The Showroom
Thread Tools Search this Thread Rating: Thread Rating: 133 votes, 4.97 average.
Old 04-28-2013, 06:59 PM   #1141
roboeclipse
My Ride: E46 330ci
Originally Posted by Kenny_M3 View Post
They are 18x9.5 et 15 all around. The rears have a 25mm spacers to give it a more aggressive look to match the front.
I'm in love with your rims....what kind are they?
roboeclipse is offline   Reply With Quote
Old 04-28-2013, 07:04 PM   #1142
Snik
Snik's Avatar
My Ride: IR M3 Vert.
That 330 coupe on ACS is nowhere near aggressive.
whats with all the none aggressive cars up in this piece?
Do you ride a sportbike?
Old 04-30-2013, 11:07 PM   #1143
cosantana
My Ride: 2003 M3 Convertible
BBS LMs
19 BBS LMs
Name:	Painted Finished15.jpg
ID:	503286   Click image for larger version
ID:	503287   Click image for larger version
2003 BMW M3 Convertible:
BBS LM's 19"
Stop Stech 355mm Slotted Big Brake Kit
6 pistons in front and 4 Piston on Back
CSL front bumper
Vorsteiner VCSL rear diffuser full carbon fiber
Crystal LED Tail lights upgrade
Matte Black front grill and side gill upgrade
Short Antenna
Agency Power Exhaust with Titanium Tips
Bilstein PSS10 Coilover System
Radio Upgrade
Interior refreshed
DICE Ipod Integration
Hardwired for a Valentine V1
cosantana is offline   Reply With Quote
Old 05-01-2013, 06:35 AM   #1144
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
How are those LMs a square setup?
/_________\
O==[][]==O
Old 05-03-2013, 01:46 PM   #1145
domcreates
Banned User
My Ride: Jet Black 1999 323i
Originally Posted by snik View Post
that 330 coupe on acs is nowhere near aggressive.
Whats with all the none aggressive cars up in this piece?
Originally Posted by 330i zhp View Post
how are those lms a square setup?
+1
domcreates is offline   Reply With Quote
Old 05-03-2013, 04:47 PM   #1146
haze.
My Ride: 2001 330ci
not as aggressive as some, but here you go.
haze. is offline   Reply With Quote
Old 05-03-2013, 10:16 PM   #1147
AP1_RG
My Ride: 325i
Clean... More pics!!!
AP1_RG is offline   Reply With Quote
Old 05-09-2013, 09:30 PM   #1148
Kenny_M3
My Ride: f30 3 series
they are esm. and thanks
Kenny_M3 is offline   Reply With Quote
Old 05-11-2013, 12:23 PM   #1149
latino1ny
My Ride: BSM 335i
Is that Evap's old car?
'08 BSM E92 335i 6MT/KW V1s/matte black grills/blacked out side markers/complete LED interior kit/DCI/M-aero front lip/Alcantara shift boot/Clutch stop/CDV delete/LED reverse lights/muffler delete/Cyba scoops/3.8" Cyba tips
latino1ny is offline   Reply With Quote
Old 05-11-2013, 12:47 PM   #1150
haze.
My Ride: 2001 330ci
no not that i know of...bought it stock in 2011
Old 05-11-2013, 01:10 PM   #1151
latino1ny
My Ride: BSM 335i
Originally Posted by bimmerchop View Post
post your AGGRESSIVE SQUARE wheel setup
Some people need to learn what SQUARE wheels are... SAME rim diameter, same WIDTH, same OFFSET, same tire SECTION WIDTH, same ASPECT RATIO.
18x9.5 et 20 with 215/40-18 ALL FOUR CORNERS is square
18x9 front 18x9.5 rear is NOT square
215/40 fronts and 235/40 rears is NOT square
et 20 front and et 15 rear is NOT square (I don't care if you added a spacer in the rear, if you change the final ET, you're NOT fukking square anymore.
