Go Back   E46Fanatics > Tuning & Tech > Suspension & Braking
Old 10-16-2010, 06:56 PM   #1
jbl_91762
My Ride: 01 330i BLK Sedan
help deciding which lower control arms and bushings
Ok installed the new shoes Hankook V12s and the shop noticed that my I am in need of a new lower control arm and bushings. why would I have to replace the whole control arm and not just the busings, I mean isnt the control arm steel or aluminum and its the bushings that go out?? I also have KW VS2 Coil overs so which bushings and control arms should I get to complement my suspension set-up? I will hit the occsaional track day but the car is also my daily driver.
jbl_91762 is offline   Reply With Quote
Old 10-16-2010, 06:57 PM   #2
mvrk10256
My Ride: E30 325i
meyle HD control arms, powerflex bushings. if its oem you cant just replace teh ball joints, however the meyle has pressable ball joints.
/thread
Old 10-16-2010, 07:19 PM   #3
jbl_91762
mvrk, are you saying I can get away with just Meyle has ball joints I can use so I do not have to replace the control arms? Im certain the arms are stock. Thanks cause I have no clue
Old 10-16-2010, 09:01 PM   #4
TxZHP04
My Ride: ESS TS2+ ZHP
No, the ball joints on the stock control arms are not serviceable. The Meyle ball joints are made for the Meyle HD control arms. What mvrk is saying is that if you go ahead and get the Meyle arms now, then in the future you should only need to replace the ball joints and bushings.
