Go Back   E46Fanatics > Tuning & Tech > Suspension & Braking
Old 10-02-2010, 01:09 PM   #1
5ynd1cat3
My Ride: swagger wagon
question about cup kit
I'm going to be ordering my cup kit from Jlevi this week and wanted to know if there was anything else related to the strut/spring assembly that should be replaced when doing the swap. I have a level 2 suspension rebuild kit from ECS that has new control arms, bushings, endlinks and tie rods. I also picked up some M3 RTABs and Vorschlag limiters for the back as well as new RSMs and reinforcement plates. Would it be beneficial to replace the strut hats in the front? I'm assuming I'd have to carry these over from the OEM assembly. My goal is to put the front portion of the cup kit together before I remove the old struts/springs so I can just pop them in instead of wrestling with 10-year-old struts for the sake of a couple parts that need to be carried over. Any insight? This is the diagram I was looking at. I'm guessing that most of it needs to be reused, at least that's how it was in my E36.
5ynd1cat3 is online now   Reply With Quote
Old 10-02-2010, 04:19 PM   #2
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
Hey there,
Typically you can reuse the factory front strut hats but if yours are particularly worn, it may be worth it to replace.
Old 10-03-2010, 10:59 AM   #3
5ynd1cat3
Hey great Nick, thanks for the info. I'm not sure if they're worn or not but for like $11/ea I just might get new ones. Looking to order on Monday or Tuesday. You have the sport cup kits in stock? Wanting to lower the front ~1.5" and the rear ~1.2".
Old 10-04-2010, 05:40 PM   #4
jamex
My Ride: 2005 325Ci
You're talking about the front shock mounts? Where did you find them for $11?
jamex is offline   Reply With Quote
