Old 10-01-2010, 05:52 PM   #1
WSTO
Past Site Sponsor
+WHEELSTO PROJECT KICS R40 Racing Lug nuts x Macht Schnell Competition Wheel Studs
x
Bimmerpost members,
WSTO is proud to introduce the Project Kics R40 Racing Composite lug nut set and Macht Schnell Competition Wheel Studs (12x1.5mm). The Project Kics R40 features a unique feature (patent pending) of this seven-sided, heptagonal lug nut is that each lug consist of 2 pieces, where the top of the lugs spin freely from the tapered centering ring.
This ensures a much tighter and precise hold than traditional lug nuts. It also minimizes the chances of scratching your wheels. Made of lightweight composite materials, these open ended lugs fit on both standard studs as well as extended studs. The entire set weighs just under 2 lbs! Highly recommended for both street and track enthusiasts.
All Macht Schnell Competition studs are hardened and tempered to strength class 10.9 or 10 according to DIN/ISO standard 898. They meet the statutory requirements of all countries - including the USA. All studs feature a black plating process for OEM appearance. Final inspections are not restricted to random quality checks. Every single fastener is tested to ensure compliance with specifications. Studs/nuts are also offered individually and should be replaced after every race season.
Competition Wheel Stud Kit Features:
- 10.9 Grade Strength Class for ultimate strength and safety
- Bullet Tip prevents cross-threading
- Faster and easier wheel changes
- 75mm length allows for most spacer thicknesses (up to +12mm) to be used without changing studs
- Eliminates the need for balancing the wheel while threading in stock wheel lugs
- Black zinc coating for additional strength and corrosion/wear resistance - Allen key insert for easy installation
- Fits most BMW models
PROJECT KICS R40 Racing Lug nuts with Macht Schnell Competition Wheel Stud conversion kit:
(20) Project Kics R40 Racing Composite lug nuts 12 x 1.5mm lug nuts with a special key / socket adapter. 12x1.5mm pitch (Hyper Black type finish)
- Super light-weight thin-wall construction using strong light-weight OEM quality materials.
- Oversized and taper seat to ensure best contact.
- External drive by popular 17mm hex for easier installation.
- Full stud engagement and can accommodate long racing studs.
- Reliable and stronger than aluminum racing nuts.
- Japan patented (No. 1192260) and USA patent applied.
- Lug body produced by Cold-Forged SCM-435 material.
- Attached rotating taper-seat made with A7075-T6 aluminum and ultra-hard alumite finish.
Macht Schnell Competition 75mm Bullet Tip Wheel Stud Specifications:
- Shank length: 75mm (Bullet Tip)
- Thread pitch: 12mm x 1.5.
NOTE: For added safety, we recommend adding Locktite to the stud ends when installing into the hub. Locktite can be purchased at your local hardware store. Studs should be torqued to 65 ft lbs each.
How to Order or Get More Information:
Call: 312.880.7767
Email: info@wheelsto.com
or PM us!
WSTO is offline   Reply With Quote
Old 10-01-2010, 07:44 PM   #2
invictus
My Ride: M3 (F80 & E46), S3R
Got these longer than 75? say, 90?
CCW. Dunlop. Ground Control. StopTech. Hawk. Vorschlag. Rogue Engineering. Recaro. TCDesign. RaceTech. VAC. Motul. Vorsteiner.
Find me on track: 10/19-21 Sonoma Speedway // 11/10-11 Thunderhill
The story so far...
Fund my track car:
PM me about my: stock diffuser, stock trunk, e46 m3 part out
invictus is offline   Reply With Quote
Old 10-04-2010, 06:18 PM   #3
WSTO
Past Site Sponsor
Only 75mm shank is available at the moment.
Old 10-04-2010, 06:28 PM   #4
C Digital 323CI
Eurowerkz Midwest
C Digital 323CI's Avatar
My Ride: 2006 E90 330i
I had these on my old E46 and they rocked! Great deal WSTO!
