Old 10-13-2010, 08:16 PM   #1
Estoril-E46
My Ride: M3
BFG drag radials are not very good.
So first tires I put on my car after it was obvious starspecs weren't going to work were Hoosier A6s, once I put those on I got full grip in 4th and could hook in third if I was careful. However as they are road race tires with stiff sidewalls I figured I was giving up some potential. So 5k miles later after I corded them I decided to go with some BFG drag radials in the same size.
Well I am very disappointed. I don't even have traction in 4th and the cars all over the place. It's really scary when you change lanes at 130mph and the car tries to go sideways. They are so bad I will probably toss them before they are treadless and go back with the A6s. I've tried lower pressures too. The tread is also just balling up on the tire which is probably part of the problem.
Anyway F.I. buyer beware.
The quick but slow car:
www.Precision-Sport.com
Estoril-E46 is offline   Reply With Quote
Old 10-13-2010, 10:55 PM   #2
yellowssm
My Ride: 2005 M3
Really???? Brian (screen name gasser) really liked the bfg's on his stage 2.5? Rob really likes the toyo R888's on his stage 3 and that is also what mert used on his car to do his record breaking 60-130 time. Might want to give those a try. I am currently using them now and love them What size are the drag radials? If you are gonna toss them, can I buy them from you for cheap???
yellowssm is offline   Reply With Quote
Old 10-13-2010, 11:07 PM   #3
gringotegra
My Ride: Turbo
The BFG's suck... had them on my car for not very long at all and they wore off really fast...
Try some M/T ET's, Nitto 555's or the Bias ply M&H's...
10.12@151mph..... English Racing
gringotegra is offline   Reply With Quote
Old 10-14-2010, 01:00 AM   #4
MSpired
My Ride: HPF Stage 2.5 e46 M3
Send a message via AIM to MSpired Send a message via MSN to MSpired Send a message via Yahoo to MSpired
MT's or R888's IMO
MSpired is offline   Reply With Quote
Old 10-14-2010, 01:50 AM   #5
forcefedvw
My Ride: 03' Z4 '00 VW
mickey thompsons all the way!!!!!
Innovative Performance
http://www.facebook.com/pages/Innova...609652?sk=info
2JZ-GTE Conversions & GM LS-Engine Conversions
forcefedvw is offline   Reply With Quote
Old 10-14-2010, 01:52 AM   #6
yellowssm
My Ride: 2005 M3
The only thing I wondered is how do Mickey thompsons handle for daily driving. Cornering wise?
Old 10-14-2010, 01:56 AM   #7
MSpired
You don't go taking turns on them, but it's not like it's dangerous to daily drive on them...
Old 10-14-2010, 02:08 AM   #8
yellowssm
My Ride: 2005 M3
At least with the toyo r888 you can go canyon carving too
Old 10-14-2010, 04:55 AM   #9
need4spd
My Ride: M3 with CSL trunk!
They are horrible in cornering! When i put them on for the first few days i thought something was wrong with my rear suspension until i realized it was teh damn tires. That was going from a BFG drag radial. So if you are having issues with lack of stiff sidewall with the bfg's good luck with the mickey thompsons.
You need to heat those bfg's up a bit. However as bad as teh mickeys are at cornering they stick a lot nicer than the bfg's. If you want the best of all worlds time to get a AWD car. Preferably mid engined.
need4spd is offline   Reply With Quote
Old 10-14-2010, 09:09 AM   #10
InDiGlOM3
My Ride: HPF M3 stg 2.5
I daily My MT's from time to time, 305/35/18 just for you that dont remember. They are awesome, traction in 2nd race/meth. even traction in first some of the times depending on the road. I drive the same on them as my Invo's when it comes to hard cornering and they are just fine. I leave them at 32psi, even at that psi I get perfect traction.
Need4spd: how big was your sidewall? must of been huge to have corning problems
Old 10-14-2010, 09:46 AM   #11
AirFrcd
My Ride: Mfizzle, and GT-R
I run MT 275-40/17s at 23psi, and they are the best tire thus far!
I still have to be very careful on pump/meth and modulate the throttle (ease into it - lol), as it will go sideways in the blink of an eye, especially when not heated up, yet.
I can do everything through Christ who gives me strength.
Philippians 4:13
AirFrcd is offline   Reply With Quote
Old 10-14-2010, 10:17 AM   #12
jchris
My Ride: Sold-HPF BMW M3 Stg3
Great info!!! Saving this Thread.
jchris is offline   Reply With Quote
Old 10-14-2010, 10:19 AM   #13
InDiGlOM3
Airfrcd What stage are you, 3? I forget......I am 100 percent positive the 305/35 has more grip, you should try them next time. If you have some 18 inch rims sitting around.
Old 10-14-2010, 11:24 AM   #14
yellowssm
My Ride: 2005 M3
How wide of a wheel do you fit that tire on?
Old 10-14-2010, 11:27 AM   #15
AirFrcd
Yes, stage 3! Thanks for the feedback. I really benefit from the tall '40 series sidewall!
Philippians 4:13
Old 10-14-2010, 11:33 AM   #16
yellowssm
My Ride: 2005 M3
btw which mickey thompsons are you guys running again? I have these in 265/40/18 sitting in my garage waiting for the dragstrip
http://www.mickeythompsontires.com/s...StreetRadialII
Old 10-14-2010, 05:35 PM   #17
InDiGlOM3
Im running the ET street radial 2. 305/35/18. They say to atleast have a 10.5 inch wide rim but I have a 10inch, makes the tire a tad bit taller then spec.
Airfrcd- remember, your 40 series is no taller to the eye then my 35 series. they are practically the same, only my tires are wider. the series number is a percentage of the width.
Old 10-14-2010, 07:00 PM   #18
UrineMachine
Banned
My Ride: Mysterious 5
Send a message via AIM to UrineMachine
bfg have been the worst in my experience. once worn some, they have the texture of a small cell foam sponge. they feel like really dense foam vs rubber. They blow for traction on every car I've been in with them from VWs to BMWs. Terrible. Get a M/T Street Radial Worlds better. Dunno what wheels you guys can run but if you can run a 16" or 17" wheel you will have a lot more traction than an 18" wheel.
UrineMachine is offline   Reply With Quote
Old 10-14-2010, 07:25 PM   #19
yellowssm
My Ride: 2005 M3
BTW, I forgot to ask you... You said you daily drove on the MT's, how many miles would you get on a pair? thx
Old 10-14-2010, 09:03 PM   #20
InDiGlOM3
Id daily for a month at a time because im lazy to put back on my Invos. So i have yet to go thru my first set. Im at about 4k miles right now. 2k miles was a Road trip to AZ. EvilTwinrob has been dailying his MT's same size as mine for awhile, he be the one to ask how many miles he has got so far.
