do it right and keep my trunk space. I was worried about the amps over heating but so far it has not been a problem. Ill add a fan if i have to. If I get a flat it would be a pain but i could pull that all out in no time.
Here's my thread about my first install
Good luck.
Old 09-14-2010, 07:12 PM   #12
radarcontact
I'm currently in the process right now...
http://forum.e46fanatics.com/showthr...367&highlight=
Old 09-17-2010, 03:45 PM   #13
ferrarix99
ferrarix99's Avatar
http://www.dealercostcaraudio.com/ultimateup36i.aspx
Im currently looking at the full DLS componet set, i think it will be the best for the money ~600 without an amp. Heres my question...
If i swap out the speakers will I need to change the wire or can I use the HK wire?
Also
what amp will work with the stock head unit?
I was looking at these two:
http://www.sonicelectronix.com/viewitem_c.php?id=21951
or
http://www.sonicelectronix.com/item_...o+PA500.4.html
i read above about a line out converter (LOC)? will i need to do that with these amps?
-Nick the Greek-
euro.techniks
Old 09-17-2010, 09:02 PM   #14
torrnt
My Ride: M3
The HK wire is thick enough. I'm currently using it for my components. You will need a LOC to hook up the amp to the factory HU.
Old 09-17-2010, 09:07 PM   #15
DropTopKingM3
My Ride: All German
Nick I cant wait to see the finished product. Would love to see the setup in person when youre done as Im about to pull the trigger on audio this fall.
..George..
Old 09-20-2010, 09:09 AM   #16
ferrarix99
ferrarix99's Avatar
The kicker has differential inputs, that's what I need right? If I get that one then I don't need a LOC do I?
-Nick the Greek-
euro.techniks
Old 09-20-2010, 02:46 PM   #17
ferrarix99
ferrarix99's Avatar
this guy is the man!
http://bimmer.roadfly.com/bmw/forums...786337&page=10
-Nick the Greek-
euro.techniks
Old 09-20-2010, 05:55 PM   #18
radarcontact
Correct.
Old 09-24-2010, 06:37 PM   #19
ferrarix99
ferrarix99's Avatar
Final Setup
DLS UP36i
JL8w7-3 Skipass
Kicker 10ZX650.4
Kicker ZX750.1
I wanna see where im gonna mount these amps lol there gonna have to overlap in the trunk of the vert, stay tuned and ill post pics in the showroom
-Nick the Greek-
euro.techniks
