Sponsored by BimmerWorld
Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 10-15-2010, 02:56 PM   #1
Phantoms69
My Ride: 330ci
What is the best brake fluid to use?
This might be a bit late to ask, but what would be the best brake fluid to use in my 2003 330ci? I am replacing the brakes this weekend so hopefully the fluid is one I can get from a local source. I see in the manual that DOT 4 is recommended. I did a search on the forums here but didn't find the answer just yet, so sorry if I am asking this and the answer is out there. Any help would be appreciated.
Thanks in advance.
Phantoms69 is offline   Reply With Quote
Old 10-15-2010, 03:48 PM   #2
AW-M3
My Ride: '05 M3 'Vert
ATE super blue. It is a DOT4 with a 536 degree temp rating. There is a blue and orange (I believe). Alternate the colors when you do complete flushes so you can tell when the fluid has been completely evacuated from your brake lines.
AW-M3 is offline   Reply With Quote
Old 10-15-2010, 04:45 PM   #3
Turd Furgasun
My Ride: '02 330i Sedan
don't use the super blue... it stains your reservoir. Get the gold ATE.
I just flushed my system with Fuchs 5.1. But really any Dot 4/5.1 fluid will work.
The wet/dry temperature ratings of OEM are equivalent to $3 Prestone.
Turd Furgasun is offline   Reply With Quote
Old 10-15-2010, 04:49 PM   #4
FTWeisse
My Ride: has no hip-hop rimz
No.
Motul 600.
Old 10-15-2010, 05:12 PM   #5
WALKD U
My Ride: Just Fast!
MOTUL RBF600....
-TrippinBimmer
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
Stock
NAwhp/NAwtq SAE Corrected
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 10-15-2010, 05:32 PM   #6
ChasCan
My Ride: 2001 330xi
DOT 5.1 has the highest boiling point wet or dry of any brake fluid out there. DOT 4.0 being the second highest & DOT 3.0 the next. Do not confuse DOT 5.1 with DOT 5.0. 5.0 is silicone based whereas 5.1 is conventional brake fluid. They are not recommended to mix. You can use any conventional brake fluid brand recommended here, just do not mix 5.0 with any other DOT # brake fluid. DOT 5.1 is just the next generation of conventional brake fluid designed to have the highest boiling point of all. If you track your car heavily, this, IMHO, is the best whether or not you achieve the max temp threshold. Chas
ChasCan is offline   Reply With Quote
Old 10-15-2010, 07:25 PM   #7
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Motul is OK, Castrol SRF is way better. SRF lasts way longer than Motul which means less money and less work over time.
If you are not doing HPDE's...I'd just stick with ATE gold.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 10-16-2010, 12:16 AM   #8
Phantoms69
My Ride: 330ci
Thanks for all the suggestions. I will see what the local auto stores have and go from there.
Thanks again.
Old 10-16-2010, 01:19 AM   #9
xi_ter
My Ride: 2003 325xi
Alternate between ATE Blue and ATE Gold. That way you know when all the old brake fluid has been bled out.
Old 10-17-2010, 06:50 PM   #10
bigjae1976
bigjae1976's Avatar
I tried that and the blue fluid turns everything blue and it doesn't really work. In fact, I think it is tell dirty, dark yellow fluid from clear/light gold fluid.
Old 10-17-2010, 06:52 PM   #11
OrientBlau
My Ride: 2003 330i
What are opinions of the DOT4 sold at the dealer.
OrientBlau is offline   Reply With Quote
Old 10-17-2010, 10:36 PM   #12
bigjae1976
bigjae1976's Avatar
Depends but it should be fine for street use/light track use.
Old 10-18-2010, 11:03 AM   #13
ECSTuning
ECSTuning's Avatar
My Ride: BMW
We have an entire section devoted to E46 braking fluid. I am personally running ATE Super blue and have never had an issue.
However we also carry the entire Motul lineup, as well as Pentosin, and OEM.
Best,
Joe
Old 10-18-2010, 02:07 PM   #14
teamdfl
Slow in, slower out
My Ride: 325it
DOT 3/4/5.1 refers to the wet boiling point of brake fluid. A DOT 3 can have a higher dry boiling point than a DOT 4. For the typical track junkie changing fluid several times a year, the dry boiling point is the critical specification.
For years, Ford DOT 3 heavy duty truck fluid (metal can) had a dry boiling point of about 550F at half the price of typical high performance fluid. Unfortunately, the accountants at Ford decided we were having too much fun for too little money. The new Ford DOT 3 comes in a plastic bottle and has a lower boiling point. For what its worth, The Ford DOT 3 had a higher dry point than their own DOT 4.
Mod the driver. Participate in your local BMWCCA autocross or driving school. Have you joined BMWCCA yet?
teamdfl is offline   Reply With Quote
Old 10-18-2010, 02:13 PM   #15
mvrk10256
My Ride: E30 325i
or if you dont track at all get a bottle or two of synthetic Dot3/4 at ur local autozone and flush that **** out. you will be just fine.
Old 10-28-2010, 03:34 PM   #16
M-bird
My Ride: 325i, GULF E30M3!!!
I use Motul 600 RBF in the race car.
For a street car ATE blue or gold is fine, even for light track use.
M-bird is offline   Reply With Quote
Old 10-28-2010, 11:33 PM   #17
SC_TR0JAN_M3
My Ride: 2004 BMW M3
ate's a happy medium between getting a higher boiling point and not breaking your wallet like srf or motul. i've used it on and off the track with no issues. when i did use motul, the only thing i gain was a slightly better pedal feel and a lighter wallet.
2004 CB 6 Speed ///M3
Looking For :: GC Race Sways :: SS Race ::
SC_TR0JAN_M3 is offline   Reply With Quote
Old 10-30-2010, 11:47 AM   #18
Chris__B
My Ride: Several
I use AP Racing Formula 5.1 for daily driving and track days. It has great thermal properties and the correct viscosity for ABS valves. Just change it out every two years, just like what is recommended for any other brake fluid.
For dedicated track cars, AP600 racing fluid. For all-out racing with slick and downforce, AP PRF is hard to beat. Just below the boiling point of Castrol SRF, but much better recovery properties.
Chris
Chris__B is offline   Reply With Quote
Old 10-30-2010, 12:33 PM   #19
DangerousMind
My Ride: Sierra 1500 SLT
I alternate between Ate Super Blue and Ate Typ 200 (Gold).
DangerousMind is offline   Reply With Quote
Old 10-30-2010, 06:35 PM   #20
e46techtuner
My Ride: 2000 328i
I use DOT 4 from the dealer. No, problems on street or track. You can alternate from DOT 4 and DOT 3 but DOT 5 is usually silicone based and doesn't mix well with 3 or 4 brake fluid.
e46techtuner is offline   Reply With Quote
