Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 268 votes, 5.00 average. Display Modes
Old 12-01-2012, 08:02 AM   #781
dayusmc
My Ride: 01 325ci & 06 325ci
I was able to get igo to stop having out of memory issues on my D90, here is what I did...
I turned off the 3D map veiw and put.it to 2D, I turned off all those extra tjings that show up on the.map- gas stations, air ports, poi, ect... It seems there was just to much stuff trying to load. My suggestion to anyone having this out of memory issue is to turn ALL the extra stuff off, see if it works without freezing. If it does, start turning back on only the things you really want... Hope this helps!
Kyle
dayusmc is offline   Reply With Quote
Old 01-05-2013, 08:07 AM   #782
Alpine
My Ride: 2002 E46 BMW 330Ci
Originally Posted by jeffb325@DynavinSolutions View Post
It is the "Navi Sound" setting in the radio menu.
I tried this out but when it is enabled, the navi voice is very soft compared to radio/USB, etc. With this disabled, the nave voice is the same volume as the radio/USB, etc. Is there a way to resolve this, to equalize the volume when navi sound is enabled? Cheers...
Alpine is offline   Reply With Quote
Old 01-13-2013, 07:32 AM   #783
bin01123
My Ride: 2001 540i
Anyone have updated maps?
bin01123 is offline   Reply With Quote
Old 01-30-2013, 12:56 AM   #784
aznbeayst
My Ride: TiAg M3 Vert
Send a message via AIM to aznbeayst
ya bump anything new for us old v5 owners =(
GOODBYE: turbo RSX... HELLO: M3!
aznbeayst is offline   Reply With Quote
Old 01-31-2013, 06:59 AM   #785
reshizzo
My Ride: Subaru Impreza
hello,
i have the dynavin and want to start iGO but i get dont start it because of following error
DATABASE CANNOT BE FOUND
i have tried everything but i wont start
any ideas? SYS.txt i got it, changed it to
[folders]
app="StorageCard/iGO"
but same error
please help
reshizzo is offline   Reply With Quote
Old 03-16-2013, 01:22 AM   #786
bin01123
My Ride: 2001 540i
Bad news. I found out there is no map update for us
Sent from my HTC VLE_U using Bimmer App
Old 01-06-2014, 07:13 PM   #787
rocksonrocks
My Ride: 325i
I have Igo Primo 2.4 installed and have 2 issues. The clock is not correct. I can't seem to find anywhere to set it or my time zone. Is this automatic? Also in the manuals I've seen it says current time should be displayed in top left when in map view. I don't have that. Is there a setting for this.
Guidance voice is very low on my Eonon D5150. There are limited settings in the D5150 and I think I have them set to the maximum. Is there any adjustment in Igo for this?
Other than this the software seeems to work great.
rocksonrocks is offline   Reply With Quote
Old 01-06-2014, 08:23 PM   #788
TR4G-
My Ride: '01 325xi, '90 325iC
where did you get your maps? I have everything up and running but the maps
EDIT: for those interested here is a great source of maps: iGO Maps Alot of the links are dead, but you can find some that work. I ended up using a torrent of the 2012.Q4s b/c I dont feel like spending days downloading via file hosts....
TR4G- is offline   Reply With Quote
Old 01-18-2014, 05:17 PM   #789
rocksonrocks
My Ride: 325i
Help my menu's gone
I turned the Nav Menu off in the settings so when I start nav it goes straight to the map. Well, now I don't know how to get it back including the settings menu. Can anyone help with this ? Searched many forums and the manual and can't find any inof on this?
Old 03-23-2014, 08:35 PM   #790
Rezist09
My Ride: 325i sedan
where to get igo primo 2.4
Rezist09 is offline   Reply With Quote
Old 05-29-2014, 08:49 AM   #791
redde44bimmer
My Ride: 2004 Bmw 325ci
I'm in the same boat, am able to run the program but don't have GPS SIGNAL and maps. Any help would be great.
redde44bimmer is offline   Reply With Quote
Old 05-29-2014, 08:55 AM   #792
redde44bimmer
My real issue is that I've downloaded the maps but not sure in how to put the file path. Any help or tutorial would be great.
Old 05-29-2014, 05:37 PM   #793
rocksonrocks
My Ride: 325i
Had the same problem. Eventually found a manual online that helped. I think you have to do a long press on the screen. Maybe in one of the corners. Then of course you have to go into the tools/settings to change it if you want. Sorry I can't help more than that.
Old 06-22-2014, 07:47 AM   #794
timmyy34
My Ride: M3
Igo Primo
Hi Guys
Can anyone please help. I have just go a gps with igo primo installed it works fine but I am unable to get road and street names announced. I have downloaded new voice files and modified my sys.dat file but no luck
I would much appreciate any help
Many Thinks
timmyy34 is offline   Reply With Quote
Old 11-10-2014, 04:20 AM   #795
delmanicomio
My Ride: Ford
hi,
i have an issue so i would be so glad if you can help me.
i'm not riding a bmw, i found this forum while making a search.
i have broken speedometer and odometer car, using a navigation device igo primo based.
perfectly shows my speed.
any possibility so see i much miles i did ?
like odometer device will record my miles log as long as device open.
delmanicomio is offline   Reply With Quote
Old 01-23-2015, 12:56 AM   #796
m3-4aj
My Ride: E46 M3 / F80-M3
Send a message via AIM to m3-4aj
anyone have links to download the latest igo primo
m3-4aj is offline   Reply With Quote
Old 02-13-2015, 11:46 AM   #797
m3-4aj
does anyone have the latest igo primo?? thanks
