///Official BMW Performance Intake & Strut Bar & Everything Else Thread - Page 13 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 4.50 average.
Old 10-14-2010, 11:31 AM   #241
OrientBlau
My Ride: 2003 330i
Understand that BMW does things by the book and ensures that certain perfunctory steps are taken. That is why they list things like disconnecting a battery for an AI swap. They are tailored for the dealer and are more inclusive than necessary. It also ensures that the dealer is making any necessary DME updates and charging the customer accordingly. Using common sense, why would a strut bar require any flashing or coding. How would the computer know you have a strut brace on and how would it compensate, anyhow.
OrientBlau is offline   Reply With Quote
Old 10-14-2010, 11:50 AM   #242
serge_ua
My Ride: 330i ZHP stick
Originally Posted by shanneba View Post
The last page of the instructions says:
7. Concluding work and coding
This retrofit system does not require coding.
Connect the battery
Conduct a brief test
Thanks man! They must be using a template for that... I have a couple more questions if I may. I am OK with cutting plastic, cables, and insulation. But for the life of me, I cannot figure out how would you connect positive terminal bracket after swapping everything 180 degrees. The cable is coming from the right (all relative to you when you stand in front of an engine compartment) - see my picture, and after swapping in the diagram it is conveniently coming from the left... DO I just put the cable on top on top of the rubber stripping? It does not seem to be extendable...
Another question: to pull up the cover of positive terminal bracket (per instruction), it seems to me that I need to peel the rubber stripping of the metal partition - it seems glued.
And the last one. 35 Nm is 26 ft-lb
http://www.thetoolhut.com/Torque-Con...sh-Metric.html
Whereas the instructions on putting M3 strut bar says 18 ft-lb:
http://www.bmw330ci.net/projects/strutbar.php (step 8). WHich one is true?
Name:	IMG_0161 (Small).jpg
ID:	379619   Click image for larger version
serge_ua is offline   Reply With Quote
Old 10-14-2010, 12:21 PM   #243
tanzi
My Ride: 02' 325i
It is lightly glued, just pull it off it will come off don't worry, and it goes back on easily too. Just whatever you do don't forget to retool the flux capasitor that's connected to the doohicky in line with bmw specs
tanzi is offline   Reply With Quote
Old 10-14-2010, 12:26 PM   #244
OrientBlau
My Ride: 2003 330i
I've pulled off those rubber seals on top of the partitions many times. Its fine. Just pull up and push back down. No need to even use glue.
The battery terminal box is flipped and you switch the cables. You have one on each end which attach to the box. There are two battery connections in the box. You reverse them.
Old 10-14-2010, 12:40 PM   #245
3KGT325XI
My Ride: 325xi
No intakes left ugh! I guess Afe route it is
3KGT325XI is offline   Reply With Quote
Old 10-14-2010, 12:57 PM   #246
Jmanscotch
My Ride: makes my pants tight
^ You check with other suppliers?; bmwmercedesparts.com, getbmwparts.com
-Jake
2004 325CI - 2003 3.0 Z4 - 1994 325i - 1967 1602 - 2008 328XI - 2009 135i - 2007 Jeep Wrangler - 2014 *Loading*
Jmanscotch is offline   Reply With Quote
Old 10-14-2010, 12:59 PM   #247
OrientBlau
My Ride: 2003 330i
I wonder if dealer sponsors like Faulkner and Tischer get first dibs or priority on the inventory of BMW parts.
Old 10-14-2010, 01:02 PM   #248
BMWPartsSource
Internet Sales
BMWPartsSource's Avatar
My Ride: n/a
who said there is none left !!!!!!!
I STILL HAVE THEM !!!!!!
BMWPartssource.com
BMWPartsSource is offline   Reply With Quote
Old 10-14-2010, 01:02 PM   #249
BMWPartsSource
Internet Sales
My Ride: n/a
What do you mean?
