Thread Tools Search this Thread Rating: Thread Rating: 14 votes, 4.43 average. Display Modes
Old 07-05-2011, 01:14 AM   #481
southpaw
My Ride: E36 M3 and E36 318ti
<3
y u no teach me your ways?!
-Brandon
239whp/227wtq @2700lbs
southpaw is offline   Reply With Quote
Old 07-05-2011, 01:23 AM   #482
cyberkaa
My Ride: E46 332i,M3;E30 325i
Because postcount
-Kalim
(klx photo studio)
Old 07-05-2011, 11:47 PM   #483
omhl
My Ride: E46 M3 6MT
Send a message via AIM to omhl
this guy is legit....
omhl is offline   Reply With Quote
Old 07-06-2011, 12:56 AM   #484
mkodama
mkodama's Avatar
Unlike some other shady azn kids that I hear pass by KLX auto on occasion.
Old 07-06-2011, 01:35 AM   #485
omhl
My Ride: E46 M3 6MT
Referred my friend to you for rear shock install .
Old 07-06-2011, 01:47 AM   #486
Kris.R
My Ride: 2012 Dodge Charger
Bump for a super cool guy!
- Kris -
"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves."
-Abraham Lincoln-
Kris.R is offline   Reply With Quote
Old 07-06-2011, 10:53 AM   #487
DJ Reminisce
My Ride: Knows Dubstep SUCKS
Originally Posted by cyberkaa View Post
Today (Monday), DJ Reminisce (Kayvan) came over in the morning to have his blown OEM suspension replaced on his ZHP coupe with a Ground Control spring and shock setup. The rears went in without a hitch, but a stud on the strut hat on the driver's side broke free, rendering the hat unusable. We decided to hold off on the fronts as the new struts did not come with new hats and Kayvan would have to order new ones.
New hats and dust sleeves in hand! Look forward to finishing off the installation tonight man!
Dinan CAI_Stage II_3.46 Dif
OEM CF Strut Bar_Eibach Sportline_GC Konis
OEM Gloss Grills_H&R Spacers_Clubsport Sills_Painted Splitters
Amber LED Corners/6k HID Fogs/LED Interior_Shadow Emblems
500W_RE Audio_Hertz Components
DJ Reminisce is offline   Reply With Quote
Old 07-06-2011, 11:29 AM   #488
cyberkaa
Thanks, Oscar!
Thanks, Kris!
-Kalim
(klx photo studio)
Old 07-06-2011, 11:30 AM   #489
cyberkaa
Awesome. Will see you and your car tonight.
-Kalim
(klx photo studio)
Old 09-04-2011, 06:23 AM   #490
slate
My Ride: 1987 325ic, 2003 M3
Hey, just to update you - I'm driving the car! It's absolutely fantastic! After the "hard code" that I couldn't get rid of, the bad starter that the shop found and then the clutch was off just enough on my install to have the clutch retensioned, reinstalled with the $400+ clutch tool (despite the SMG clutch writeup that iI found on here that did without), and a reinstall of the SMG software, it was ready to go! Starting in December, using your engine swap writeup, traveling 4 hrs one way to work on it and 3 months in shops, it's been a long road, but after driving the car about 1000 miles in the last 4 or so days... WOW! Thanks!
slate is offline   Reply With Quote
Old 09-04-2011, 08:27 AM   #491
cyberkaa
That was quite a journey, but your perseverance paid off. Congrats!
-Kalim
(klx photo studio)
Old 09-12-2011, 12:23 AM   #492
cyberkaa
Back from vacation and into the swing of things...
Kyle (323ci newbie) finally has a new suspension to replace his well-worn OEM one.
We also attempted to replace his burned out electric fan today, but found out that the part was incorrect. Bummer.
I'll be trying to work through a backlog of things on the E30 to make it a reliable daily driver again so I can start working on the S54 swap in the sedan. More to come...
-Kalim
(klx photo studio)
Old 09-12-2011, 12:34 AM   #493
Gheybe
Gheybe's Avatar
My Ride: F80 M3
Don't give a shiit about what this thread is about.
Just came in here to scream at you for your 100k posts.
Gheybe is offline   Reply With Quote
Old 09-12-2011, 12:47 AM   #494
cyberkaa
You mad, brah?
-Kalim
(klx photo studio)
Old 09-12-2011, 12:53 AM   #495
Gheybe
Gheybe's Avatar
My Ride: F80 M3
I'm 'mirin
Old 09-15-2011, 02:22 PM   #496
323ci newbie
My Ride: mkodama
323ci newbie is offline   Reply With Quote
Old 09-15-2011, 02:23 PM   #497
323ci newbie
My Ride: mkodama
thanks kalim!
