Sponsored by BAVSOUND
Old 04-23-2003, 08:13 AM   #1
Frank Rizzo
My Ride: '02 330ci
JL Amps = Balanced signals?
Has anyone here hooked the factory HU outputs directly to a JL amp that accepts the balanced input signals? I'm thinking one less component in the signal path (no converter) can only help - I'd just like to know that it actually works...
Gen-u-ine Chevrolet?
Like there is a rash of counterfits?
Frank Rizzo is offline   Reply With Quote
Old 04-24-2003, 12:26 AM   #2
johnhab
My Ride: '02 330xi
Send a message via AIM to johnhab Send a message via Yahoo to johnhab
Yes, the JL amps accept the BMW headunit inputs directly, i.e., you don't need a line output converter.
Better picture coming!
johnhab is offline   Reply With Quote
Old 03-09-2004, 08:22 PM   #3
gharari
My Ride: 2000 323i Sedan
Send a message via MSN to gharari
How 'bout an Alpine 540?
gharari is offline   Reply With Quote
Old 03-09-2004, 11:01 PM   #4
johnhab
My Ride: '02 330xi
I don't believe so, but not 100% sure. I can tell you that my Alpine MRV-T420 does NOT accept balanced differential/speaker-level inputs. You can look at at amp's specs and if it's input range is 2V or below, it only accepts unbalanced inputs (i.e., you need an LOC).
Old 03-10-2004, 06:21 PM   #5
TXKev
My Ride: 2003 330Ci
Xtant amps also accept Balanced line inputs. They can handle up to 17v.
Kev
TXKev is offline   Reply With Quote
Old 03-10-2004, 09:36 PM   #6
gharari
Is there an input voltage adjustment on amps that accept balanced?
Old 03-14-2004, 09:24 PM   #7
johnhab
My Ride: '02 330xi
Yes, there's input gain sensitivity on amps that accept balanced inputs. The manufacturer doesn't know if you're going to feed it a balanced signal, an unbalanced signal, and whether it's coming from a factory headunit, an aftermarket headunit, speaker-level inputs, etc.
Old 03-17-2004, 10:25 AM   #8
rkj082000
My Ride: 1999 328i
How does it sound using a stock HU to an amp versus using a aftermarket deck with like 4v pre-outs? Is there a noticeable difference?
rkj082000 is offline   Reply With Quote
Old 03-19-2004, 11:56 PM   #9
johnhab
My Ride: '02 330xi
I really can't answer that, as I'm using my aftermarket amp to drive a set of JL Stealthboxes, so I'm only hearing the lower frequencies. I also have navigation so I don't plan to switch out my headunit.
Hopefully someone else that did an amp upgrade with the stock headunit then later switched out for an aftermarket head unit could give you some insight into the sound difference. However, it's going to greatly depend on the headunit, the amp being used, the aftermarket speakers being used, etc.
Old 03-20-2004, 03:25 PM   #10
gharari
If you hook it up right, and adjust the VEN4 properly, there should be very little difference between the sound of the stock hu and an afteremarket when listening to CD. You might be able to get better FM/AM reception from an aftermarket but I'm not sure about that.
Old 03-20-2004, 03:50 PM   #11
johnhab
My Ride: '02 330xi
If you have a HK navigation unit, you're almost certainly going to have better reception with an aftermarket unit, unless you buy a piece sh!t. That's why I got an XM receiver...
