Old 10-19-2010, 12:08 PM   #21
MadBMW
My Ride: BMW 330i
Originally Posted by ruckus323 View Post
plastigage told you 0.025 inches or mm? I assume inches otherwise that would be a little tight for bearing clearance. I'm guessing your other rods were between 0.003 and 0.008 inches plastigaged??? I don't know the book specs for these cranks.
If you have 0.025 inches on your rods, you're going to hear some knocking when you out it back together.
Those are MM measurements. The Haynes repair manual says .025-.050mm (.001 to .002in) is usual for the e46. The 2nd channel is pushing the .050mm mark. Its kinda between .038 and .050mm which is in spec according to a not so good manual . The other channels are closer to the .025mm mark.
Ah I was looking at the m3 crank, $1200 is better but id rather see if this works and only be behind a few hours and $150 if it doesn't.
More parts just came, may have them all now! more to come...
- Bimmin a 330i... again. -
MadBMW is offline   Reply With Quote
Old 10-19-2010, 01:05 PM   #22
tedfredrick
My Ride: 2001 325I
My Dad had a motorcycle with a rod knock for years and it never caused a problem. He just used thicker oil. The knock that he had was when the motor was cold. Have you thought about thicker oil. The only problem with thicker oil is that you get more startup wear and lesss gas mileage. You have already covered the wear problem. You might think of Mobil 1 15-50w. If you don't use differnet bearings and machine the crank you might have the same knock resurface. The thicker oil may fix the knock
2007 BMW 328I handiling package
2001 E46 325I
1927 Ford Track T 350 Chevy
tedfredrick is offline   Reply With Quote
Old 10-19-2010, 01:06 PM   #23
tedfredrick
My Ride: 2001 325I
Did you plasigage the old stuff and find the differnce between the two that would let you know if you were on the right track
2001 E46 325I
Old 10-20-2010, 02:02 PM   #24
MadBMW
My Ride: BMW 330i
I didn't plasti the old stuff, but I definitely am on the right track... everything went together as it should with very limited play. The old stuff had a lot of play.
Started her up last night... she runs! Big improvement! Maybe I am being picky but I can hear a little something when my head is close to the pan. Hoping after the 500 mile break in, shes gona be fine... Also the battery is shot now that its been sitting, getting one today (update: batt just needed a long slow charge, its holding up). On to reassembling the rest of the suspension.
More to come...
Old 10-21-2010, 10:46 AM   #25
MadBMW
My Ride: BMW 330i
Ok - shes off the jacks and went for a little ride last night! She sounds 98% better and I hope this fix sticks!
It did start to overheat slightly, due to having an air bubble in coolant line - burped her and shes good to go!
Total job was about 12hrs of work at a difficulty level of 7.5 IMO.
Old 10-21-2010, 12:58 PM   #26
Tangent_
My Ride: '01 330i, '11 Z435i
Nice job! I suppose it's a bit late to mention you might want to check on the oil pump nut?
http://forum.e46fanatics.com/signaturepics/sigpic70081_4.gif
Tangent_ is offline   Reply With Quote
Old 10-21-2010, 02:40 PM   #27
MadBMW
My Ride: BMW 330i
Haha, glad you mentioned it for this thread... I did give it a few extra taps with a chisel/hammer so shouldn't have any issues there. I happen to see a post from one of the other members having done this.
I also took apart the pump and checked for, i guess play... it was fine. From what I read they are rarely a problem.
Old 11-04-2010, 08:54 PM   #28
MadBMW
My Ride: BMW 330i
SOOOOOOOOOOOOOOOOOOOOOOO
Its been about 500 miles of easy driving.... and the knock is a little louder then it was when I 1st put it all back together... CRAP
Don't know how fast its going to get really bad, hopefully a WHILE! Otherwise its oversize bearing time with a trip to the machine shop and consideration for a new con-rod or 2...
Old 11-06-2010, 09:09 AM   #29
Blk 2002 330ci
My Ride: BMW 330ci
If the old rod bearings had spun I would think the rods would need to be resized to make them round again.
Before I would rebuild your engine I would also look at a low mileage used one.
