Old 10-08-2010, 07:24 AM   #21
Hrvat
My Ride: 02 Imola Red M3
This reminds me of 7 out of 8 bolts backing out on the harmonic balancer on my 540i. So lucky that I cought it otherwise had it fallen off, it would have killed everything up front.
PM ME FOR FREE SAMPLES
Originally Posted by roronoah View Post
so 2004 bmw's dont come with a diff?
Hrvat is offline   Reply With Quote
Old 10-08-2010, 10:11 AM   #22
Estoril-E46
My Ride: M3
Originally Posted by Forcefed M3 View Post
mine did also
How did you guys get to the situation where all 3 were loose and damaging threads? Ignore it for a while?
The quick but slow car:
www.Precision-Sport.com
Estoril-E46 is offline   Reply With Quote
Old 10-08-2010, 03:26 PM   #23
Forcefed M3
My Ride: HPF Stage 2.75
It is a well known problem with the e46 M3, per the service manager at BMW of Fife. When they service the car they supposedly check them. Anyways with mine the day I heard the first clunk I took to the guys who installed my tranny, I thought maybe they didn't tighten something down properly.
Forcefed M3 is offline   Reply With Quote
Old 10-09-2010, 11:21 AM   #24
baller2all
My Ride: BMW E46 M3
Originally Posted by 0-60motorsports View Post
Guys check out my threads..........
http://forum.e46fanatics.com/showthr...049&highlight=
http://www.bimmerboost.com/showthrea...-other-updates
If you notice I changed all the bolts and the new diff bolts are different. In the end because they werent tightened to BMW spec they ALMOST came lose but thank God I felt there was something wrong and got it checked out and tightened. You'll find all the Parts in my thread. PLease change out ur diff bolts to the new design.
Part number for the diff bolts?
baller2all is offline   Reply With Quote
Old 10-09-2010, 02:30 PM   #25
0-60motorsports
My Ride: E30 325ic & E46 M3
Send a message via MSN to 0-60motorsports Send a message via Yahoo to 0-60motorsports
Front bolt with washer 33 17 7 840 535
Rear Bolt 23 00 1 222 891. You need 2 of these.
Washer for rear bolts 07 11 9 931 021. 2 of these too.
EURO 04 M3: GC Coils, Eibach Sways, PF RTABs, RE RCAs, INTRAVEE II, Black Roundels, ///MFEST Badges, Depo's, VCSL Bumper + Race Lip + CF Trunk + CF Rear Diffusor + CSL center console, DIETZ TV in Motion, SS Stepped Headers, SS Catless S & Res X-pipe, SS Race, Z8 Starter Button, Lamin-X, OEM CSL Steering + CSL interior, OEM CSL Intake, EVOLVE Alpha-N Tune, BBS CH's, FX-R 3.0's, ST40's, DINAN Rear Strut Brace, BW Oil Cooler, 3.91 gears
0-60motorsports is offline   Reply With Quote
Old 10-09-2010, 02:42 PM   #26
yellowssm
My Ride: 2005 M3
I gotta take a look next oil change.
yellowssm is offline   Reply With Quote
Old 10-09-2010, 02:43 PM   #27
yellowssm
My Ride: 2005 M3
Is this all we need? Im going right now? Approximate cost? torque specs? should we use red loctite?
Old 10-09-2010, 02:45 PM   #28
0-60motorsports
These are the 3 bolts that need replacing. Cant check cost for you right now but you can check it on www.getbmwparts.com, shouldnt be more than $20 im guessing..... GL
Old 10-09-2010, 02:47 PM   #29
yellowssm
My Ride: 2005 M3
is there correct torque specs and should we use red loctite?
Old 10-09-2010, 02:52 PM   #30
0-60motorsports
My master tech didnt use any loctite so I dont recommend it, torque specs are 90 degree angle torque and then 220nm torque I THINK But dont hold me to it. You will need to check with the dealership from where your picking up the bolts or maybe someone on here can help.
I apologize for not having the torque specs and its almost 2300 here so I cant call up my tech now....
Old 10-09-2010, 02:57 PM   #31
yellowssm
My Ride: 2005 M3
just to let you guys know here are my costs (since i work for a dealership) on those parts.
Front bolt with washer 33 17 7 840 535 $5.08
Rear Bolt 23 00 1 222 891. You need 2 of these. $1.15
Washer for rear bolts 07 11 9 931 021. 2 of these too. $.43
Old 10-09-2010, 03:03 PM   #32
0-60motorsports
Excellent!
Sent from my iPhone using BimmerApp
Old 10-11-2010, 12:42 AM   #33
dancccp
My Ride: is on rails
Send a message via AIM to dancccp
anyone get the torque specs?
dancccp is offline   Reply With Quote
Old 10-11-2010, 12:45 AM   #34
CruzBMW
My Ride: 2001 BMW 325ci
Mechanic just want to tweak bolt. Don't trust those ****s for ****. Consumer beware.
CruzBMW is offline   Reply With Quote
Old 10-11-2010, 03:01 PM   #35
dancccp
Anyone know of the most efficient way of tightening the two rear torx bolts?
I have a torque wrench 1/2 drive and my female torx socket is a 3/8, with the adapter on its impossible to fit the tool in unless you have a universal joint, which to my knowledge will not yield a proper torque read on the wrench.
Old 10-11-2010, 04:31 PM   #36
funkboy316
My Ride: 2003 M3 vert
get a 3/8 torque wrench would be best, or a 1/2 inch torx socket.
2003 TiAg HPF stage 2.5 SMG M3 vert
funkboy316 is offline   Reply With Quote
Old 10-14-2010, 01:49 PM   #37
dancccp
gonna have to go hunt one down lol.
I took the hex bolt out and the first 2 threads were significantly damaged, which makes me wonder if the threads in the diff are done. Has anyone had experience with this?
Old 10-14-2010, 02:06 PM   #38
yellowssm
My Ride: 2005 M3
While my car was on the lift my mechanic checked the bolts and they were all nice and tight. I already bought and have all the new bolts and washers, should I even bother changing them out?
Old 10-14-2010, 02:17 PM   #39
yellowssm
My Ride: 2005 M3
by the way we are talking about the bolts that go into the back of here correct?
Old 10-14-2010, 02:29 PM   #40
dancccp
bolts 2 and 3