-Chad - Eurowerkz, Midwest Director
SPONSORED BY: | TOYO Tires | WheelSTO | Level Industries |
C.Moon Photography
Twitter
C Digital 323CI is offline   Reply With Quote
Old 10-04-2010, 06:56 PM   #5
WSTO
Past Site Sponsor
Thanks Chad,
It's one of best combo's out there for a stud conversion.
affordable, looks great and made from the best stuff on Earth
Old 10-04-2010, 11:53 PM   #6
mcr_driver
My Ride: my favorite two feet
this or the bbs...thoughts and recommendations between the two kits?
mcr_driver is offline   Reply With Quote
Old 10-07-2010, 09:44 AM   #7
WSTO
Past Site Sponsor
Honestly, they are both great products. But we have listed the anodized red BBS lug nuts for any BBS wheel owners, who want to convert to stud + lug nuts, and the Wheelmate studs are the only ones on the market that fit perfectly for these closed end BBS lug nuts, and are readily available for purchase. The quality of the Kic's R40 lug nuts is unmatched. They have a high quality finish that won't chip off, mar and feature a 2-piece conical ring that spins freely so you can install your wheels without damaging the finish.
Old 10-07-2010, 04:25 PM   #8
m3 guy
My Ride: 2001 e46 m3
These project kics lugs are so tempting
*2001 E46 M3 Oxford Green Metallic II-Cinnamon*
*AST*Work*VRS*UUC*RE*Apex*Scorza*SS*Brembo*
m3 guy is offline   Reply With Quote
Old 10-08-2010, 06:29 PM   #9
Dr.U
My Ride: 2004 CB M3 SMG II
Send a message via AIM to Dr.U Send a message via MSN to Dr.U Send a message via Yahoo to Dr.U
I already have the Macht Schnell studs, and they're awesome!
And I've also been looking for a set of R40 lugs. Can you please PM me the price on a set of R40 lugs with locks? I want to use these to replace the custom powdercoated Blox Racing lugs I used to have.
Dr.U is offline   Reply With Quote
Old 10-08-2010, 08:18 PM   #10
M3_POWER
My Ride: is better than yours
Can you please PM the price for the kit please. Any pics of this set up with some wheel on?
M3_POWER is offline   Reply With Quote
Old 10-11-2010, 11:48 AM   #11
acpstunts
My Ride: E46 330ci / E53 X5
Also interested in a price for the kit! thanks
acpstunts is offline   Reply With Quote
Old 10-11-2010, 07:01 PM   #12
WSTO
Past Site Sponsor
Indeed, they would look super sweet with your new set up.
I can assure you that the Project Kics R40 might be the right set up/look you are looking for. Sent you a PM.
Sure, sent you a PM.
Here's the Project Kics R40 with Macht Schnell 75mm stud kit installed with Yokohama/AVS F7 Forged wheels:
PM'd!
Old 10-13-2010, 05:55 PM   #13
m3 guy
PM me a price for the project kics
Old 10-18-2010, 03:52 PM   #14
0-60motorsports
My Ride: E30 325ic & E46 M3
Send a message via MSN to 0-60motorsports Send a message via Yahoo to 0-60motorsports
Look great!
EURO 04 M3: GC Coils, Eibach Sways, PF RTABs, RE RCAs, INTRAVEE II, Black Roundels, ///MFEST Badges, Depo's, VCSL Bumper + Race Lip + CF Trunk + CF Rear Diffusor + CSL center console, DIETZ TV in Motion, SS Stepped Headers, SS Catless S & Res X-pipe, SS Race, Z8 Starter Button, Lamin-X, OEM CSL Steering + CSL interior, OEM CSL Intake, EVOLVE Alpha-N Tune, BBS CH's, FX-R 3.0's, ST40's, DINAN Rear Strut Brace, BW Oil Cooler, 3.91 gears
0-60motorsports is offline   Reply With Quote
Old 10-31-2010, 04:17 AM   #15
0-60motorsports
Whats the price on the Project kics conversion kit?
Old 11-02-2010, 05:12 PM   #16
WSTO
Past Site Sponsor
Sent you a PM, but your box is filled.
You can shoot me an email: sales@wheelsto.com
Old 01-15-2011, 11:53 AM   #17
ault786
My Ride: 330ci
Price inquiry
Can I please get a quote for the Kics R40 Neo Chro Racing Composite Lug Nuts & macht schnell competition wheel stud conversion also I am local and am wondering how much would you charge to mount and balance all four tires on my 18" wheels. thank you
ault786 is offline   Reply With Quote
Old 03-15-2011, 05:42 PM   #18
05lagosM3
My Ride: 05ILB ZCP M3
wheel stud kit and RC40 lugs
Hi,
Can you provide me with a quate for the Macht Schnell competition wheel stud kit for my E46M3 and a seperate price for the RC40's to 98230?
Todd
05lagosM3 is offline   Reply With Quote
