///M3 Forum
Old 10-05-2010, 03:38 PM   #1
M3_POWER
My Ride: is better than yours
*Hmm Instrument Cluster and Gauges Is Not Working, Great. What Can It Be?*
Well today when I started the car, the top three lights on my cluster light up (high beams, oil, and forgot the one left of the high beam). I turned the car off and back on, and to my surprise, nothing on the instrument cluster light up anymore, along with the gauges being dead (no tach, speed and coolant temp pegged to the right in the red). I'm sure the coolant gauge does that by default correct? My AC is acting weird now as well. It works, but the air isnt very cold (even on 59). Everytime I turn off the car and start it back up, the ABS and airbag light will turn on and goes away like it normally does. Then the same problem occurs, no displays on the cluster. I'm going to check the fuses, but I don't think it's that because the ABS and airbag light comes on then off when I start the car. I'm wondering if it's due to me hitting an animal that ripped my front bumper off and knocked some wiring around from underneath a few weeks ago. Any help would be really appreciated!
M3_POWER is offline   Reply With Quote
Old 10-05-2010, 07:15 PM   #2
ayogpradhan
My Ride: E46 M3&MKIV TT Supra
Why don't you try unplugging and resetting the cluster?
ayogpradhan is offline   Reply With Quote
Old 10-05-2010, 09:32 PM   #3
M3_POWER
How do you do that?
Old 10-06-2010, 02:22 AM   #4
ayogpradhan
this might help you a little
Old 12-26-2010, 09:52 PM   #5
-z0sick-
My Ride: z06
Ok so the same thing happened to me this morning. As some of you may know we've had a crazy amt of rain here in socal lately and I think that the moisture may be a culprit. Here are what my symptoms where and what I did to fix it:
Symptoms
* Speedo, Tach, Gas, Coolant Temp, MPG, Odo, gauges not working
* None of the steering wheel buttons are working
* Turn signals not working
* Fan works but A/C does not
* Radio works
* ABS and Seat Belt lights work
* Instrument cluster lights up
How I fixed it:
Tried to perform the Instrument Cluster Self Test (hold down the trip button, turn key to position 1) but that didn't do anything. VERY IMPORTANT: I then left the key in position 1 then opened up the fuse box and checked fuses 10, 34, and 43 by taking them out and putting them back in. All the fuses were fine BUT when I took out the last fuse (43) and put it back in I heard this strange motor sound and then magically the instrument cluster started working.
So leave the key in position 1, pull out and put back in each fuse one-by-one and see what happen
-z0sick- is offline   Reply With Quote
Old 02-03-2013, 06:21 PM   #6
demolanike
My Ride: bmw
I WAS DRIVING MY 2003 BMW 330i TODAY AND ALL OF A SUDDEN THE BRAKE AND ABS LIGHTS ON THE CLUSTER CAME ON. I SWITCHED OFF THE ENGINE AND SWITCHED IT BACK ON, THOSE TWO INDICATOR LIGHTS WENT OFF AND AFTER SOME ,MINUTES IT CAME BACK ON AGAIN. CHECKED THE BRAKE OIL, BRAKE PADS EVERYTHING LOOKS FINE. SOMETIMES THE TWO INDICATOR LIGHTS WILL CHANGE FROM RED TO YELLOW. NOW AS I WAS COMMING BACK ON MY JOURNEY. THE ODOMETER GAUGE AND THE FUEL ECONOMY GAUGE STARTED ACTING ERRATIC AND AFTER SOME TIME ALSO STOPPED WORKING. WE HAD A SNOW STORM YESTERDAY AND IT ALSO RAINED ALSO. COULD IT BE BECAUSE OF THIS OR SOMETHING ELSE. I CHECKED THE FUSES CONTROLLING THE INSTRUMENT CLUSTER, ALL THREE FUSES ARE FINE. WHAT DO I DO? DOES ANYONE HAVE THE ANSWER?
demolanike is offline   Reply With Quote
Old 02-04-2013, 02:06 AM   #7
TerraPhantm
My Ride: M3 & ZHP
Coolant pegged to the red means the cluster lost communication with the DME. I would check the wiring and fuses
Old 02-06-2013, 09:19 AM   #8
kaput
My Ride: 2002 M3 SMG
Send a message via AIM to kaput
Vehicle Speed Sensor
2002 M3
kaput is offline   Reply With Quote
Old 05-03-2013, 06:08 PM   #9
M3FlyMe
My Ride: ///Mm Good
Send a message via AIM to M3FlyMe
Man this site/thread just saved me. Was driving to Albany from Syracuse and halfway there my turn signal indicators failed and my seatbelt light came on, even though it was buckled. Stopped at a rest area and checked them outside and they were working. So I continued the trip. Man I was dreading bringing it in to the dealer. Pulled fuse 43 and as soon as I did heard a motor/ratchet sound. Everything seems to be fine now. This is my go to first for anything that goes wrong with the ///M.
M3FlyMe is offline   Reply With Quote
Old 09-28-2015, 07:40 PM   #10
GoodEnough
My Ride: '06 & '11 M3 ZCP
Symptoms
* Radio works
How I fixed it:
Worked Thanks Alot!!1
2006 M3 ZCP - 2011 E90 M3 ZCP
GoodEnough is offline   Reply With Quote
Old 01-04-2016, 10:02 AM   #11
dino71
My Ride: 2003 BMW 330i
I hope your fix works Sick, this crap happened to me this morning.
dino71 is offline   Reply With Quote
Old 01-17-2016, 10:14 PM   #12
Nolimit_Trini
My Ride: 318i 2005 E46
Symptoms
* Radio works
How I fixed it:
This happened to me just this morning - and its so frustrating because i am about to sell the car and i just spent a lot of money on suspension, steering and engine... now this... i really hope it works...
Nolimit_Trini is offline   Reply With Quote
Old 03-22-2017, 11:19 PM   #13
superchaos
My Ride: 2001 325i
I have tried a lot of things
The only lights that are working are the e-brake, airbag, and ABS. The cluster was working before the battery went dead. I ended up jumping it from the dead battery and driving it about 15 miles to my house.
I have tried the battery cable reset, Key in Pos1 and removing and replacing 10, 34, and 43.
Same thing in Pos2. The cluster is back lit when I turn the lights on. The blinkers work but the cluster indicators for the blinkers do not work.
The car starts, runs and drives like normal. Just the cluster does not work.
I want to try putting in a different cluster just to see if it reacts (to make sure my existing one isn't shorted out).
superchaos is offline   Reply With Quote
Old 04-20-2017, 06:23 PM   #14
scottjoh
Modded ///Member
My Ride: '99 323i & '02 540i
superchaos, sounds like your cluster is dead and needs to be repaired. I've been seeing a lot of cluster lately with similar problems. Dead, except maybe the airbag or ABS lights.
It may work again after a power cycle, but, will go out again. The problem is going to get worse.
scottjoh is offline   Reply With Quote
Old 04-20-2017, 06:44 PM   #15
superchaos
My Ride: 2001 325i
Started working!
I was doing some more work on the car. I left the positive hooked up and removed the negative cable. I left it that way overnight. I started it up the next day and the cluster was working flawlessly.
I took it in to BMW for an airbag recall and they reset the airbag light for me.
