Sponsored by BimmerWorld
Old 10-11-2010, 06:49 PM   #1
YOnpds
My Ride: E46
Exclamation Front Camber Plates Installed:
Installed: SPC Front Camber Plates. Corrections up to +3 deg.
Before:
Left Front = -2.1..........Right Front = -3.3
After:
Left Front = -1.2..........Right Front = -1.9
My question: How come the "right front" was only corrected to -1.9 deg. The SPC camber plate was adjusted all the way where we could not move the plate anymore to get more positive?
Is there somewhere else we can adjust the camber? Tie Rods maybe?
YOnpds is offline   Reply With Quote
Old 10-12-2010, 08:23 AM   #2
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Don't think you can adjust it anywhere else. I know height will affect camber. Also, do your plates have a caster setting? Are they both on the same caster setting?
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 10-15-2010, 11:16 PM   #3
YOnpds
My Ride: E46
Yeah I think it does have but the installation setup we followed was strictly for camber adjustments.
Old 11-11-2010, 06:15 PM   #4
My Ride: 2016 Lexus
So you bought camber plates so you can get crappy camber? Why did you end up with less camber?
First off if your camber was that off to begin with WITHOUT plates, you had either of two problems:
Bent control arms
or
a massive drop
i'd go at least 2.5 on both sides with 0 toe.
And no tierods dont affect camber
Old 11-15-2010, 09:15 PM   #5
kuksul08
My Ride: M3
Bent control arms
or
a massive drop
+1 something looks wrong there...
Look at that subtle jet-black coloring. The tasteful thickness of it. Oh my God, it even has a 6mt.
S54 Valve Adjustment Spreadsheet & Info: http://dl.dropbox.com/u/28231781/S54...ent%20info.zip
S54 VANOS DIY Video: http://www.youtube.com/watch?v=9SkT2j3jsU0
kuksul08 is offline   Reply With Quote
Old 11-16-2010, 12:45 PM   #6
ryanwhite74115
My Ride: 2013 Infiniti G37S
Something is broke on the right side...3.3 is redunk.
ryanwhite74115 is offline   Reply With Quote