SQUARE set up means you can rotate your tires ANY way. Put fronts on rear, rears on fronts, lefts on rights, front left on rear right, etc. If you have a different offset in the rear, or different section width, you CANNOT do that. therefore, you are NOT square...
Take a gander at Evap's old car and you'll see why I asked that.... spitting image.
Old 05-11-2013, 01:14 PM   #1152
Snik
Snik's Avatar
The Official: "Post Your [AGGRESSIVE SQUARE WHEEL SETUP] Thread"
Offset doesn't and usually isn't the sane for it to be a square setup. So relax.
Old 05-11-2013, 01:25 PM   #1153
haze.
My Ride: 2001 330ci
If you have different spacers in the rear and front, how are the fronts and rears not interchangeable?? My spacers stay on my hubs the wheels do there own thing. Look through this thread before you spaz, 90% of the setups on here are different offsets.
But yea my car and evaps car are close, except his was a steel grey 323 sedan with vmrs and i have a steel blue 330 coupe with breytons.
Old 05-11-2013, 01:35 PM   #1154
latino1ny
My Ride: BSM 335i
Offset doesn't affect it being considered square? Ok, then you have ET20 fronts and fukk it, lets say ET8 rears, rotate your right side tires only, put the rear in the front and the front in the rear. So now your front left is ET20, front right is ET8, rear left is ET8 and rear right is ET20. Drive around like that for a month and tell me how your cars drives!!!! You wouldn't do that would you? Ok, so then offset DOES affect it being SQUARE.... SQUARE means you can pick a random wheel and put it on ANY given corner of the car, and it will work. Square = all 4 corners the SAME!!!
Hence the reason for my rant... People need to learn what SQUARE is. Granted the E46 M isn't designed to be a square set up. The rear fenders are a lot wider than the front fenders and if you put a TRUE square set up on an M3, the fronts will be Mexi-flush and the rears will be Hellasunk... but that's beside the point. Non-M coupes and sedans have no excuse.
Old 05-11-2013, 01:43 PM   #1155
haze.
My Ride: 2001 330ci
if you have 20mm rear spacers and no front spacers the rims are still square. Like i said, spacers stay with the hub. i think you need to learn what SQUARE is.
Old 05-11-2013, 02:43 PM   #1156
lamsv
My Ride: 2001 325iT
Preach!
lamsv: 2001 HELLROT on BLACK 325iT
lamsv is online now   Reply With Quote
Old 05-11-2013, 03:00 PM   #1157
Snik
Snik's Avatar
:Lmao: Someone totally missed the meaning of square.
Old 05-11-2013, 03:17 PM   #1158
Press22
My Ride: 01 325ci
Squared!
Press22 is offline   Reply With Quote
Old 05-11-2013, 04:27 PM   #1159
latino1ny
My Ride: BSM 335i
I know the spacers stay with the hub, and I know what square is. Problem with spacers is that when you ask people for their specs, they tell you the FINAL specs after spacers. (ex. 18x9.5 ET20 front 18x9.5 ET10 rear)
This is difficult to discern whether the rims AREN'T square, or dude's running spacers. A PROPER response if running a true squared set up but have spacers for flushness, would be something to this effect (18x9.5 ET20 all the way around with the addition of 10mm spacers on the rear bringing final rear to ET10) Now you KNOW dude is squared, but running spacers. But nah.... nobody posts ish like that, they just give the final specs.
Old 05-11-2013, 04:33 PM   #1160
latino1ny
My Ride: BSM 335i
Originally Posted by Dibaltic View Post
17x9.5 et18 front and et10 rear
This is a good example of what I'm talking about. Dibaltic IS on a square wheel set up. I'm not sure about tires sizes, because he didn't post them, BUT, I know for a fact his wheels are square. They are C4 Corvette wheels. ORIGINAL specs are 17x9.5 ET56, but look how Dibaltic posted his "specs" His method makes it look like the rims aren't square. When in actuality, he's running a 38mm adapter in the front and 46mm adapter in the rear, giving him to his final specs.
This is a proper way to post specs of a square set up.
Rate This Thread
