Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 76 votes, 5.00 average. Display Modes
Old 10-01-2010, 06:32 PM   #41
TRBOVNM
My Ride: 04 330 CI/04 Cobra
Send a message via AIM to TRBOVNM
brutal,
2000_328CI is going to test it out. Like jeff said, others are on another board, but from here, he is going to try it out. I think he ordered the antenna and patch. so we will see soon. if I had everything setup I would do it, but I am a couple weeks out.
TRBOVNM is offline   Reply With Quote
Old 10-01-2010, 07:30 PM   #42
carcus
My Ride: 2006 BMW M5
Standing by for further information before I take the plunge. Keep us updated.
2006 M5 E60, "Lord Vader" Last real NA M series
German Car Fanatic. Colorado ///M Flight member, BMW CCA member.
carcus is offline   Reply With Quote
Old 10-02-2010, 02:44 AM   #43
Darkoz
My Ride: E46 325Ci
petrut, is this procedure reversible?
I've got all your WinCE files for the patch but I'm in two minds whether I'll personally actually use any of it.
Darkoz is offline   Reply With Quote
Old 10-02-2010, 10:28 AM   #44
petrut
My Ride: bmw e46
reversible as easy to delete program files from from sd
petrut is offline   Reply With Quote
Old 10-02-2010, 11:36 AM   #45
Darkoz
My Ride: E46 325Ci
So your patch doesn't actually change anything on the OS/firmware of the device itself, it all runs off the SD card?
Old 10-02-2010, 12:53 PM   #46
petrut
My Ride: bmw e46
it changes lots of things, but changes are hidden in system and don`t affect normal operation unless are activated from sd ( running desktop application ). So unless you run my app from sd, the system will use factory settings.
Old 10-07-2010, 01:23 PM   #47
petrut
My Ride: bmw e46
well, how is the status here? no one interested in wifi ?
Old 10-07-2010, 01:37 PM   #48
TRBOVNM
lol, I know, what the heck is up people. Well, mine is at my house waiting, but won't be installed unitl this weekend. I will pick up the patches sometime next week after I get situated with it. Then need to order the antenna.
Old 10-07-2010, 01:48 PM   #49
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
OK ordered the adapter and am just awaiting its arrival. Will buy software as soon as it comes in and post vids
| 435 HP 328Ci | RRT Racing | Designer Wraps | Active Autowerke | Vorsteiner | STATUS Racing |
Timeless Motor Group
Old 10-10-2010, 06:20 PM   #50
WanderLustMan
My Ride: 05 M3 Mystic Blue
OK, I purchased the hack today and have a few quick questions before I go about destroying my setup .
1. Can someone confirm that with a v5 Dynavin, I don't need to make ANY firmware updates? I was confused by the instructions that petrut included in the hack zip file.
2. All I need to do is copy the "wincehack" directory to the root of the SD card, then set the navigation path to the "install.exe" and let install. After that I can delete wincehack from the SD card and the hack will still be present?
WanderLustMan is offline   Reply With Quote
Old 10-10-2010, 10:30 PM   #51
Darkoz
My Ride: E46 325Ci
Correct on both counts
Old 10-11-2010, 10:13 PM   #52
WingsAA
My Ride: E46 M3
So I'm hitting a snag. I'm trying to copy the wincehack from the unzipped file to the root of the SD card and am getting an error when trying to do that. Any troubleshooting suggestions?
2004 Jet Black 6MT
WingsAA is offline   Reply With Quote
Old 10-12-2010, 02:49 AM   #53
Darkoz
My Ride: E46 325Ci
Did you follow the instructions that came with your WinCE patch download?
Old 10-12-2010, 05:44 AM   #54
petrut
My Ride: bmw e46
make sure you have space on sd, LOL . And if you have MAC, use a windows pc, sorry
Old 10-12-2010, 06:07 AM   #55
TRBOVNM
or if you have a MAC, you can run windows on it. I have windows XP running in vmware fusion on my macbook pro. As of right now, I will never own another brand computer.
Which USB port would we use to do the patch updates? For the dynavin firmware updates we use the DVDUSB. Since petruts patches are for the NAVI side, I assume we use the GPS USB port?
I have one USB extension for the rear USB ports and before I put everything back together I need to figure out if I need to get another extension cable.
Old 10-12-2010, 07:48 AM   #56
WingsAA
My Ride: E46 M3
I tried but it was sort of confusing due to the grammar.
I managed to get the files copied over to the SD card however, when setting the navigation path to install.exe and launch the navigation/confirm the install... I get a message telling me data files not found please read instructions.
After re-reading the instructions I extracted the files from the data.zip on the SD card and put copied them into the program files folder on the wincehack folder. Tried to do the install again and am getting the same message: Data files not found, please read instructions.
Can someone help clear this up for me. My head is hurting.
2004 Jet Black 6MT
Old 10-12-2010, 09:31 AM   #57
petrut
My Ride: bmw e46
COPY ONLY the program files folder from data.zip to wincehack folder !!!!!!!!! Is pretty clear explained...
@trbovnm, install the patch on the GPS SD card, not on usb, not from usb !
Old 10-12-2010, 09:51 AM   #58
WingsAA
My Ride: E46 M3
This is what I did. Extracted and Copied the program files folder from the data.zip located on the SD card to the wincehack folder that I downloaded from your location. then copied the wincehack folder to the root of the GPD SD card.
**Update** I think I found my mistake... I'll report back shortly.
2004 Jet Black 6MT
Old 10-12-2010, 11:16 AM   #59
WingsAA
My Ride: E46 M3
Got it figured out!
2004 Jet Black 6MT
Old 10-12-2010, 11:18 AM   #60
TRBOVNM
can you explain your mistake so future users don't make it?
