Thread Tools Search this Thread Rating: Thread Rating: 5 votes, 4.20 average.
Old 04-28-2011, 09:57 AM   #1081
robt_sf
My Ride: 2003 330Ci
Does anybody else still have the Carbon Performance Strut Tower brace in stock?
robt_sf is offline   Reply With Quote
Old 04-28-2011, 11:41 AM   #1082
e46rage
My Ride: 330ci 2001
Am looking for the strut too
Sent from EVO 4G using biMM3R APP.
R.I.P. E46RAGE.
e46rage is offline   Reply With Quote
Old 04-28-2011, 11:52 PM   #1083
Qwiksand99
My Ride: 2001 330ci
I have mine, havnt installed it yet, not sure if I'm keeping it, what's it worth to you??
Qwiksand99 is offline   Reply With Quote
Old 04-29-2011, 10:12 AM   #1084
aradeath
My Ride: 330Ci
Send a message via AIM to aradeath
I have mine as well.
| 2006 e46 330Ci ZHP| [Sponsors] - ASPTuning - VMR | Wheels
| aFe CAI | eVo Sport UD Pulleys | Eisenmann Cat-back Race Exhaust | Powerchip Software |
| TechniK Gen3 Headers | Vorsteiner CF Hood | HKS Hypermax RS Coilovers | BMW Perf SSK |
| Sparco Evo2 seats | UUC LTW Flywheel & Cerametalic Clutch | Hamann Front Lip | Custom Willwood BBK |
aradeath is offline   Reply With Quote
Old 05-13-2011, 05:30 PM   #1085
mrmaico
My Ride: 04 ZHP, 05 R1200 GS
Success! I found an alternate filter to fit the Performance intake.....a Napa Gold 6301. Other than being about 1/8" narrower it's a perfect match. I even pulled my intake apart and test fit it. It takes a little more finessing to get it seated perfectly but once it's screwed down it will work just fine. It comes with a wire mesh layer on it and I think if you wanted to snip off that mesh it would be just as easy to fit as the $55 BMW filter. This one was $9!
I wish now I wouldn't have ordered a spare from BMW with my intake.
Barry
In this last pic I didn't have the 4 bottom screws all tightened completely, if I had the 2 top screws would have sat flush. Be careful when tightening these two down so that you don't break those two fragile looking ears off.
mrmaico is offline   Reply With Quote
Old 05-13-2011, 06:58 PM   #1086
Bake
My Ride: AW F10 535 M-Sport
Great find, I need to replace my filter soon. I wonder how the airflow thru this compares to the BMW unit. Waiting for some more people to chime in.
Sent from my iPhone using BimmerApp
Bake is offline   Reply With Quote
Old 05-13-2011, 07:27 PM   #1087
nick330xi
My Ride: 2001 330xi
about to place my order with bmwpartssource for the intake......any last comments or concerns i should know about this before i get it?
nick330xi is offline   Reply With Quote
Old 05-14-2011, 06:27 PM   #1088
mach.schnell
My Ride: 08/2000 330Cic x2
But aren't you showing comparison pics to the stock air filter? Isn't the performance filter curved as in your last shot? Where are comparison pics to that?
mach.schnell is offline   Reply With Quote
Old 05-14-2011, 06:55 PM   #1089
Mdot Fdot
My Ride: 2005 BMW 330ci
^^ Nope all the filters are completely flat when removed. That is an accurate representation of both the filters side by side
Mdot Fdot is offline   Reply With Quote
Old 05-14-2011, 07:34 PM   #1090
mrmaico
That last shot is showing the Napa filter installed in the cage.
Correct, it's not curved until you install it in the cage. I tried cutting the mesh out of the Napa filter today and it wasn't hard to do but you need to be careful so you don't cut the filter itself. I think I'd recommend just leaving the mesh on, it's really not that stiff. It's just easier to form the non-mesh filter into the cage and that cage seems kinda fragile. Be careful not to break any part of it because it looks like it's not available separately.
Old 05-16-2011, 10:43 AM   #1091
AL.e46.330ci
My Ride: 01 330ci 5MT
I'm also looking to order the BMW performance intake for my 01 330ci. Is it compatible with the 01 with no problems.?
