Old 10-12-2010, 06:22 PM   #1
JPesch
My Ride: 2000 323i
Drivers door key unlocking/locking problem
It looks like everything wants to go bad on my car right now. Luckily no big things though.. yet.
A little bit ago I went to unlock my door by using the key in the door and the key got stuck slightly offset from up/down and I had to use a little force to remove it.
Now the drivers door locks/unlocks fine with the button in the car and on the remote still. The problem is only when using the key in the door. It unlocked the door half the time, and made the sound of unlocking it but didn't fully unlock it the other half of trys. Nothing happened when i turned the key to the right, and the key wouldn't automatically go back to being vertical so it coul be pulled out.
Any advice?
Sent from my Droid using BimmerApp
JPesch is offline   Reply With Quote
Old 10-12-2010, 11:11 PM   #2
JPesch
My Ride: 2000 323i
Does #11 seem correct? Im assuming thats all I would need.. but a second opinion always helps
11 CATCH WITH KEY CODE LEFT 1 09/2000 51218244049 $83.65
Also, does anyone know how I go about having it coded for my key? Hoping I give my vin and it comes coded..
Old 10-12-2010, 11:36 PM   #3
AdamI
My Ride: 01 325Ci
http://cgi.ebay.com/BMW-E46-DOOR-LOC...a0256f716#shId
No recoding necessary. Just disassemble, and reassemble with new parts. The bottom ring in the picture is probably what broke. I just replaced mine.
AdamI is offline   Reply With Quote
Old 10-13-2010, 12:55 AM   #4
JPesch
My Ride: 2000 323i
That is great information AdamI. It didn't even cross my mind that I'd be able to fix mine. Is there anything else in the cylinder that could break? Or is that pretty much it? I'm definitely ready to buy that repair kit
Old 10-13-2010, 05:05 PM   #5
AdamI
My Ride: 01 325Ci
Open the door, and you'll see a rubber oval, kind of behind the cylinder but facing the rear of the car. Pop that out, use a size 4 or 5 hex key to unscrew the bolt. Then just wiggle the lock cylinder out of the door, and get a better idea of whats rly goin on.
Old 10-13-2010, 09:32 PM   #6
JPesch
My Ride: 2000 323i
I will get in there and check it out tomorrow. Thanks
Old 10-14-2010, 04:07 PM   #7
JPesch
My Ride: 2000 323i
As you can see, that ring circled in my picture was broken into a couple pieces so I ordered the repair kit that you linked to. Thanks a bunch.
Old 10-23-2010, 10:04 PM   #8
AdamI
My Ride: 01 325Ci
Sure thing man. You'll have fun getting the spring back in there, lol.
Old 02-23-2011, 12:46 AM   #9
anhtu402
My Ride: 2002 BMW 325XI
AdamI and others that have taken this apart: This might be a stupid question, but I'm pretty sure you have to take the door panel off right? Then do what you said in post #5?
Thanks!
anhtu402 is offline   Reply With Quote
Old 02-23-2011, 02:49 AM   #10
anhtu402
Nvm I was able to figure it out.
Sent from my PC36100 using Bimmer App
Old 02-23-2011, 09:25 AM   #11
druggrepp
My Ride: 325ci 2001
pics of lock
Here are some pics of offending springs.
My key wont open doors so i am using key only and I know it's the same thing.
Keep us posted on the fix...
'01 325ci
ID:	394161   Click image for larger version
druggrepp is offline   Reply With Quote
Old 02-23-2013, 03:12 PM   #12
Bombay Badboy
My Ride: 2001 BMW 325i(or Xi)
Soooooooooooo. What do you do when the remote doesnt work, and then the lock breaks?!?!?!!?
Bombay Badboy is offline   Reply With Quote
Old 02-25-2013, 05:25 AM   #13
NumbaOneNewb
My Ride: 2003 330CI Silver
you better pray it broke when you were already unlocked and you were attempting to lock it.
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 03-09-2013, 09:49 PM   #14
btimm
My Ride: 2000 323i
Aha I just had that happen to me and had to get a little kid across the street to go through my ski hole and turn my car on to unlock the doors... Guess I will be doing this repair soon!
btimm is offline   Reply With Quote
Old 04-15-2013, 01:24 PM   #15
biggles0509
My Ride: 328Ci
I too had locked my car and then the lock broke (remote hasn't worked for ages)! Luckily my very helpful son climbed in through the boot and turned the ignition on to unlock the car. Repair kit ordered.
biggles0509 is offline   Reply With Quote
Old 04-15-2013, 03:12 PM   #16
NumbaOneNewb
Wow. Lol. Imagine if you didn't have a son and you had to do the whole tunnel rat thing. When you say repair kit, you mean the part that broke? Perhaps getting the remote working as well.
Old 06-20-2013, 11:34 PM   #17
Cancal
My Ride: BMW
Any advice?
Hi,
I've same problems as yours. But also facing problems to open all windows and sunroof. I press and hold, it just unlock driver's door. Central locking system is working fine. Any idea or suggestion?
Cancal is offline   Reply With Quote
Old 06-26-2013, 04:24 PM   #18
blu_olivz
My Ride: 325i
Having lock problems as well, on my '03 325i.
The driver's side door lock seems reluctant to pop up when unlocking, and when that happens, all the other three doors' locks don't respond when I try to unlock them (with key AND the central locking button in the car).
Central locking issue?
edit: I did some more digging (especially through that mother of all unlocking posts: "door locks are all crazy").
My problem looks like it has more to do with the general control module, specifically the relay responsible for unlocking all doors (relay 1-B).
For anyone interested in a detailed explanation: "BMW GM5 Door Lock Relay Schematic and Explaination"
I think I've just been posting in the wrong thread... anyway, good luck to everyone with their own issues!
blu_olivz is offline   Reply With Quote
Old 06-26-2013, 04:30 PM   #19
Cancal
My Ride: BMW
Does anyone can help me to find fuses for convenience options and fuse number? I did open glove box and saw the fuse box was reading but no luck.
Old 06-26-2013, 05:11 PM   #20
blu_olivz
My Ride: 325i
[deleted]
