Old 10-07-2010, 05:30 PM   #1
Forcefed M3
My Ride: HPF Stage 2.75
Exclamation Urgent! E46 M3 guys check your differential bolts!
While my car was in the shop getting the transmission replaced, the mechanic noticed that one of my differential bolts was missing and another one was halfway backed out. BMW doesn't put thread lock on these bolts! WTF. It has happened to other people as well. Easy fix with red lock tight. That could really suck to look in your mirror and see your 2 back wheels and your diff changing lanes without you.
http://m3forum.net/m3forum/showthread.php?t=115461
Forcefed M3 is offline   Reply With Quote
Old 10-07-2010, 06:04 PM   #2
MaverickM3
My Ride: gets badge
I guess it's a good thing HpF is changing my diff. They will fix it.
MaverickM3 is offline   Reply With Quote
Old 10-07-2010, 06:05 PM   #3
///M3-QTR
My Ride: IR M3
Couldn't wait until HPF is able to build the transmission ?
You got a new tranny or used ?
///M3-QTR is offline   Reply With Quote
Old 10-07-2010, 06:20 PM   #4
Forcefed M3
Used, my old one will head there for the new syncros.
Old 10-07-2010, 06:25 PM   #5
Greg Ogden
My Ride: HPF 2.5 M3, E36 M3
Send a message via ICQ to Greg Ogden
This is a must! I just had the exact same issue a couple weeks ago. These should be checked every time you change you oil.
Greg Ogden is offline   Reply With Quote
Old 10-07-2010, 07:30 PM   #6
mtran850
My Ride: C6 Z06
That was what have caused my clunking noice awhile back
mtran850 is offline   Reply With Quote
Old 10-07-2010, 07:42 PM   #7
funkboy316
My Ride: 2003 M3 vert
hmmm i need to check mine ASAP, i had my os giken installed shortly after you. if yours had already come lose, mine might have as well.
2003 TiAg HPF stage 2.5 SMG M3 vert
funkboy316 is offline   Reply With Quote
Old 10-07-2010, 08:16 PM   #8
02black330ci
My Ride: spaceship
Puta cheeet!!! I'll check mine out tomorrow, I'll be under the car doing some suspension work. Thanks for giving a heads up.
02black330ci is offline   Reply With Quote
Old 10-07-2010, 08:22 PM   #9
Estoril-E46
My Ride: M3
Which bolts were loose on yours. Half shaft or one of the three mounting bolts.
I'm guessing the half shaft bolts. See this often on stock cars.
The quick but slow car:
www.Precision-Sport.com
Estoril-E46 is offline   Reply With Quote
Old 10-07-2010, 08:29 PM   #10
Forcefed M3
Mounting bolts on 3 of us so far
Old 10-07-2010, 08:34 PM   #11
Estoril-E46
My Ride: M3
Which ones.
Old 10-07-2010, 08:52 PM   #12
Greg Ogden
Which ones.
Mine were the three bolts that mount the diff to the sub frame. Two of the bolts were missing and the last one was half way out. It damaged my sub frame and we had to re-tap it.
Old 10-07-2010, 09:23 PM   #13
ispeedm3
My Ride: e46 m3 TuRbO
thanks checking mine tonight!
[CENTER]
ispeedm3 is offline   Reply With Quote
Old 10-07-2010, 09:39 PM   #14
Forcefed M3
Computer back up! Mine also was subframe.
Old 10-07-2010, 09:53 PM   #15
TaZaM3
Psshhhht M3
My Ride: E46 M3
Mine might had broke because of this as well!
TaZaM3 is offline   Reply With Quote
Old 10-07-2010, 10:19 PM   #16
Estoril-E46
My Ride: M3
It's obvious when even one of the mounting bolts are loose, that's what I don't understand. You should have had an enormously loud clunk very early.
Old 10-07-2010, 10:39 PM   #17
Greg Ogden
I did, I had my mechanic check to see what the issue was and that's what he discovered.
Old 10-08-2010, 12:36 AM   #18
Forcefed M3
mine did also
Old 10-08-2010, 04:50 AM   #19
Tightm3
My Ride: E46 M3
Ditto, Good Call!
My mechanic at Bavarian Specialists diagnosed mine when I complained of a loud Clunking noise, it was the three mounting bolts
Tightm3 is offline   Reply With Quote
Old 10-08-2010, 05:02 AM   #20
0-60motorsports
My Ride: E30 325ic & E46 M3
Send a message via MSN to 0-60motorsports Send a message via Yahoo to 0-60motorsports
Guys check out my threads..........
http://forum.e46fanatics.com/showthr...049&highlight=
http://www.bimmerboost.com/showthrea...-other-updates
If you notice I changed all the bolts and the new diff bolts are different. In the end because they werent tightened to BMW spec they ALMOST came lose but thank God I felt there was something wrong and got it checked out and tightened. You'll find all the Parts in my thread. PLease change out ur diff bolts to the new design.
EURO 04 M3: GC Coils, Eibach Sways, PF RTABs, RE RCAs, INTRAVEE II, Black Roundels, ///MFEST Badges, Depo's, VCSL Bumper + Race Lip + CF Trunk + CF Rear Diffusor + CSL center console, DIETZ TV in Motion, SS Stepped Headers, SS Catless S & Res X-pipe, SS Race, Z8 Starter Button, Lamin-X, OEM CSL Steering + CSL interior, OEM CSL Intake, EVOLVE Alpha-N Tune, BBS CH's, FX-R 3.0's, ST40's, DINAN Rear Strut Brace, BW Oil Cooler, 3.91 gears
0-60motorsports is offline   Reply With Quote