Blk 2002 330ci is offline   Reply With Quote
Old 11-08-2010, 02:52 PM   #30
MadBMW
My Ride: BMW 330i
Used are $2000+ and I would have to do the swap... If I have to do con-rods I may consider it... if its just an oversize bearing, way cheaper to get back in there and replace it..
Old 11-08-2010, 04:09 PM   #31
ajlman
My Ride: 323Ci
Hey Man, Save yourself more trouble in the future. Your rod journals are badly scored. I would not even consider trying to sand that crank yourself. Find a good machine shop and read up on what the factory spec. clearances are give them the spec. and the oversize bearings you're using and they'll know how much to take off. Or better yet just get a new Crank. Do it right, you'll do it once...If not you'll end up having to replace your bearings every 3 months. Your car, Just my 2c.
ajlman is offline   Reply With Quote
Old 11-16-2010, 10:25 PM   #32
BimmerDude18
My Ride: 1998 528i
Those cranks in good shape go for $350, look for S52 cranks, they are interchangeable.
-Tyler
1998 528i 5-speed Work in progress
1988 Toyota Pickup (4WD 5-speed) daily
2007 San Marino Blue 350z 6-speed sold
1996 328i 5-speed sold
www.e46nonM.com - www.precision-sport.com - www.flyingwindowtinters.com - www.techniquetuning.com
BimmerDude18 is offline   Reply With Quote
Old 11-19-2010, 02:45 PM   #33
MadBMW
My Ride: BMW 330i
Any idea where to pick up a used one? Car-parts.com is not giving me any results for cranks...
Old 06-13-2011, 07:07 PM   #34
MadBMW
My Ride: BMW 330i
Just wanted to update that its been working great for the last 10k miles! ::knocks on wood::
I am however leaking oil pretty bad - think its the dipstick gasket. Ill be replacing that soon, even though it was just changed.
Old 08-05-2011, 09:24 PM   #35
brandonbigdog
My Ride: 01 330ci
where did you get the bearings and what size? Also is there a spec what the conrod journal diameter is stock in the haynes manual?
brandonbigdog is offline   Reply With Quote
Old 10-28-2011, 06:49 PM   #36
GreaseJunkie
My Ride: 325xi
MadBMW, I'm looking for an update! I was searching bearings as a trouble-shoot problem for my 325xi (thank God it sounds like I have a different issue. I don't think this is over my head, but I have nothing to hold the car over my head ) Anyway, this is a great read and I want to hear the ending. It's been 4 months since your last report... Got to love a happy ending, hopefully!
GreaseJunkie is offline   Reply With Quote
Old 02-13-2012, 12:51 AM   #37
AMCINK
My Ride: 2000 323CI
any updates
AMCINK is offline   Reply With Quote
Old 05-09-2012, 01:54 PM   #38
MadBMW
My Ride: BMW 330i
Lol sorry guys... Dont get on here much unless I have issues.. which is the case now
Purchased everything from Pelican Parts. Fast and affordable.
I went with the OEM size. They have the oversize bearings for cranks that have been machined to the oversize spec as well.
Don't think there was any measurements for just the conrod. By measuring the space in the bearings when assembled it mesures everything (crank, bearings and conrod).
So for your happy ending........ ...... Its kinda happy! Knocking is gone and I fixed that problem! yay... seems over time the bearings seated themselves and there is no noticeable knocking anymore. I put over 15k miles on it over the last year!
....but now have more problems related to me messing with things (cant find oil leak.. maybe from the head gasket - boooo) and unrelated things like a rough idle and a bad hesitation while accelerating. Bimmer work never ends does it...
Off to the rough idle threads... already fixed a broken intake flapper which fixed it the 1st time.. now its back, worse, and the intake flapper is still like new after checking.
Seafoaming tonight!!!
Old 05-10-2012, 10:40 AM   #39
MadBMW
My Ride: BMW 330i
Seafoam didn't do anything... didn't even smoke a lot... weird.
Old 05-11-2012, 08:40 PM   #40
ThatGuy_JZ
My Ride: '02 Steel Blue 325Ci
Send a message via AIM to ThatGuy_JZ
Sell the car and buy another one???
- 2002 Steel Blue 325Ci -
ThatGuy_JZ is offline   Reply With Quote
330i rod bearings, bmw rod bearings, diy, e46 rod bearings, rod bearings