BMWPartssource.com
Old 10-14-2010, 01:10 PM   #250
OrientBlau
My Ride: 2003 330i
Originally Posted by Patrick- BMWPartsSource View Post
What do you mean?
I imagine that you guys (dealers) get priority from the warehouse or supplier for BMW parts. Like if a third party vendor needed a part and there was only one left, it might go to BMW instead of the 3rd party retailer. I could be wrong. Just something I would surmise.
Old 10-14-2010, 01:16 PM   #251
Gator325
My Ride: 2004 BMW 325Ci
Patrick, I can't find the CF strut brace on your website. What is it listed under?
Gator325 is offline   Reply With Quote
Old 10-14-2010, 01:17 PM   #252
Mulatto325
My Ride: 325ci convertible
here are my before and after pic's took me about 30min easier then i thought but i did have to borrow a dremel from a friend
ID:	379642   Click image for larger version
My tops down, its upset.
>>>Mulatto325<<< Build thread
http://forum.e46fanatics.com/showthr...087&highlight=
Mulatto325 is offline   Reply With Quote
Old 10-14-2010, 01:26 PM   #253
BMWPartsSource
Internet Sales
My Ride: n/a
Shoot me a email and i will just do it over the phone !! pcasey@bmwpartssource.com
BMWPartssource.com
Old 10-14-2010, 01:32 PM   #254
serge_ua
OrientBlau, tanzi, Mulatto325 - thanks a bunch guys!!! Looks like I can do it after all Just ordered the CF strut brace from Patrick - can't wait to get it!
Old 10-14-2010, 01:38 PM   #255
OrientBlau
My Ride: 2003 330i
You know, I'm often intimidated initially by various DIYs, but once you get in there and begin working, the bark really is worse than the bite. Its usually much easier than one thinks, especially when its your first time. After doing a few small jobs, you build confidence and can tackle more complex repairs more easily and confidently. When it all comes down to it, the DIY work isnt difficlut, but it is time consuming and kills your back.
Just read as many DIYs as you can and ask questions. Having a Benltey manual or a TIS CD ($10 on ebay) helps. My approach is that I look DIYs over until I can visualize every step in my mind. This way, I literally just open the hood and start wrenching without any instructions. Its all been burned into my memory, the steps and torque values, etc.
Old 10-14-2010, 01:52 PM   #256
shanneba
My Ride: 2003 330Ci
Did anyone order a spare air filter for the Intake?
I was wondering if it comes installed on the plastic piece. Seems like that would account for the extra price.
I took the air filter out of the plastic and it looked like a standard BMW E46 air filter. The plastic part just seems to hold it in a circular shape and connect it to the top of the air box.
I didn't actually measure the filter part, should have compared it, I'll do that when I replace it next time.
I was just thinking maybe you could put an AFe Pro 5R filter in the Performance Air Intake.......
Join BMWCCA
Old 10-14-2010, 02:17 PM   #257
tanzi
My Ride: 02' 325i
I JUST called my buddy at my local bmw dealer and his computer system is showing 342 of the 325i intakes in NA
Old 10-14-2010, 02:25 PM   #258
N89
My Ride: 330Ci
Wow, that's not a lot.
N89 is offline   Reply With Quote
Old 10-14-2010, 02:49 PM   #259
tanzi
My Ride: 02' 325i
Not really but other smaller disstribution centers will have some too. I think there are plenty to go around
Old 10-14-2010, 03:34 PM   #260
N89
My Ride: 330Ci
I think even if they were all picked up you would still have a VERY hard time trying to find someone else with a matching setup, even if the figure was 1,000... although it sounds like a lot on paper, in reality that's nothing compared to the millions of enthusiasts out there and the even larger amount of BMW owners in the US alone. Unless of course you meet someone else from this thread/site.
bmw performance, carbon fiber, filter, intake, performance, strut bar, strut brace
Rate This Thread