Y U NO FINISH SWAP?!
Old 09-25-2011, 10:30 PM   #498
cyberkaa
Busy weekend!
Started Saturday off by helping Robert (robt_sf) with his E46 vert in the morning. Robert came by a while back to have his LCM reflashed for HIDs hoping to solve a flickering issue he had with the OEM headlights he had retrofitted. The headlights would work fine on battery it seems, but would start flickering continuously after 10-15 seconds if the car was running. Additionally, turning other electrical devices on, such as the heater, defroster, or windows, would either momentarily stop the flickering or kill the lights altogether until the car was shut off. Flashing the LCM hadn't helped, so we went through a step by step diagnosis checking for correct voltage at the headlight connectors, taillight ground, etc. Everything checked out, so the last thing we tried was plugging in a spare LCM I had on hand. It solved the problem completely, so Robert is going to see about getting a new one.
After that, I gave the E30 a much needed wash. It's amazing how dirty a tree can make a car in such a short time...
Finally, I headed over to help TKC (Toby) with some wiring on his Yamaha R6. We started a retrofit of his HID projectors into the headlight housing last weekend and Toby finished that up a few days ago, so I had gone over again to figure out how to make the projectors come on with the high/low beam switches the way he wanted. Yesterday, we worked on getting rid of some glitches (poorly designed harness connector) and routing the cables. Unfortunately, the bike decided it didn't want to start anymore, so after finishing what we could, we called it quits. Toby finished tying the cables up today and the end result is simply awesome.
Today, I got down to some regular maintenance on the E30. The A/C and power steering v-belts had snapped on the way to Toby's house yesterday, so that was the first order of business. Next, I checked the front suspension out as the front tires have worn very unevenly in the last 500 miles or so. The control arms and bushings checked out ok, so I'll be picking up some new tires and getting the car aligned hopefully next week. I finished up by topping the fluids up, checking the air pressure in the tires, and testing the lights. One high-beam bulb is out and I'll need to fix what's probably a bad ground that's affecting both the right low-beam and turn signal. D'oh.
For some good news, I've gotten another load of parts for the S54 sedan swap. I'll be picking up a few pieces to complete the clutch setup soon.
-Kalim
(klx photo studio)
Old 10-03-2011, 02:57 AM   #499
cyberkaa
Did some more work over the weekend...
On Saturday, one of my coworkers with an E46 came by for a quick bit of maintenance. First up, we had to address the slow leak from the transmission drain plug that I spotted last time when I had his car off the ground to replace RTABs and FCABs. It was a good opportunity to change the transmission fluid, so after a quick drain, I replaced the plug with a new one and refilled the transmission with some fresh fluid. Next, I read out the fault codes to see what was causing an SES light to pop up intermittently and it looks like the thermostat is stuck open so that'll be the next item on the maintenance list. Finally, we popped in a fresh cabin air filter. The old one hadn't been changed in ages and it certainly showed...
Later, Robert (robt_sf) came by with the brand new LCM to replace the one we determined last week to be faulty, so I plugged it in and flashed it for him. No tamper dot and perfect HID light function for his vert.
Robert's wife also brought her E46 sedan by to get an SRS fault diagnosed and cleared. The module had logged a supply voltage fault at one of the tensioners. The code didn't come back after being cleared, so hopefully it'll stay gone.
Today, Jason (sellsellsell2000) and his 323i visited the garage to have the oil filter housing gasket replaced. Jason's car had been making a horrible mess in his driveway because of copious amounts of oil leaking from that area. We also found that oil had seeped out near the banjo fitting that connects the VANOS oil line to the rear side of the oil filter housing. It wasn't clear whether the line itself had leaked from the rotating joint on the hard section or if the banjo fitting itself was the cause, so we replaced the banjo bolt and installed a pair of new sealing washers for now. We'll see how that holds up when Jason comes back next time for his VANOS seals.
Sorry for the lack of pics!
WTB: lovely assistant to photograph garagewerke!
Next week: Inspection II on an E46 M3! Well, if the schedule works out, anyway. I'll try to take pics of that since some parts of that service are interesting.
-Kalim
(klx photo studio)
Old 10-03-2011, 03:02 AM   #500
Drew@Swift Motorworks
Past Site Sponsor
My Ride: Scooty Puff Jr
Dude for real? Stop working on oter people's crap and do your own car
Drew@Swift Motorworks is offline   Reply With Quote
epic
