E46 Convertible
Old 10-09-2010, 05:58 PM   #1
TroyNVIE
My Ride: Mercedes & Lotus
HELP - Convertible Hydraulic Fluid Burst?!?
All -
I had the top down today, enjoying the nice whether. When I went to put the top up, the following occured:
1) The top went about 3/4 of the way up through it's sequence ("roof" was almost flat, and the clips were maybe 5 seconds away from getting engaged)
2) I hear a "Pshhhh", and then nothing happens.
3) I get out of the car, and I see what appears like a light splash of water-y fluid in the convertible area (under where the boot lid usually covers), as well as two streams of water-like fluid coming from just underneath the car near the exterior.
I drove the car very slowly with the roof slight above the windsheild (i.e. not engaged) and the boot lid up in the air, to my garage (about 2 miles away).
What might this be? Anyone have any experience with it? Any help is much appreciated! Thanks.
TroyNVIE is offline   Reply With Quote
Old 10-09-2010, 06:05 PM   #2
iansanderson
My Ride: 2001 330CiC
Originally Posted by TroyNVIE View Post
All -
sounds like a hose has burst or a fitting has come apart. You will need to manually lift the top to a point where you can access the top storage area and see where the leak has occurred. report back with pics when you find it. try to flush the fluid out so it doesn't do any damage to the paint. there are drain holes as you have noticed.
Cheat Sheet:
GT1/ISIS/MoDiC = Factory authorized diagnostic system used by BMW dealerships across the world.
NCS Expert = BMW Factory R&D programming tool available on the internet (not intended for the public and not available to the dealership network)
OEM = Genuine BMW part only available from a franchised BMW dealership.
DME = Engine Management Computer
iansanderson is offline   Reply With Quote
Old 10-10-2010, 09:04 AM   #3
TroyNVIE
How do you flush the fluid out?
Old 10-10-2010, 04:13 PM   #4
volkswackin
My Ride: VW's haha
use some sort of degreaser thats safe for paint...thats about all i can think of as its oil so water is no dice..
volkswackin is offline   Reply With Quote
Old 10-10-2010, 05:44 PM   #5
iansanderson
degreaser and a hose should do it. it's not true hydraulic fluid.. rather a mineral oil so it probably won't damage the paint. After you repair it, you will need a bottle of Aral Vitamol ZH-M (convertible top fluid) from the dealer. They should stock it.
Cheat Sheet:
Old 10-10-2010, 06:29 PM   #6
jfoj
My Ride: 330CiC, M5, X5, E93
Check out this tread and you will find the Convertible Top manual with a lot of good info.
http://forum.e46fanatics.com/showthr...ht=convertible
Old 10-11-2010, 06:20 AM   #7
TroyNVIE
Thanks guys. Does this sound like a difficult repair for a mechanic?
Old 02-12-2012, 07:18 PM   #8
fast2fresh
My Ride: E46 convertible
Did u replace the burst cable? Cause i also have a leak, and i need to replace mind. Do u have a part number and picture? Please reply me back at fast2fresh@yahoo.com
fast2fresh is offline   Reply With Quote
Old 02-12-2012, 09:59 PM   #9
caliboy
My Ride: 2004 325Ci
i dont know why but i was under the impression the E46 used mechanical top lift mechanism and not hydraulic. if any of the fluid went on the leather, clean is ASAP! or it will cause stains on the leather.
caliboy is offline   Reply With Quote
Old 02-13-2012, 07:36 AM   #10
gbakerkingston
My Ride: '05 M3 vert, '13 X5D
If found to be a faulty hydraulic cylinder (seal within a cylinder), have the cylinder remanufactured at
http://www.tophydraulicsinc.com/en/
I had two bow tension cylinders overhauled by Klaus. Recommended.
gbakerkingston is offline   Reply With Quote
burst, convertible, hydraulic, leak, problem
