Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 40 votes, 5.00 average. Display Modes
Old 10-01-2010, 08:28 AM   #21
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
Love seeing that this is becoming a popular mod. I have been very happy with mine so far an can help address questions if anyone has any more
| 435 HP 328Ci | RRT Racing | Designer Wraps | Active Autowerke | Vorsteiner | STATUS Racing |
Timeless Motor Group
Old 10-01-2010, 08:36 AM   #22
Darkoz
My Ride: E46 325Ci
Darkoz is offline   Reply With Quote
Old 10-01-2010, 08:40 AM   #23
Darkoz
My Ride: E46 325Ci
Here's a pic so far.......looks like another thing to buy, LED license plate light
2000_328CI, is it possible to give a description of how you spliced into the reverse light wiring or perhaps pics if you took any?
Old 10-01-2010, 08:41 AM   #24
2000_328CI
2000_328CI's Avatar
Yeah man I went in through the trunk liner and tapped into the reverse lights to power the camera ONLY when the car was in reverse. Let me know if this makes it a little clearer
Old 10-01-2010, 08:46 AM   #25
Darkoz
My Ride: E46 325Ci
Thanks but what I meant was the actual procedure of splicing into the wires, how did you go about it?
Old 10-01-2010, 08:52 AM   #26
2000_328CI
2000_328CI's Avatar
You will use one of those red wire taps. Find the reverse light wiring and tsp into the power trough that. I can't remember specifically which wire in that cluster you want to utilize. Peppyr6 helped me with that portion so I will ask him to chime in. I meant to take new pictures but kept helping rather than documenting
Old 10-01-2010, 09:05 AM   #27
Darkoz
My Ride: E46 325Ci
No worries, did you just cut the reverse light wires or did you take the OEM plug off and connect/solder the camera wires to the ends of the reverse light wires and then slide the wires back into the OEM plug, if so how do you get the wires out of the OEM plug, I can't figure out how to disconnect the wires from the plug..
Old 10-01-2010, 09:30 AM   #28
TRBOVNM
My Ride: 04 330 CI/04 Cobra
Send a message via AIM to TRBOVNM
found out my camera does not have night vision and does not have the distance intervals. so we will see how it works. not a big deal for me though.
I will probably either use a butt connector or a wire clip to tap into the reverse lights.
TRBOVNM is offline   Reply With Quote
Old 10-01-2010, 02:26 PM   #29
PreppyR6
My Ride: shines like justice
We just used a couple t-taps to tap into the reverse pos/neg wires. I stripped back the wriring from the camera and attached some connectors to fit the t-taps and then tapped the wires going to the passenger side reverse light (doesnt matter which reverse light you pick). No need to remove plugs or anything.
Das Weena!
PreppyR6 is offline   Reply With Quote
Old 10-01-2010, 02:28 PM   #30
PreppyR6
The two wires to tap are brown(ground) and blue/yellow. You also need to remove the glovebox, pull down the fusebox and look up into the compartment to see a black box. Unhook the black box and locate any blue/yellow wire. Use the Dynavin's reverse cam wire (green I think) and tap into the blue/yellow wire (you will need some extension wire as Dynavin wire is only a few inches long.
Das Weena!
Old 10-01-2010, 08:49 PM   #31
Darkoz
My Ride: E46 325Ci
The only cable I see on the Dynavin for the reverse camera is the rear camera rca cable, there is no other reverse cam wire that I can see.
Old 10-05-2010, 11:45 AM   #32
erod225
My Ride: 2003 M3XI
LOVE this mod, def. gonna do this to my sedan. How much does the camera cost?
erod225 is offline   Reply With Quote
Old 10-05-2010, 04:31 PM   #33
jinxie
My Ride: 2000 BMW 323ci
I've been planning on doing this by putting the camera in my trunk keyhole, but this looks barely noticeable. do you have any daytime pictures?
jinxie is offline   Reply With Quote
Old 10-05-2010, 04:56 PM   #34
Darkoz
My Ride: E46 325Ci
I'll post a pic when I get home today, I have 3 different reverse cameras and this one is the smallest and least noticeable
Old 10-05-2010, 10:26 PM   #35
Jmanscotch
My Ride: makes my pants tight
Most on seem to run in the neighborhood of $40
-Jake
2004 325CI - 2003 3.0 Z4 - 1994 325i - 1967 1602 - 2008 328XI - 2009 135i - 2007 Jeep Wrangler - 2014 *Loading*
Jmanscotch is offline   Reply With Quote
Old 10-06-2010, 12:45 AM   #36
shannon1
shannon1's Avatar
My Ride: 2001, 318i
I got one of those lens light replacements. Here's how it looks.
Shannon.
shannon1 is offline   Reply With Quote
Old 10-06-2010, 03:34 AM   #37
Darkoz
My Ride: E46 325Ci
This one is at head level, so what you see as you walk past the car, sun was just setting sorry about the yellow tinge .........
Old 10-06-2010, 03:37 AM   #38
Darkoz
My Ride: E46 325Ci
Originally Posted by shannon1 View Post
I got one of those lens light replacements. Here's how it looks...........
shannon1, have you got a pic or link to the camera that you bought?
I like how it shows the distance in metre increments
And then wash your car
Old 10-06-2010, 07:22 AM   #39
Darkoz
My Ride: E46 325Ci
OK chaps, can one of you knowledgeable guys help me out with one minor issue.
Camera is installed in the number plate light location and fits perfectly, check, power wire to the inbuilt camera LED is spliced into the number plate light wire, check, power wire from the camera is spliced into the reverse light harness, check.
Plugged the supplied video RCA cable into the camera which is then plugged into the reversing camera cable at the back of the Dynavin, check, tested the camera and picture on the Dynavin screen is good, check, however I can only get the picture to come on by manually pressing the camera icon on the Dynavin main screen, it doesn't trigger automatically when I put the car in reverse which I thought by splicing the camera's power wire into the reverse light wiring was supposed to do.
So I have missed something but have no idea what it is.
Old 10-06-2010, 04:21 PM   #40
duke.togo
My Ride: '05 330Ci
Question
What are you guys using for the entry point back into the trunk for the camera wiring?
Hole drilled through the trunk, behind the removable lip? Or is there a way to fish wire through the existing bundle/grommet (for the lights/trunk release button) in the lip?
duke.togo is offline   Reply With Quote
location, reverse camera, zhp
