Sponsored by BimmerWorld
Old 10-05-2010, 05:17 PM   #1
Tate325xi
My Ride: 325xi 5MT
Metallic banging noise from front brakes when braking
My car has recently started making a metallic sounding clanking noise from the front brakes whenever I brake. The sounds increase the harder I brake. I turned off stability/traction control, and that helped a little, but I can't figure out what it is doing. Anybody know?
-Tate
Originally Posted by 217Bimmer View Post
sometimes i'm into it and my one hand gets tired, i try switching, but then it's like someone with lou gehrig's trying to peel a carrot.
Tate325xi is offline   Reply With Quote
Old 10-06-2010, 10:39 AM   #2
Tate325xi
My Ride: 325xi 5MT
bump.
-Tate
Old 10-06-2010, 03:10 PM   #3
BimmerBrakes
The Brake Newbie!
My Ride: 2005 ZHP BMW
Send a message via AIM to BimmerBrakes
I would check FCAB, Then the Control Arms, then Brakes and etc...
-Anthony@BimmerBrakes
BimmerBrakes is offline   Reply With Quote
Old 10-07-2010, 09:28 AM   #4
Tate325xi
My Ride: 325xi 5MT
took it to my indy yesterday, should be finding out today what the issue is.
-Tate
Old 10-07-2010, 10:23 AM   #5
BimmerBrakes
The Brake Newbie!
Sounds good Keep Us Posted
Old 10-17-2010, 11:37 PM   #6
AMCINK
My Ride: 2000 323CI
Any update on the indy shop findings?
AMCINK is offline   Reply With Quote
Old 10-18-2010, 02:31 PM   #7
Tate325xi
My Ride: 325xi 5MT
yeah sorry forgot to post. turns out the brake pads were more or less non existent. got it in just in time though, and the rotors were fine.
-Tate
Old 10-18-2010, 03:07 PM   #8
Fry-man22
My Ride: 2003 BMW 330i Sport
If they were that worn you should have seen a light come on indicating they were done.
If you didn't then you need to check with the person who did your brakes as to why the sensor didn't go off. BMW pads have NO metal shim that contacts the rotor when the pad is worn - this shim is what gives that annoying squeal and makes you check your pads. Since they are not on BMW pads the electronic wear sensor becomes more important as you don't know there is a problem until you drag a pad on the rotor.
Fry-man22 is offline   Reply With Quote
Old 10-18-2010, 03:11 PM   #9
Tate325xi
My Ride: 325xi 5MT
yeah i did have that light... just didn't realize it until after i took it to my indy
-Tate
brakes
