Suspension & Braking
Have some questions about suspension or brake setups for your E46 BMW? Get all your answers here! |
#1 |
Annoying Suspension Chirp
I've seen a few posts regarding this but no definitive resolution. I'm getting a chirping sound from my passenger front suspension when I drive over sharp bumps. A big bump doesn't trigger it but expansion joints, etc. do. It's pretty noticeable with the windows or top down and is really annoying. I have newer Meyle arms and bushings and replaced the sway bar links with Febi replacements about 2 mos. ago. I didn't hear the noise until about a month after replacing the links. Has anyone experienced this and been able to pinpoint the source? I don't have any loseness or suspension performance loss, just the annoying noise.
#2 |
I have it too, I just replaced my meyle control arms with bushings and my sway links are on the way maybe it is the tie rods or the strut mount?
#3 |
my friend's dodge has this so i'd be interested in the resolution as well...
#4 |
Has anyone experienced this with Meyle sway bar links? I wish I would have tried them vs. the Febi/Bilstein. It seems strange that this started within weeks of replacing my worn factory links.
#5 |
i hear this sound every so often from the passenger side too... my FCAB's and gang are bad so i was hoping that was the cause... guess not...
somebody help us
Mods
Exterior- M-tech II front, M3 Lip, Predator Chromiums 6000K, 6000K xenon, matching fogs, 30% tint, Eagle Eye LED's, Staggered 19" CSL's w/ Falken 452's Performance- CF Dinan CAI, 3.38 Diff, Ebay Headers Interior/Sound- Tri-M3 wheel, Leather ///M shiftknob, DICE iPod integration, JL Audio 10" Whoofers, Custom Box, JL Audio 250/1 Amp ![]() |
#6 |
Same here, rear, passenger side...annoying, but only when window is down and music not cranked up....hahaaaa.....
#7 |
I have it in the front and rear
#8 |
I'm amazed that so many hear it but no one has figured out the cause. I'm pretty certain it's not a serious issue so it's definitely low priority; just a nuisance. I'm tempted to hit my links and sway bar bushings with Dupont teflon spray to see if that makes a difference.
#9 |
I jstarted hearing a chirp in the rear passenger side, too.
Haven't noticed it in a few days, so maybe it was just the hot weather....
#10 |
Even the cicadas can't mask the chirp. It's driving me nuts. Anyone solve this? I've asked Ruben at Desert Motorworks to quote the Meyle stabilzer bar links. I might try swaping out the Febi and see if that solves it.
#11 |
hahha my friends e36 used to get it. He doesnt get it anymore i wonder what he did.
YEHMEN
E46 m3 - RIP 06 STI - Sold E36 m3 - Current |
#12 |
its my opinion that this could very well be normal. I occasionally hear it on my ZHP also. Its possible that its just the shock absorber compressing.. the liquid/gas being shot through the holes in the internal plate that dampens the forces.. If you look at a cutaway of a shock you'll know what i mean.
#13 |
I have this problem too! Someone told me that it could be the spring pads going bad. Those rubber pads wear down and let the springs rub against the metal mounts causing the squeaking/chirping noise.
#14 |
It could be so many things, you really need to get out of the car, move the suspension, and try and track it down.
It could be as simple as greasing the sway bar bushings, or as complicated as replacing your control arms. |
#15 |
UPDATE:
I figured mine out, it was the brake pads, they had play. The clip in the rear had not enough tension and the one in the front BMW charged me ~$25 for it.... a piece of metal that should be no more than $5, but okidoki...... |
#16 | |
I'll pick up a couple of clips and replace the fronts and report back afterwards. Thanks for the follow-up information on this. |
#17 |
I will check mine but i dont think this is my problem
#18 |
I haven't bought the clips yet but I noticed that I can easily flex the clip off the caliper on the fronts with my fingers but the backs are super tight; I can't budge them. If the fronts are that lose, it seems reasonable that the caliper would move in the carrier over sharp bumps. I'm picking up the clips tomorrow and will report back.
#19 |
FIXED!!
I bent the clips and put grease on the back of the pads without taking them out. noise is gone! |
#20 |
The new clips eliminated 90% of my chirp. When I compared the original clip with the new part, there was about a 1/4 inch difference in the position of the end of the clip that would rest on the top of the caliper. This explains the reduced tension. It may have been an option to bend the clip back but for $30, I put two new clips on. I do still get an occasional chirp very infrequently over really harsh bumps but I'm certain that's from the pads needing some anti-sqeal. It's not a surprise considering how noisy these Axxis pads have been. The dealer gave me (free
) a can of graphite based lubricant they use on factory pad backing plates to absorb squeal so I'll give that a try and see if the chirp completely disappears. |
