Bavarian Soundwerks' Mobile Electronics Forum
Have all your A/V and electronics questions answered here. Ipods, A/V, Radar Detectors Oh My! Sponsored by Bavarian Soundwerks |
#1 |
Prof Nav -> Non-H/K & H/K same head unit?
Hello all,
I have a question... If I get the Prof Nav, that will function as my HU right? I do not want to get the H/K system as I am planning an upgrade anyway, but I want to keep the stock HU. The H/K system is basically just an amp/speakers upgrade right, I mean it doesn't upgrade the HU? Also, if I don't get the H/K, I will need to do all the wiring from the HU to a new amp in the trunk and back to the speakers myself myself right? And, if I don't get the H/K system will do I still get all the factory "holes (sorry, couldn't find a better word)" to put the speakers in? Thanks! |
#2 |
What do you mean by "prof"? Professional? The stock nav?
I have the Nav with HK, but I believe you're right, the headunits are the same, the only difference would be the amp in the trunk (more channels) and the additional speakers. No, even with a non-HK, the amp will still be in the trunk, and thus you can tap into the factory harness in there as well. You won't have to run your own wires unless you want to add speakers in locations that don't come with the non-HK system. Not sure about the holes, although I thought I've read that if you don't get the HK, the HK locations are pre-cut but not "punched out."
Better picture coming!
#3 |
Thanks for the info. Main reason I ask is that I am 100% sure I will do an audio upgrade, even if I get the H/K system. I want to know if it is a good or bad idea to get the H/K considering I will replace both the amp and all speakers if:
a) The head unit is the same or not (same) b) Wires are in place (in place to the default front speaker locations if you get the stock system) c) Holes are precut/punched out (not) I will most likely let a shop do the installation. Maybe getting the H/K system will cut a significant hole in installation time, thus installation will be cheaper.... ps: Prof = Professional, this is the nav system with the color screen. There is also a nav system with a tiny screen that just displays the directional arrows, no map. Not sure if that is an option on ther US models.
Receive Motorsport results on your Mobile phone
www.sportsnn.com/en/motorsport |
#4 |
Sofa-king-what
yes you can add everything you want to the stock nav-tv sys.
.... there are some sort of stock amplifier in the trunk (under the navi computer... left side of the trunk)... you can easily add ampli&speaker only using a line converter (to create a RCA output from the stock wire..... ...just a question: do you swap from radio navigation (the navi with the "arrows") to nav tv???or just install it |
#5 |
Not sure what you mean. I will get the color screen navigation on my new order, I'm not trying to retrofit. Just trying to find out if I should order the H/K system even if I will upgrade that anyway straight after delivery. But I guess I will not order the H/K system to save me some money that I can put into the upgrade...
#6 |
Sofa-king-what
i meant retrofit...........
my 2 cents........ save money and upgrade your existing speaker..... |
#7 |
No longer a worker bee!
Don't waste your time with H/k. It's not a dropdead gorgeous system by any means. It's a simple upgrade that will not perform well when pushed. If you're not looking for gutwrenching bass, this will do just fine.
---dotted line---
#8 |
Actually I have the H/K system on my 320Ci now and I never really liked it. That is whyy I will definitely upgrade when I get the M3. I'm looking for an answer if getting the H/K system would make upgrading more easy as opposed to getting the standard 6 speaker system. If the head unit would be *better* with the H/K system for instance, I would get it as I want to keep the head unit and just replace the amp/speakers. Also installation would be easier as the wires are in place and the "holes" are already pre-cut and such. But does that weigh up against the $$$ the H/K upgrade costs??? I don't know.
#9 |
Sofa-king-what
def. HK system is for middle aged german people that love to listem Bach at a quarter of the entire volume.....while they're driving into the slowest side of "die autobahn"....with their wives on the passenger side....and obviously their 3 children on the back seats.........
ja ja ja |
