H&R Touring on a sedan info needed - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BimmerWorld
Old 10-12-2010, 05:33 PM   #1
2003 325i
My Ride: '03 Orient Blue 325i
Here's my story, I'd like to throw one of these kits on but these are my "issues".
My summers are 225/40 18s in the front with ET29 (a little sidewall/wheel poke, less than 5 mm I'd say). The rears are 255/35 18s ET40 (tire sidewall perhaps 'just' inside of edge of fender when looking down on them).
I'd kinda like to space the rears out so the tiny poke matches the front, 5mm spacers I think would look purrrrrfect.
Am I going to have rub issues front or rear with this setup assuming the H&R drops me 1.4" front and 0.75" rear?
Anyone with setups similar with pics who would share 18" (I only want 18s) wheel pictures welcome. If you do post wheel pics with the H&R kit please include wheel size (incl. width and offset)and tire size. I wouldn't be adverse to having lips rolled under but would like to avoid rolling/pulling fenders.
Basically can this be done under my conditions given these wheels I have (style 293s)?
for help... this would be my spring (no pun intended) project next year.
Old 10-12-2010, 05:58 PM   #2
2003 325i
just took some measurements. fronts will have about 4mm poke once I get close to 0 deg toe (I know this measurement shouldn't affect poke at the centre of the wheel). The rears are offset about 4-6mm inside the wheel well. So I guess 8mm spacers in the back are the right ones for me. Assuming I do these what can I do to make this work? A little neg camber? I'd rather have stock alignment specs but if it's like 0.5 deg neg camber needed I'm fine with that.
Old 10-12-2010, 09:22 PM   #3
Ruf
My Ride: 03 ZHP Imola Red
I'm in the process of installing a touring kit on my ZHP - w/18in wheels, same tire size you're running now.
The rears are done, looks very good, rides nice too.
I'll be done with the fronts this weekend, so I can send a photo then.
For a sport susp, they noted a .75" drop in front and .25" drop in rear.
Ruf is offline   Reply With Quote
Old 10-12-2010, 11:10 PM   #4
2003 325i
Thanks, let me know wheel size and offset as well if you could
Old 10-13-2010, 08:33 AM   #5
Ruf
I've got the stock zhp wheels, but I'll look up the info when I get home tonight
Sent from my PC36100 using BimmerApp
Old 10-13-2010, 09:58 AM   #6
2003 325i
if you tell me what style they are (BMW style #) then I can look it up online. Thanks again
Edit: found it... ET47 front, ET50 rear... that's a fair bit different then my 29/40 setup... ouch, still interested in your fitment tho.
