Sponsored by BimmerWorld
Old 09-27-2010, 10:20 AM   #1
PO-BoxE46
My Ride: BMW E46
Question Looking for Stiffer Springs To replace my current Springs
I purchased a Raceland kit and find that that the rear springs are to soft. If any one has or knows of someone who has replaced the stock raceland springs with something else, could you provide some suggestion? I'm not looking for dumb remarks just a little help.
PO-BoxE46 is offline   Reply With Quote
Old 09-27-2010, 12:56 PM   #2
PO-BoxE46
My Ride: BMW E46
Still looking for help
Old 09-27-2010, 10:38 PM   #3
BMW_Matt
My Ride: 135
What kind of rates you looking for?
BMW_Matt is offline   Reply With Quote
Old 09-28-2010, 02:44 AM   #4
3bananas
My Ride: 1998 328is
I'm swapping my RLs for Vogtlands, heard very good things about them from competent forum members
________________________
3bananas is offline   Reply With Quote
Old 09-28-2010, 08:19 AM   #5
jamex
My Ride: 2005 325Ci
Are you sure its the springs you want to replace? They mostly control the height. The rear shocks in the raceland kit are a bit soft and thats probably what you want to be swapping out. I found it a bit bouncy at first but either it went away or I don't notice it anymore. I was going to swap in my OEM sport shocks as a free alternative but lost my motivation after I stopped noticing the bouncing.
jamex is offline   Reply With Quote
Old 09-28-2010, 08:20 AM   #6
jamex
My Ride: 2005 325Ci
Doesn't sound like the OP wanted opinions on rip'n'replace options. From following the vogtland thread I would guess you're either a shill, a troll, or both.
Old 09-28-2010, 01:11 PM   #7
PO-BoxE46
My Ride: BMW E46
so your suggesting i change the rear shocks. what should i swap them out for. I'm running Front: 20" x 8.5 & Rear: 20" x 10" in the rear.
Old 09-30-2010, 12:37 PM   #8
ECSTuning
ECSTuning's Avatar
My Ride: BMW
H&R has a solution to your soft spring delima...
They offer their Race Springs, for those that want the ultimate in handling and an over-the-top highly aggressive look.
Race Springs will lower your vehicle approximately 1.75 - 2.5 inches and should be matched with high-quality sport tuned shock absorbers. Race Springs also have a firmer spring rate than the Sport Spring.
Best,
Joe
Old 09-30-2010, 06:11 PM   #9
Solo 323 CI
My Ride: 00 323Ci
You might as well sell them. Replacing the springs is going to cost just as much as the coils. Just get lowering springs. You can't use coilovers to their full advantage anyways with such a large wheel setup.
Solo 323 CI is offline   Reply With Quote
Old 10-01-2010, 04:28 AM   #10
mkodama
mkodama's Avatar
What makes you believe your rear springs are too soft?
Springs entirely control both ride height and spring rate. Fine tuning to the ride height can be done with spacers and adjustable perches though.
