Old 10-11-2010, 09:17 PM   #1
TrickTizzle
My Ride: 325i
E46 325i Headers Installed - Dyno Graphs included
Ok guys, if you remember my last thread of my B25 stock dyno at 155whp, I got the car dyno'd after headers to show my 11whp gain. Not too bad for a 325i.
The installation was a breeze, the bolts on the head came off like butter without breaking any studs or such! I did not take of the motor mount, and it is definitely not needed, plenty of room to take off headers.
Disconnecting headers from cat-back was a pain in the @ss. 4 of 4 bolts snapped and then I had to punch the fvck out of it with a pneumatic impact gun, and the damn thing wouldn't budge. I ended up taking a pry bar and pry-ed it off.
I was able to install 15 out of the 16 bolts, the middle bolt on the back header was impossible. I had all sorts of extensions and such available, just not possible at all.
I went back and checked the system for any leaks and such, and it is all ok. No leaks were found.
Connecting the header to cat-back was a b1tch. We used a hydraulic jack also to move the cat-back around, to try to align them up perfectly, it just wouldn't happen. We were MM off for the bolt to catch on to threads, and then I pushed my foot down on the foot hydraulic jack to get more leverage and the whole car got up and moved literally 4 inches to the left off the lift. Now we have to get all the stuff out of the way, lower car, re align, etc. Then after hour and a half of messing around with that last bolt we just used a nut and bolt and it did the trick. Hasn't snapped yet, and no leaks were found.
Make sure you use OEM gaskets and nuts.
Here are some pictures and such below.
Ceramic Coated Header from Anthony @ BimmerBrakes
To anyone that wants to purchase headers, I definitely recommend these, I had no issues what so ever. Everything was a perfect fit, oxygen sensor bungs are actually functional. The sensors screwed right in, and they were perfectly placed.
OEM Catalytic Converters
Notice the difference
M54B25 Engine Block
And on to the dyno graphs
NET GAIN = 11 WHP/ 3TQ SAE CORRECTED
Stock Dyno
Dyno with headers
-Kind of pissed off the guy needed 12 pulls to get 3 clean ones, where as the first guy got 3 good pulls each time...My tires are pretty worn out now.
Overall I'm very happy with results. Love the new exhaust tone. Love the new smell.
No service engine soon light due to o2 sims that work perfectly which were also bought from BimmerBrakes. I got the header install done in approximately 8 hours, BUT I did have the car on the lift ft high, and a professional toolbox with all extensions, pieces, etc.
Very fun install. Not hard at all, but never again.
TC Kline | BMW Performance | Active Autowerke
Old 10-11-2010, 09:17 PM   #2
TrickTizzle
My Ride: 325i
Sorry for delay.
Old 10-11-2010, 09:29 PM   #3
mvrk10256
My Ride: E30 325i
great job. Believe me, you say never again and you will end up having to do it a couple more times, happened to me. I am glad to see some real numbers, guess my butt dyno hadnt lied to me. the torque curve also looks a lot better. enjoy the mod. I am really curious though as to how you did it w/o pulling the mount. Also i amsure if you go in from above you should be able to get the top nut, but what I did was full torque down the shorty header and then do the long one.
all in all glad it worked out for you.
Old 10-11-2010, 09:32 PM   #4
TrickTizzle
My Ride: 325i
I loosened them both first. Pulled rear out, pulled front out. Connected front. Connected rear.
Them went in and out without any force/probems.
Old 10-12-2010, 08:51 AM   #5
Iceman00
My Ride: ghey
Do you have run files? I'd love to see an overlay of them vs stock.
Iceman00 is online now   Reply With Quote
Old 10-12-2010, 08:58 AM   #6
simsima325
'a certain moderator'
simsima325's Avatar
My Ride: Honda Civic
nice write up, and very good to see dyno numbers
want headersssssss!
Old 10-12-2010, 03:40 PM   #7
jamex
My Ride: 2005 325Ci
I just checked bimmerbrakes' website and could not find any mention of ceramic coating...only that they're stainless steel. Your pic doesn't look ceramic coated either. Are you sure they're not just SS?
jamex is offline   Reply With Quote
Old 10-12-2010, 04:31 PM   #8
TrickTizzle
My Ride: 325i
Unfortunanely no.
