Old 10-14-2010, 09:40 PM   #21
forcefedvw
My Ride: 03' Z4 '00 VW
and dont go bigger than a 17" wheel best drag performance and i think it will still fit your rear brakes barely.
Innovative Performance
http://www.facebook.com/pages/Innova...609652?sk=info
2JZ-GTE Conversions & GM LS-Engine Conversions
forcefedvw is offline   Reply With Quote
Old 10-14-2010, 10:34 PM   #22
Evil Twin Rob
My Ride: 2004 M3
I probably have 7,000 miles on my MT's, and they are still in good shape. This includes 3 trips to the strip, and some spirited drives with the local BMW club. To me, they felt fine in the corners, as they were causing the front tires to push. Obviously, there are much better tires for corners if you are really pushing the car to it's limits, but I couldn't be more happy with the all around capabilities of these tires. They even exceeded my expectations for wet driving.
HPF 2.5
Evil Twin Rob is offline   Reply With Quote
Old 10-14-2010, 11:33 PM   #23
yellowssm
My Ride: 2005 M3
Very good to know! Are you using the ET street II's also? What size and what size wheel are they on?
What are you guys running for camber in the rear?
yellowssm is offline   Reply With Quote
Old 10-15-2010, 03:02 AM   #24
need4spd
My Ride: M3 with CSL trunk!
Originally Posted by InDiGlOM3 View Post
I daily My MT's from time to time, 305/35/18 just for you that dont remember. They are awesome, traction in 2nd race/meth. even traction in first some of the times depending on the road. I drive the same on them as my Invo's when it comes to hard cornering and they are just fine. I leave them at 32psi, even at that psi I get perfect traction.
Need4spd: how big was your sidewall? must of been huge to have corning problems
I had 275/40/17" 9-10" inch wide rim. I always run them 30-35psi.
need4spd is offline   Reply With Quote
Old 10-15-2010, 09:19 AM   #25
InDiGlOM3
My Ride: HPF M3 stg 2.5
Thats weird that you had such horrible experience with the tires in the corners then. exp with a wide rim and high psi in the tire.
Yellowssm: I try to keep the camber close to zero as I can now just for more tire on the ground and better traction in the straight.
Old 10-15-2010, 12:31 PM   #26
yellowssm
My Ride: 2005 M3
cool. You were saying you squeeze a 305 on your 10" wheel right? is there any negatives to doing this? If not I might try squeezing a 295 on my 9.5" wheel
Old 10-15-2010, 01:37 PM   #27
azjimi
My Ride: '02 M3 coupe
I think this link may answer your question:
http://www.tirerack.com/tires/tirete...jsp?techid=198
VF Stage 2 S/C, Om Scorza exhaust, Stett Performance headers, Custom Performance Rasp Eliminator and Race Cats, GTR hood, 19" SSR GT3's, Bridgestone RE-11's, PSS9 coilovers, Eibach Sways, Powerflex RTABS, Angel Eyes, Smoked Depos
azjimi is offline   Reply With Quote
