Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 40 votes, 5.00 average. Display Modes
Old 12-17-2011, 06:27 AM   #221
kevz65
My Ride: 318i SE E46
Originally Posted by fadeaway View Post
Okay. Look closely at the light that you took out that has four wires connected to it. It is a daisy-chained power supply. Two wires are for power and two wires are for ground. To find out which, follow the wires to the bulb holder. They are shorted in the holder.
That is the short answer.
Here is the long answer.
In pic 2, you have the ability to disassemble the part the wires are sticking out of. This should have a total of 4 wires. 2 for the boot lid handle button and 2 for power to the lights.
The 2 for the lights go directly to the part that you cut out, then it goes to the other light using the same supply. Daisy-chained. These are the two wires that should hook up to your LED light. Take a multi-meter and find out which is power and which is ground. Then connect the wires to your LED light accordingly. I hope I don't have to say this, but do the test while you have power and connect when you don't have power.
It is also possible to disassemble the rest of the boot lid handle, but I would recommend against it since you will most likely break some plastic bits that don't glue on again. Edit: After looking closer at your pics, you have a simpler design to your boot handle than I do. It is already open. Just follow the wires around.
As for the other wires, I was able to fit them into the place where they come out from in pic #2 after some cutting of the wires and butt-splicing.
Does that make things clearer? I'll keep checking this thread to see how you're coming along.
Thanks for the explanation. Really appreciate it!
To put it simply is this how I would wire it:
Red (pos) from the camera led to the grey brown which is conjoined with the other grey brown(there are two grey browns in the pics).
Then the black wire from the camera led to the conjoined brown/red and brown?
Thanks again buddy
kevz65 is offline   Reply With Quote
Old 12-17-2011, 07:46 AM   #222
MaximumWalrus
My Ride: E39 530i
I've picked one of these things up off Ebay in anticipation of the D99 coming out. It looks like the one in Darkoz's pic and came in a box with a picture of a Z4 on it. Is the light likely to be a white LED? Just wondering if I'm going to need to order up some LED's for the other side to stop it looking odd.
MaximumWalrus is offline   Reply With Quote
Old 12-18-2011, 04:45 AM   #223
kevz65
I believe it is.
Old 12-19-2011, 04:47 AM   #224
fadeaway
My Ride: 04 330Ci
Thanks again buddy
I'm not sure which is which but you're getting the gist of it. The same color stock wires are joined first.
You have to figure out which is connected to black and red. I usually use a voltage meter. One of your friends should have one if you don't have one yourself. Black is ground (or reference line) and red is ~12V (or higher voltage line).
fadeaway is offline   Reply With Quote
Old 01-06-2012, 10:03 PM   #225
Rickna
My Ride: '01 330xi - '09 IS-F
It was advertised to fit but wasn't even close.Took some work to fit this in.
I eliminated the screws after I shot the pic. Very little protrusion is what I was after.
The graduations are close to the actual distance. I know-the wires look terrible. It's been fixed since then.
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
Old 01-07-2012, 11:30 AM   #226
kevz65
Finally had a stab at it! 90% of it is done now and the boot handle and LED are working!! Only thing is the RCA cable isn't long enough so I will need to splice another one onto the existing one to reach the front! Thanks
Old 01-10-2012, 12:42 PM   #227
fadeaway
My Ride: 04 330Ci
Old 01-10-2012, 01:16 PM   #228
w0w
My Ride: '02 M3 Vert
does anyone have good picture of the light output of those leds? id like to have an even glow so i might have to mount the camera somewhere else
daron
w0w is offline   Reply With Quote
Old 01-10-2012, 02:15 PM   #229
fadeaway
My Ride: 04 330Ci
I personally didn't like the LED so I hacked up the cam. I once asked for recommendations on an LED that would have a similar light output for the other side, but came up with nada.
Good luck.
Old 01-27-2012, 03:28 PM   #230
m2rvh
My Ride: BMW
mine on my vert
uses original lock place
m2rvh is offline   Reply With Quote
Old 02-11-2012, 09:56 PM   #231
geeDoh
My Ride: E46 M3
been reading this thread for the past 2 months, and finally felt confident enough to try it. install, wiring, etc went well, but ran into a problem.
when i put my car in reverse, the Dynavin (D99) switches to camera, but the screen is black, and there is a small camera icon in the top left of the screen. any ideas?
instead of soldering wires (from camera power to reverse light), i used t-taps to splice. could this have any affect on this? also, i used 22-gauge hookup wire to extend the reverse wire (the green wire from behind the Dynavin) to the trunk. could that have any affect on this? just trying to do some detective work...
thanks for any help!
geeDoh is offline   Reply With Quote
Old 02-11-2012, 10:12 PM   #232
Tchleung
My Ride: 02 M3
Are you sure the Video RCA cable is connected?
Follow me on Instagram @tommtomm84
03 Carbon Black X5 4.4 - Parts Hauler/Daily
02 Carbon Black M3 6MT - Fun Car
456whp/312wtq @ 8psi, No #'s yet at 9psi
4.10 / Headers / ESS VT2-550+
Tchleung is offline   Reply With Quote
Old 02-11-2012, 10:36 PM   #233
geeDoh
My Ride: E46 M3
yup, all plugged in...
Old 02-12-2012, 01:21 AM   #234
Tchleung
My Ride: 02 M3
Oh wait, I remember reading on the D99 thread that you have to change it to use the camera as it's default on PDC I think.
Old 02-12-2012, 01:50 AM   #235
geeDoh
My Ride: E46 M3
I'm not sure I know what you mean...?
Old 02-12-2012, 03:15 AM   #236
Tchleung
My Ride: 02 M3
Actually now that I read it again, I don't think it's your issue but worth a shot...
Start reading from post #178 and on.
http://forum.e46fanatics.com/showthread.php?t=895068
Old 02-12-2012, 09:58 AM   #237
Rickna
Would it have anyting to do with PAL vs. NTSC?
2001 BMW 330xi
2009 Lexus IS-F
Old 02-12-2012, 02:36 PM   #238
geeDoh
My Ride: E46 M3
I don't think PAL vs NTSC matters, I remember reading a post about that.
How would I know if the camera is receiving enough power?
Old 02-12-2012, 02:42 PM   #239
Rickna
I know that my camera uses 12V. run the power lead and check it with a multimeter.
2001 BMW 330xi
2009 Lexus IS-F
Old 02-13-2012, 02:00 PM   #240
Gotubch
My Ride: 01 LSB M3, +others
Anybody sell these that replace the license plate light in the States?? Dont really want to wait almost a month to get one from HongKong?
Gotubch is offline   Reply With Quote
location, reverse camera, zhp
