Sponsored by BAVSOUND
Old 10-03-2010, 10:20 PM   #1
330iZHPftw
My Ride: 2004 330i ZHP, SV650
Three Amps / audio upgrade
am planning out my audio upgrade to my sedan with HK -- question regarding amps..
am planning on running three amps:
-1x 1200w 2 ch amp to power two 10" subs (rms 300 watts per sub)
-1x 2 ch amp to power front component speakers (rms ~100 watts per channel)
-1x stock tiny HK amp to power rear speakers
am I going to have any battery / power issues running three amps like this? should I completely remove the HK amp and run a 4 channel amp to power front components and rear speakers instead?
thoughts / comments appreciated
330iZHPftw is offline   Reply With Quote
Old 10-04-2010, 11:16 AM   #2
Mulatto325
My Ride: 325ci convertible
I don't have the hk system. But i went with 2 amps 600x for the sub and a 125x4 for my mids and highs. No problems with the stock bat but mine is only a year old. Plan on replacing your bat more frequently. If you get a new bat make sure it has a 36 month free replacemen. I gurantee you will have to replace it brfore the 36 months.
My tops down, its upset.
>>>Mulatto325<<< Build thread
http://forum.e46fanatics.com/showthr...087&highlight=
Mulatto325 is offline   Reply With Quote
Old 10-04-2010, 01:53 PM   #3
330iZHPftw
thanks for the advice I appreciate it
Old 10-04-2010, 05:14 PM   #4
jinxie
My Ride: 2000 BMW 323ci
if you're replacing all of your speakers i would axe the hk amp and go with a 4-ch amp.
jinxie is offline   Reply With Quote
Old 10-05-2010, 04:52 PM   #5
330iZHPftw
thanks, but I was planning on keeping the HK amp to run rear speakers and front mids
Old 10-05-2010, 05:35 PM   #6
jinxie
well, you asked
i meant if you are using aftermarket speakers, i wouldn't use the HK amp because of the impedance issues. if you're going to do a true upgrade, you might as well replace the crap paper speakers...
i myself am going with a (60x4 +1000x1) 5-channel amp, nice, clean, simple & takes up less space, less wiring, no current draw issues. i'm trying to conserve my trunk space to retain easy access to my spare tire. okay, so that's my 2 cents
Old 10-05-2010, 06:39 PM   #7
330iZHPftw
well, you asked
cents
yeah yeah forgot I included that..
I am trying to do somewhat of a budget upgrade / don't want to tear apart the entire system as I'm unsure as to how long I will keep the car..
my current plan is to put new components in the front to replace tweeters and midbasses with their own 2 ch amp & 2 shallow mount 10" subs (in homemade BSW style box) in trunk with their own 2 ch amp, leave all other stock HK crud in place
amp, amps, hk upgrade, sedan