The ceramic coating was during the group buy. I'm sure he can get them coated for you.
They are ceramic metallic coated, and they are most def coated. I could smell it when I first started up the car.
Old 10-12-2010, 04:40 PM   #9
rhm325i
My Ride: 02 BMW 325i
Nicely done!
this is my favorite mod so far on my 325i
rhm325i is offline   Reply With Quote
Old 10-13-2010, 07:44 PM   #10
///Mine
My Ride: '05 325i
awesome pics/charts man. after seeing this i'm really interested in getting the headers. the results are amazing!
quick question for you or anyone else who did this mod: is the smell really THAT bad and unbearable? i was talking to a guy at the euro shop i go to and he said that the smell is completely unbearable and smells like rotten eggs. is that true?
also how is the sound with the stock exhaust?
thanks guys
///Mine is offline   Reply With Quote
Old 10-14-2010, 03:24 PM   #11
RogueStatus37
My Ride: '04 330ci
You have the stock exhaust right? How does it sound?
2004 330Ci ZSP 6-Speed
Blackout grills l Smoked Reflectors l CCFL Angel Eyes l Gloss Black Roof Vinyl l BSW Speaker Upgrade l 3.46 Open Diff l BMW Performance SSKl M3 Style Trunk Spoiler
H&R Sport Cup Spring Kit l RHO Tow Hook Plate l Nokya Hyper-yellow Fogs l Stainless Steel Headers l Tuner Slotted Brake Kit l AXXIS/PBR Metal Master Pads l BMW AUX Input Kit
RogueStatus37 is offline   Reply With Quote
Old 10-15-2010, 10:50 PM   #12
ikeupinya
Stay modded my friends!!!
ikeupinya's Avatar
My Ride: shalt not be riced!!
Great write-up, getting my SS headers installed tommorrow so hoping everything goes well...
Da Lil' Paratrooper!
ikeupinya is offline   Reply With Quote
Old 10-16-2010, 12:49 AM   #13
xi325xi02
My Ride: 325xi
Will be purchasing in about a month!!!! Im super excited.
If i opt just for the SS headers, will I see any negative outcomes? I guess a better way to put it is, do you really need to get coated headers?
Originally Posted by onebad328i View Post
you want ladys damm, get a punchin hard ass sound system
I HATE CVT'S
xi325xi02 is offline   Reply With Quote
Old 10-16-2010, 08:04 PM   #14
TrickTizzle
My Ride: 325i
thanks guys
http://forum.e46fanatics.com/showpos...15&postcount=2
Just do it. It helps keep heat in, and helps with sound.
Old 10-17-2010, 10:37 PM   #15
///Mine
My Ride: '05 325i
nice vids!
how's the smell once you installed the headers? is it unbearable?
Old 10-17-2010, 10:56 PM   #16
TrickTizzle
My Ride: 325i
nice vids!
Nope. It doesnt smelll that much. Only time you will smell it if you get out of the car right after you drive it hard, otherwise in the smell is very faint in the morning, and when I get out of the car once it has warmed up. As far as the rotten egg smell, I haven't noticed anything.
Old 10-18-2010, 12:18 PM   #17
///Mine
My Ride: '05 325i
thanks a lot for the answers man. 10/10 thread
i'll definitely be getting the headers sometime soon
Old 10-18-2010, 03:55 PM   #18
RogueStatus37
My Ride: '04 330ci
Holy shit. It sounds fucking awesome with stock exhaust. Im impressed. Cant wait to install them on my car
Old 10-18-2010, 04:03 PM   #19
mvrk10256
My Ride: E30 325i
again great job.
@ the guy whotalked about rotten egg smell. your mechanic must be off his rocker. if you let the car idle in one place you will get a slight smell of gasoline cause there are not cats. but you should never smell rotting eggs.... at least not from the headers.
Old 10-27-2010, 06:41 PM   #20
Steven747
My Ride: 05 330ci
Great Thread!
