Sponsored by BimmerWorld
Thread Tools Search this Thread Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 10-12-2010, 02:01 AM   #1
paraklas
My Ride: ESS TS2 320ci
Cleaning brake calipers from Rust and Brake Dust!
Continuing my 330 rear caliper mod to my 320, time has come to clean the 330 calipers. They had a very very nasty layer of rust and brake dust, bonded together, which took countless hours with dremel with sandpaper/stone/brush to clean them. Now I have some persistent dust/rust in areas I can't reach, i.e. between cylinder and caliper.
Is there any solution to remove the brake dust buildup completely? I was thinking soaking them in rust inhibitor for a day or two, what do you think ?
Old 10-12-2010, 11:07 AM   #2
BimmerBrakes
The Brake Newbie!
My Ride: 2005 ZHP BMW
Send a message via AIM to BimmerBrakes
Paraklas,
I usually use this to rebuild the Calipers and Paint them.
http://www.evapo-rust.com/
-Anthony@BimmerBrakes
BimmerBrakes is offline   Reply With Quote
Old 10-12-2010, 06:19 PM   #3
ThatGuy_JZ
My Ride: '02 Steel Blue 325Ci
Send a message via AIM to ThatGuy_JZ
Sandblast them. Watch out around the rubber at the piston though.
Sent from my Samsung I897 Captivate
- 2002 Steel Blue 325Ci -
ThatGuy_JZ is offline   Reply With Quote
Old 10-12-2010, 06:25 PM   #4
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Para, if the calipers are off the car, you can use compressed air to blow the piston out (push air through where the brake line goes)...if that's what you mean...and at that point, it makes sense to rebuild with the new seal and dust cover. Otherwise, not sure what area you can't get to. Sounds like they're clean enough...and I wouldn't risk the sandblasting as if the seal gets damaged, you'd get rust forming behind like I saw on my piston just last week...the rust on piston prevented it from retracting fully and thus getting new pads on.
Brake cleaner, brass brush...dial up the ocd meds...works for me everytime! (kidding...I am unmedicated, though I shouldn't be!)
HTH
Doug
See me in June!
dmax on Facebook
Mangofy your E46!
Old 10-13-2010, 08:11 AM   #5
paraklas
Thanks for the tips. I will order a caliper rebuilt kit tonight from the cheap usa as far as seals.
The previous owner must have tried to paint the calipers and used them while paint was still wet or something. The steel brush at 3000rpm would only polish the crust that was formed on them! Now they are clean apart from some stubborn areas which I want to clean before proceeding. I'll get some pictures up tonight to see thanks again
Old 10-13-2010, 06:33 PM   #6
2003 325i
My Ride: '03 Orient Blue 325i
Anthony, is that product safe on seals and rubber on calipers? Can u just soak the area liberally with that stuff and be ok?
Old 10-14-2010, 12:09 AM   #7
BimmerBrakes
The Brake Newbie!
The Product will not harm rubber, plastic, clothing or glass either. I would take the Caliper apart to remove all debris...
Old 10-14-2010, 12:24 AM   #8
paraklas
Pics of the almost clean calipers.
Old 10-17-2010, 10:56 AM   #9
paraklas
After soaking for 2 days in rust inhibitor:
Old 10-28-2010, 08:48 AM   #10
325ciGeschlecht
My Ride: is sapp black
ru gunna paint too? or just cleaning up?
325ciGeschlecht is offline   Reply With Quote
Old 10-28-2010, 10:16 AM   #11
paraklas
Painted with matte silver high-temp spray paint (up to 700 degrees Celsius)
Old 10-28-2010, 10:51 AM   #12
jblack03zhp
My Ride: 330i zhp
Finally pics
UUC Stage II Aluminum Flywheel/Perfomance Organic__UUC Evo 3 SSK & DSSR__UUC Underdrive Pulleys__Magnaflow__H&R Sport Cupkit__TMS Rear Camber Arms
__And tooo much other stuff
Originally Posted by Penguin Koolaid View Post
The difference being men don't make excuses to rationalize why it's okay. We do as we please. No fucks will be given. You ma'am, give a fuck.
jblack03zhp is offline   Reply With Quote
Old 10-28-2010, 01:48 PM   #13
paraklas
Old 10-28-2010, 02:02 PM   #14
Fry-man22
My Ride: 2003 BMW 330i Sport
I would have removed the bleed screw and the piston and just painted the caliper. If it was black rubber to begin with I would have tried to keep it that way. The way you cleaned them up was outstanding from where they were though - good job.
Fry-man22 is offline   Reply With Quote
Old 10-28-2010, 02:55 PM   #15
paraklas
Thanks!
I rushed to paint them to prevent rusting again. I'm waiting for a caliper rebuilt kit to arrive, seals, bleed screw and piston!
Old 10-28-2010, 11:36 PM   #16
SC_TR0JAN_M3
My Ride: 2004 BMW M3
wow... i'm wanting to do this too... my brakes have turned to a nice **** brown after all the brake dust. whats the type of paint that you used exactly?
2004 CB 6 Speed ///M3
Looking For :: GC Race Sways :: SS Race ::
SC_TR0JAN_M3 is offline   Reply With Quote
Old 10-29-2010, 12:15 AM   #17
xi_ter
My Ride: 2003 325xi
What was the brand of rust inhibitor you soaked the calipers in - was it the Evapo-Rust?
Old 10-29-2010, 12:48 AM   #18
paraklas
Motip Silver heat resistant spray paint
Product Here
I used the same paint to do the fronts and they are fine after a year!
No, I could not find it. I used Hammerite Rust Remover. From the pic in the link below, the rightmost bottle.
Product link here
Old 10-29-2010, 08:53 PM   #19
xdmikey
My Ride: e46 cabrio
well worth the effort!
pics of finished product please(for everyone!)
DINAN CAI, 3.46 DIFF, CDV DELETE,DINAN S2 & EXHAUST,HARDTOP
xdmikey is offline   Reply With Quote
Old 03-30-2012, 02:33 PM   #20
monkeyhead
My Ride: 2003 330i
Hey Paraklas, for the Motip Silver heat resistant spray paint, which size did you buy the 100 or 400 mL? I want to do all 4 calipers
Also, do you know why red color is only rated to 300 degrees instead of 800?
monkeyhead is offline   Reply With Quote