Also what's the best place to order these.?
Thanks.
AL.e46.330ci is offline   Reply With Quote
Old 05-16-2011, 10:57 AM   #1092
OrientBlau
My Ride: 2003 330i
Maybe a group buy?
I'd buy two BMW OE filters if the price was right.
All truth passes through three stages. First, it is ridiculed. Second, it is violently opposed. Third, it is accepted as being self-evident. - Arthur Schopenhauer
OrientBlau is offline   Reply With Quote
Old 05-16-2011, 12:33 PM   #1093
jason330cic
My Ride: 2001 330cic
Success! I found an alternate filter to fit the Performance intake.....a Napa Gold 6301. Other than being about 1/8" narrower it's a perfect match. I even pulled my intake apart and test fit it. It takes a little more finessing to get it seated perfectly but once it's screwed down it will work just fine. It comes with a wire mesh layer on it and I think if you wanted to snip off that mesh it would be just as easy to fit as the $55 BMW filter. This one was $9!.
Barry
I cross referenced this filter with some other part numbers, so these may also work as a replacement:
AC A1233C
CHEVROLET 25099735
FRAM CA7598
NAPA 6301
PURO A24881
WIX 46301
Mann MA1039
It is the same filter in a '94 Chevy Beretta 3.1 V6, so you can use this car as a reference when searching for the air filter.
I checked out K & N but the filter they have will not work because the filter is folded the long way so it will not wrap around the intake properly.
K&N filter not compatible
Jason330cic
jason330cic is offline   Reply With Quote
Old 05-16-2011, 04:57 PM   #1094
mrmaico
Good work. I tried checking all of them and it looks like they will all have the wire mesh on them so it appears there's no getting around that. And just fyi....Napa filters are just a rebranded Wix so there is no need to be leery of using a Napa filter. Wix makes quality filters.
AC A1233C
CHEVROLET 25099735
FRAM CA7598
NAPA 6301
PURO A24881
WIX 46301
Mann MA1039
Old 05-17-2011, 08:45 AM   #1095
mach.schnell
Ya learn something new everyday.
That, I knew.
I am surprised the outer foam edge bends easily enough, though. I thought he may have just cut if off since such can't be readily seen.
Old 05-17-2011, 09:27 AM   #1096
Patrick- BMWPartsSource
Internet Parts Manager
Patrick- BMWPartsSource's Avatar
My Ride: 1995 325i
Originally Posted by OrientBlau View Post
Maybe a group buy?
best I can do is two filters for $104. Sorry guys not much wiggle room on this one.
Patrick Casey
BMWPartssource.com
http://www.facebook.com/FaulknerBMWPartsSource
Patrick- BMWPartsSource is offline   Reply With Quote
Old 05-17-2011, 04:39 PM   #1097
Mr_325
My Ride: 2005 BMW 325i
I've been wanting to get one of these for awhile now but the prices in Canada and on eBay seem steep, anyone recommend a good place to buy from
Anyone know if these are better than the afe intakes
Mr_325 is offline   Reply With Quote
Old 06-03-2011, 08:21 PM   #1098
grandcarrera
My Ride: 330xi 2003
Is it worth it to get OEM Performance exhaust ?
grandcarrera is offline   Reply With Quote
Old 06-03-2011, 09:07 PM   #1099
fmzip
My Ride: 2001 330cic & 530i
Originally Posted by David328Ci View Post
Anyone know if the BMW performance strut brace will fit the e46 m3?
100%=will not fit
Fran
2001 330cic ESS TS2 Supercharger
Follow me on Flickr
My Car is for sale
fmzip is offline   Reply With Quote
Old 06-03-2011, 11:45 PM   #1100
Levim9
My Ride: 01' 325i
Originally Posted by fmzip View Post
100%=will not fit
http://forum.e46fanatics.com/showpos...postcount=1074
Levim9 is offline   Reply With Quote
bmw performance, carbon fiber, filter, intake, performance, strut bar, strut brace
Rate This Thread
